RG-MUX-8LC/LC-H Anahtarlar - 1
RG-MUX-8LC/LC-H Anahtarlar - 2
RG-MUX-8LC/LC-H Anahtarlar - 3
RG-MUX-8LC/LC-H Anahtarlar - 4
RG-MUX-8LC/LC-H Anahtarlar - 5
RG-MUX-8LC/LC-H Anahtarlar - 6
RG-MUX-8LC/LC-H Anahtarlar - 7
RG-MUX-8LC/LC-H Anahtarlar - 8
RG-MUX-8LC/LC-H Anahtarlar - 9
RG-MUX-8LC/LC-H Anahtarlar - 10
RG-MUX-8LC/LC-H Anahtarlar - 11
RG-MUX-8LC/LC-H Ethernet All-Optical Modular 8-Port Transparent Distribution Device Used with Splitters
Paired with splitters to realize dual uplinks on network links and suitable for scenarios with dual core switches
  • Combination of splitters and transparent distribution devices, achieving dual uplinks for all-optical links and improving the link reliability between the core network and building
Özellikler
RG-MUX-8LCI/LC-H 8-Port Transparent Distribution All-Optical Network Passive Device
An 8-port transparent distribution device on the building side supports both 10 Gbps and 1 Gbps per port, and can accommodate up to 48 ports when fully loaded. The device integrates WDM technology, which allows for a network architecture reduced from three layers to two layers. With WDM, services from the core side to the access side are transparently transmitted, realizing passive distribution nodes.
Spesifikasyonlar
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Kaynaklar
Sipariş Bilgileri
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
