RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 1
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 2
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 3
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 4
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 5
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 6
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 7
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 8
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 9
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 10
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 11
RG-S6120-24XMG4XS4VS-UP-H สวิตช์ - 12
RG-S6120-24XMG4XS4VS-UP-H 24-Port 10GE Managed Multi-GE Access Switches with 25GE Uplink Ports
100/1000/2.5G/5G/10GBASE-T ports, PoE/PoE+/PoE++, 4 x 10GE SFP+ ports and 2 x 25GE SFP28 ports, offering flexible networking options to build high-performance campus networks
  • 24 x 100/1000/2.5G/5G/10GBASE-T ports for access, 4 x 1GE/10GE SFP+ ports and 4 x 10GE/25GE SFP28 ports for uplink, meeting high bandwidth demands of large campuses
ฟีเจอร์
RG-S6120-24XMG4XS4VS-UP-H 10G Multi-GE Access Switches
24 x 100/1000/2.5G/5G/10GBASE-T ports and 4 x 10GE and 4 x 25GE uplink ports are provided to realize flexible networking.
Optical Port Fault Isolation
ข้อมูลจำเพาะ
RG-S6110-24MG4VS-UP
RG-S6110-48MG4VS2QXS-UP
RG-S6120-48XMG4VS2QXS-UP-H
2 x 40GE QSFP+ ports
Not Supported
Not Supported
Not Supported
RG-S6110-24MG4VS-UP
392 Mpps
678 Mpps
750 Mpps
982 Mpps
528 Gbps
912 Gbps
1008 Gbps
1320 Gbps
RG-S6110-24MG4VS-UP
AC input:
Fixed power supply: 460 W
The maximum power is 370 W.
90 W (without PoE)
460 W (full PoE load)
● 1 x RG-PA600I-P-F:450 W
● 2 x RG-PA600I-P-F:930 W
● 1 x RG-PA600I-P-F:400 W
● 2 x RG-PA600I-P-F:880 W
150 W (without PoE load)
1,800 W (full PoE load)
200 W (without PoE load)
RG-S6110-24MG4VS-UP
3.71 kg (8.18 lbs)
5.37 kg (11.84 lbs)
RG-S6110-24MG4VS-UP
3 x pluggable fan modules
27°C (80.6°F): 40 dB
Maximum value: < 78 dB
27°C (80.6°F): 60 dB
2+1 redundancy
2+1 redundancy
2+1 redundancy
Automatic speed adjustment
Service port: 8 kV
RG-S6110-24MG4VS-UP
Software Specifications
RG-S6100 Series
S6110-24MG4VS-UP: 100 Gbps
32,768
160,000
100
In: 2,500 Out: 1,000
RG-S6100 Series
Basic QinQ and selective QinQ
IP routing
Stateless Auto Configuration
IPv4/IPv6 VRF
IPv4/IPv6 PBR
IGMPv1/v2/v3 and IGMP proxy
MLD snooping
ACL80 and IPv6 ACL
ACL redirection
Multi-AAA
RADIUS and TACAS+
Loose and strict RPF
uRPF ignoring default routes
IPv4 VRRP v2/v3 and IPv6 VRRP
GR for RIP, OSPF, and BGP
FTP and TFTP
SNMP v1/v2/c3
Ruijie Could-based management
แหล่งข้อมูล
ข้อมูลการสั่งซื้อ
RG-S6110-24MG4VS-UP
25GE
VG-SFP-AOC7M(M)
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
