RG-S2910C-24GT2XS-HP-E Anahtarlar - 1
RG-S2910C-24GT2XS-HP-E Anahtarlar - 2
RG-S2910C-24GT2XS-HP-E Anahtarlar - 3
RG-S2910C-24GT2XS-HP-E Anahtarlar - 4
RG-S2910C-24GT2XS-HP-E, 24-port Gigabit access PoE switch (plus 2 COMBO ports), 2 10 Gigabit upstream ports, 2 expansion slots
Full gigabit access to LANs in large enterprise parks, gigabit access to commercial systems.
  • Green energy saving, saving 40% power consumption compared to products in the same class.
  • Equipped with Ruijie Network's self-developed multi-process modular RGOS11.X operating system.
  • Fully supports SDN features and complies with the Openflow 1.3 protocol standard.
  • Support TR069 zero configuration online; A wide variety of port form factors.
Özellikler
RG-S2910XS-E Series New-Generation Efficient and Energy-Saving Switches
Power consumption reduced by 40% compared with similar products
Multi-process modular OS RGOS 11.X developed by Ruijie Networks
SDN features and compliance with OpenFlow 1.3
Switch zero-configuration via TR069
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
(concerning high and low temperature tolerance, vibration, electromagnetic interference, power surge, signal tests, etc.)
Hardware and software-level CPU Protection Policy (CPP)
Accurate traffic statistics
Unified management and control of 9 virtualized devices
Multiple Modes Ensuring Easy Management
Creating New Green and Energy-saving Devices
Compared with the RG-S5750-S products with the same configuration, the S2910XS-E reduces power consumption by more than 40% .
Compared with the RG-S2900G-E products with lower configuration, the S2910XS-E reduces power consumption by about 10% .
Spesifikasyonlar
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
RG-S2910-10GT2SFP-P-E
RG-S2910C-48GT2XS-HP-E
24 10/100/1000BASE-T ports
4 1G/10GBASE-X SFP+ ports (non-combo)
48 10/100/1000BASE-T ports
10 10/100/1000BASE-T ports
2 100/1000BASE-X SFP ports (non-combo)
24 10/100/1000BASE-T ports (PoE/PoE+)
2 100/1000BASE-X SFP ports (combo)
2 1G/10GBASE-X SFP+ ports (non-combo)
48 10/100/1000BASE-T ports (PoE/PoE+)
Expansion Slots
Modular Power Slots
Fan Slots
Fixed
Fixed
Fixed
Fixed
Expansion Modules
M2910-01XS
M2910-01XS
Management Ports
1 console port
1 console port
1 console port
1 console port
1 USB 2.0 port
1 console port
1 USB 2.0 port
Switching Capacity
264Gbps
264Gbps
256Gbps
264Gbps
264Gbps
Packet Forwarding Rate
96Mpps
132Mpps
18Mpps
96Mpps
132Mpps
Max. Number of 10GE Ports
IEEE802.3af and 802.3at power supply standards; Automatic/energy-saving (default) power supply mode; Hot startup and uninterrupted power supply; Port priority; PoE devices support stacking
Port Buffer
1.5MB
RAM
512MB
ARP Table
500
MAC Address
16K
Routing Table Size
(IPv4/IPv6)
500 (IPv4/IPv6)
500 (IPv4/IPv6)
64 (IPv4/IPv6)
500 (IPv4/IPv6)
500 (IPv4/IPv6)
ACL Entries
In: 1,500
Out: 500
In: 1,500
Out: 500
In: 750
Out: N/A
In: 1,500
Out: 500
In: 1,500
Out: 500
4K 802.1q VLANs, Port-based VLAN, MAC-based VLAN, Protocol-based VLAN, Private VLAN, Voice VLAN, QinQ, IP subnet-based VLAN, GVRP, Guest VLAN
QinQ
Basic QinQ, Flexible QinQ, 1:1 VLAN switching, N:1 VLAN switching, 1:N VLAN switching
Link Aggregation
AP, LACP (maximum 8 ports can be aggregated), Cross devices AP, Flow balance
Port Mirroring
Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring, Over devices mirroring, VLAN-based mirroring, VLAN-filtering mirroring, AP-port mirroring, RSPAN, ERSPAN
# RG-S2910-10GT2SFP-P-E supports N:1/1:N port mirroring, Flow-based mirroring
Spanning Tree Protocols
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC protection, ROOT guard,Spanning Tree Root Guard(STRG)
DHCP
DHCP server, DHCP client, DHCP snooping, DHCP relay, IPv6 DHCP snooping, IPv6 DHCP client, IPv6 DHCP relay,DHCP Snooping Option 82
Multiple Spanning Tree Protocol (MSTP) Instances
Maximum Aggregation Port (AP)
128
SDN
OpenFlow 1.0 & 1.3
VSU (Virtual Switch Unit)
Support (up to 9 stack members,to ensure the effectiveness of the use, 4 members are recommended* ), Local and distant stacking, Cross-chassis link aggregation in the stack, Stacking via 10G Ethernet ports
# All models support the features above except RG-S2910-10GT2SFP-P-E
Zero Configuration
CWMP(TR069)
L2 Features
MAC, EEE, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast/Multicast/Unknown unicast storm control, IGMP v1/v2/v3 snooping, IPv6 MLD Snooping v1/v2,IGMP SGVL/IVGL, IGMP querier, IGMP filter, IGMP fast leave, DHCP, Jumbo frame, RLDP, LLDP, REUP, G.8032 ERPS, Layer 2 protocol tunnel
Layer 2 Protocols
IEEE802.3, IEEE802.3u, IEEE802.3z, IEEE802.3x, IEEE802.3ad, IEEE802.1p, IEEE802.1x, IEEE802.3ab, IEEE802.1Q (GVRP), IEEE802.1d, IEEE802.1w, IEEE802.1s
IPv4 Features
Ping, Traceroute
IPv6 Features
ICMPv6, IPv6 Ping, IPv6 Tracert, Manually configure local address, Automatically create local address
IPv4 Routing Protocols
Static Routing, RIP, OSPF v1/v2
Basic IPv6 Protocols
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 Ping and IPv6 Tracert
IPv6 Routing Protocols
Static routing, RIPng, OSPF v3
G.8032
Support
Standard/Extended/Expert ACL, Extended MAC ACL, ACL 80, IPv6 ACL, ACL logging, ACL counter, ACL remark, Global ACL, ACL redirect, Time-based ACL, Router ACL, VLAN ACL, Port-Based ACL
802.1p/DSCP/TOS traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WFQ, SP+WRR, SP+DRR; Input / output port-based speed limit; Port-based traffic recognition; Each port supports 8 queue priorities; flow-based rate limiting with the minimum granularity of 8Kbps,Dynamic QoS
VSU (virtualization technology for virtualizing multiple devices into 1); RIP GR; ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
VSU (virtualization technology for virtualizing multiple devices into 1); RIP GR; ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol); 1+1 power redundancy; Hot-swappable power module
EEE Format
Support IEEE 802.3az standard
Binding of the IP address, MAC address, and port address; Binding of the IPv6, MAC address, and port address; Filter illegal MAC addresses; Port-based and MAC-based 802.1x; MAB; Portal and Portal 2.0 authentication; ARP-check; DAI; Restriction on the rate of ARP packets; Gateway anti-ARP spoofing; Broadcast suppression; Hierarchical management by administrators and password protection; RADIUS and TACACS+;Change of Authorization; AAA security authentication (IPv4/IPv6) in device login management; SSH and SSH V2.0; BPDU guard; IP source guard; CPP, NFPP; Port protection, CoA(RADIUS change of authorization),SCP (Secure Copy)Dynamic ARP Inspection(DAI)
Manageability
SNMPv1/v2c/v3, CLI (Telnet / Console), RMON (1, 2, 3, 9), SSH, Syslog / Debug, NTP / SNTP, FTP, TFTP, Web, SFLOW,HTTP or HTTPS
# RG-S2910-10GT2SFP-P-E supports SNMPv2c, CLI (Telnet / Console), Syslog, RMON (1, 2, 3, 9), Web
Hot Patch
Support
Smart Temperature Control
Auto fan speed adjustment; Fan malfunction alerts; Fan status check
Smart Power Supply
Support power control and management
Other Protocols
FTP, TFTP, DNS client, DNS static
(W x D x H)  (mm)
440 × 260 × 43.6
440 × 260 × 43.6
340 × 260 × 44
440 × 320 × 44
440 × 360 × 44
Rack Height
1RU
≤3.5kg
≤4kg
<2.5kg
5.8kg (gross weight)
6.8kg (gross weight)
MTBF (hours)
 >200K
Lightning Protection on Power Port
Common Mode 6KV/Differential Mode 6KV
Common Mode 4KV/Differential Mode 2K
Lightening Protection on Communication Port
Common Mode 6KV
AC input:
Rated voltage range: 100V to 240V AC
Maximum voltage range: 90V to 264V AC
Frequency: 50/60Hz
Rated current: 1.5A
HVDC input:
Input voltage range: 192V to 290V DC
Input current range: 0.5A to 0.1A
AC input:
Frequency: 50/60Hz
Rated current: 1.5A
HVDC input:
Input current range: 0.8A to 0.5A
AC input:
Frequency: 50/60Hz
Rated current: 2A
HVDC input:
Input current range: 1.0A to 0.4A
AC power (RG-M5000E-AC500P):
Frequency: 50/60Hz
Rated current range: 7A to 3.5A
HVDC input:
Input current range: 3.5A to 2.5A
DC power (RG-M5000E-DC500P):
Rated voltage range: -36V to -72V DC
Rated current: 16.5A
AC power (RG-RG-PA1150P-F):
Frequency: 50/60Hz
Rated current: 10A
HVDC input:
Rated current range: 10A
Frequency: 50/60Hz
HVDC input:
Frequency: 50/60Hz
Rated current: 10A
HVDC input:
Power Consumption
24W
50W
165W (with 8-port PoE or 4-port PoE+)
850W (with 24-port PoE+)
1700W (with 48-port PoE+)
PoE Power
125W
RG-M5000E-AC500P: 370W
RG-M5000E-DC500P: 370W
RG-PA1150P-F: 740W
RG-PA1150P-F: 740W
Safety Standards
IEC 60950-1, EN 60950-1
Emission Standards
EN 300 386, EN 55022/55032, EN 61000-3-2, EN 61000-3-3, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11
Operating temperature: 0°C to 50°C
Operating temperature: 0°C to 45°C
Storage temperature: -40°C to 70°C
Operating humidity: 10% to 90%RH
Storage humidity: 5% to 95%RH
Operating Altitude
-500m to 5,000m
 *Future release support
Kaynaklar All Resources
Sipariş Bilgileri
RG-S2910-24GT4XS-E
24 10/100/1000BASE-T Ports, 4 1G/10GBASE-X SFP+ Ports (non-combo), AC
RG-S2910-48GT4XS-E
48 10/100/1000BASE-T Ports, 4 1G/10GBASE-X SFP+ Ports (non-combo), AC
10 10/100/1000BASE-T Ports, 2 100/1000BASE-X SFP Ports (non-combo), Port 1-8 support PoE/PoE+, AC
24 10/100/1000BASE-T Ports (PoE/PoE+), 2 100/1000BASE-X SFP Ports (combo), 2 1G/10GBASE-X SFP+ Ports (non-combo), 1 USB, 2 Expansion Slots, 2 Modular Power Slots, AC/DC
48 10/100/1000BASE-T Ports (PoE/PoE+), 2 100/1000BASE-X SFP Ports (combo), 2 1G/10GBASE-X SFP+ Ports (non-combo), 1 USB, 2 Expansion Slots, 2 Modular Power Slots, AC/DC
Optional Accessories
M2910-01XS
1-Port 10G SFP+ Interface Module, for S2910XS PoE models
M2910-02XS
2-Port 10G SFP+ Interface Module, only for RG-S2910C-24GT2XS-P-E
RG-M5000E-AC500P
AC Power Module, 370W Power Budget for PoE, up to 24 PoE ports or 12 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
RG-M5000E-DC500P
DC Power Module, -32V to -72V DC input voltage, 370W Power Budget for PoE, up to 24 PoE ports or 12 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
RG-PA1150P-F
AC Power Module, 740W Power Budget for PoE, up to 48 PoE ports or 24 PoE+ ports (only for RG-S2910C-24GT2XS-HP-E and RG-S2910C-48GT2XS-HP-E)
Mini-GBIC-SX-MM850
1000BASE-SX mini GBIC Transceiver (850nm)
Mini-GBIC-LX-SM1310
1000BASE-LX mini GBIC Transceiver (1310nm)
Mini-GBIC-LH40-SM1310
1000BASE-LH mini GBIC Transceiver (1310nm, 40km)
Mini-GBIC-ZX50-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 50km)
Mini-GBIC-ZX80-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 80km)
Mini-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 100km)
10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC)
10GBASE-SR, SFP+ Transceiver (1550nm, 40km, LC)
Gigabit SFP BIDI Transceiver (TX1310/RX1550, 20km, LC)
Gigabit SFP BIDI Transceiver (TX1550/RX1310, 20km, LC)
Gigabit SFP BIDI Transceiver (TX1310/RX1550, 40km, LC)
Gigabit SFP BIDI Transceiver (TX1550/RX1310, 40km, LC)
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 1m
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 3m
10GBASE SFP+ Optical Stack Cable (included both side transceivers) for S2910 and S5750-H Series Switches, 5m
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
Bize Ulaşın
