RG-SF2920-8GT2MG2XS 8-Port GE All-Optical Switch, 2 × 2.5G Electrical Ports (Backward Compatible)
  • Various port combinations, rate increase, surge protection greater than 8 kV, 8 × 10/100/1000Mbps copper ports with auto-negotiation, 2 × Gigabit/2.5G copper ports, and 2 × 10G uplink fiber ports
Thông số chi tiết chính
All-Optical Ethernet Switch RG-SF2920-8GT2MG2XS
This switch provides 8 × 1G Ethernet ports with auto-negotiation, 2 × 2.5G optical ports, 2 × 10G uplink optical ports, rich interfaces, supporting full service expansion.
and No Security Concern
Flexible Installation
Heat Dissipation Design
Quietness
It can be flexible installed in a concealed ELV box, in a customized cabinet or under a workbench.
New 2.5G Ethernet Port Providing a Higher Access Rate
The 2.5G Ethernet port supports a high-speed downlink transmission and allows Wi-Fi 6 access points to connect to the network at full load with an access rate of 5G.
Optical Link O&M
FAQ
Tài liệu
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS
RG-SF2920U-8GT1MS-P
Interface Specifications
Fixed port
4 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, electrical ports 1–4 support PoE/PoE+
8 x 10/100/1000M auto-negotiation electrical ports
1 x 1000M/2.5G SFP optical port
1 x 1000M/2.5G SFP+ port, electrical ports 1–8 support PoE/PoE+
Fixed single AC power supply
1 x console port
1 x console port
1 x console port
9.7 Mpps
16 Mpps
16 Mpps
13 Gbps
21 Gbps
21 Gbps
1000
Ingress: 1500
Egress: 500
200 mm x 170 mm x 43.6 mm (7.87 in. x 6.69 in. x 1.72 in.)
200mm x 170mm x 55 mm (7.87 in. x 6.69 in. x 2.17 in.)
Weight (full configuration, including packaging)
2.23 kg (4.92 lbs)
1.98 kg (4.37 lbs)
2.54 kg (5.60 lbs)
CPU and Storage
MAC chip with built-in single-core CPU, 400 MHz
Storage
16 MB flash memory
16 MB flash memory
16 MB flash memory
Data packet buffer
8 MB
8 MB
8 MB
Power and Consumption
< 15 W (without PoE full load)
< 60 W (with PoE full load)
< 15 W
< 150 W (with PoE full load)
Rated input voltage
AC input: 200 V AC to 240 V AC @ 50 Hz to 60 Hz
Maximum input voltage
AC input: 180 V AC to 264 V AC
40°C (104°F): > 300K
Primary airflow
Natural heat dissipation
Weak-current box: 0°C to 40°C (32°F to 104°F)
Desktop and wall: 0°C to 40°C (32°F to 104°F)
Rack: (32°F to 113°F)
5% to 95% RH (non-condensing)
Interface surge protection
Power port: 6 kV (common/differential mode)
Communication port: 8 kV (common mode)
Operating altitude
0 m to 5000 m (16404.20 ft.)
Hardware Specifications (Continued)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2MG2XS
RG-SF2920-16GT2SFP
Fixed port
2 x 1000M/2.5G auto-negotiation ports
2 x 1/10G SFP+ ports
16 x 10/100/1000M auto-negotiation electrical ports
2 x 1G SFP optical ports
1 x console port
1 x console port
1 x console port
49.1 Mpps
61 Mpps
26.8 Mpps
66 Gbps
82 Gbps
500
500
Ingress: 1,500
Egress: 500
2.75 kg (6.06 lbs)
3.11 kg (6.86 lbs)
2.75 kg (6.06 lbs)
CPU and Storage
MAC chip with built-in single-core CPU, 1 GHz
Storage
512 MB SDRAM
256 MB flash memory
512 MB SDRAM
256 MB flash memory
512 MB SDRAM
256 MB flash memory
Data packet buffer
12 MB
12 MB
12 MB
< 25 W
< 25 W (without PoE full load)
< 25 W
Rated input voltage
Primary airflow
0°C to 50°C (32°F to 122°F)
Operating altitude
RG-SF2920-16GT2SFP-P
RG-SF2920-8GT2MG2XS-P
RG-SF2920-16GT2MG2XS-P
Fixed port
2 x 1G SFP ports
Electrical ports 1–8 support PoE/PoE+
2 x 1000M/2.5G/5G auto-negotiation electrical ports
2 x 1G/10G SFP+ ports
2 x 1000M/2.5G/5G adaptive electrical ports
2 x 1G/10G SFP+ ports,
Electrical ports 1-8 support PoE/PoE+
1 x console port
1 x console port
1 x console port
68.44 Mpps
16 Mpps
68.44 Mpps
92 Gbps
21 Gbps
92 Gbps
500
500
Ingress: 1,500
Egress: 500
2.81 kg (6.20 lbs)
3.12 kg (6.88 lbs)
CPU and Storage
Storage
512 MB SDRAM
256 MB flash memory
512 MB SDRAM
256 MB flash memory
512 MB SDRAM
256 MB flash memory
Data packet buffer
12 MB
12 MB
12 MB
Rated input voltage
Primary Airflow
Operating altitude
RSTP (IEEE 802.1w)
SNTP
MQTT
Syslog/Debugging
 IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W)
 Energy-efficient power supply management modes
 Warm start to implement uninterrupted power supply
Software Specifications (Continued)
RG-SF2920-16GT2SFP, RG-SF2920-16GT2SFP-P, RG-SF2920-8GT2MG2XS, RG-SF2920-8GT2MG2XS-P, RG-SF2920-16GT2MG2XS, RG-SF2920-16GT2MG2XS-P
MAC VLAN
Basic QinQ and flexible QinQ
DHCP server, DHCP client, DHCP snooping, and DHCP snooping
Static blackhole routing
ACL80 and IPv6 ACLs
SSHv1.5 and SSHv2.0
Portal authentication
Unknown unicast suppression
Load balancing
LACP dynamic aggregation
Cross-VSU aggregate interface
IPv4 VRRP v2/v3, IPv6 VRRPv3
GR for OSPF
RSPAN and ERSPAN
Flow- and VLAN-based SPAN
SPAN, RSPAN, and ERSPAN
 Electrical ports in compliance with IEEE 802.3af (15.4 W) and IEEE 802.3at (30 W)
 Automatic and energy-efficient power supply management modes
RG-SF2920U-4GT1MS-P
4 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply; electrical ports 1–4 support PoE/PoE+; maximum PoE output power: 45 W
RG-SF2920U-8GT1MS
8 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply
RG-SF2920U-8GT1MS-P
8 x 10/100/1000M auto-negotiation electrical ports, 1 x 1000M/2.5G SFP port, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W
RG-SF2920-16GT2SFP
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1G SFP ports, fixed single AC power supply
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1G SFP ports, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W
RG-SF2920-8GT2MG2XS
8 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G adaptive ports, 2 x 1/10G SFP+ ports, fixed single AC power supply
8 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G/5G auto-negotiation electrical ports, 2 x 1/10G SFP+ ports, fixed single AC power supply; electrical ports 1–8 support PoE/PoE+; maximum PoE output power: 125 W
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G adaptive ports, 2 x 1/10G SFP+ ports, fixed single AC power supply
16 x 10/100/1000M auto-negotiation electrical ports, 2 x 1000M/2.5G/5G auto-negotiation electrical ports, 2 x 1/10G SFP+ ports, fixed single AC power supply; electrical ports 1-8 support PoE/PoE+; maximum PoE output power: 125 W
User Experience Questionnaire
We cordially invite you to participate in the user experience survey on our official website. Your feedback will help us build a better platform.
No
