RG-MAP920-SF-M(V3) ไร้สาย - 1
RG-MAP920-SF-M(V3) ไร้สาย - 2
RG-MAP920-SF-M(V3) ไร้สาย - 3
RG-MAP920-SF-M(V3) ไร้สาย - 4
RG-MAP920-SF-M(V3) ไร้สาย - 5
RG-MAP920-SF-M(V3) ไร้สาย - 6
RG-MAP920-SF-M(V3), Simplified Optical Ethernet (SOE) Micro AP
2.5GE SFP port for high-speed indoor access
Enterprise-class Wi-Fi 7 delivering a data rate of up to 3.570 Gbps
WIS digital twin network for superior network O&M efficiency
ฟีเจอร์
RG-MAP920-SF-M(V3) SOE Micro AP
The RG-MAP920-SF-M(V3) is a Wi-Fi 7 wall-plate access point launched for Ruijie SOE Solution. It features dual radios with a combined peak data rate of 3.570 Gbps. It supports one 2.5GE SFP port and four 1000BASE-T ports, meeting needs of high-speed wired access for multiple devices.
2.5GE SFP Port for Ultra-Gigabit High-Speed Indoor Access
With the uplink 2.5GE SFP port, the device easily handles high-bandwidth broadband access requirements, delivering a more stable and smoother network experience.
Enterprise-Class Wi-Fi 7 Delivering a Data Rate of Up to 3.570 Gbps
Empowering seamless high-bandwidth applications with next-generation wireless performance.
WIS integrates intelligent O&M functions, including visualized fault locating, along with local, service and key area network optimization. These capabilities aim to improve operational efficiency and enhance the user experience for wireless networks.
Go to WIS Digital Twin Network >
ข้อมูลจำเพาะ
RG-MAP920-SF-M(V3)
Four spatial streams
Channels:
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
Two spatial streams
● Radio 2 -- 5 GHz: 2x2 downlink MU-MIMO, two spatial streams
Channels:
● Radio 2 -- 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
Radio technologies: OFDM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● Radio 1 -- 2.4 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
● Radio 2 -- 5 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
Channels:
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 574 Mbps (MCS0 to MCS11)
Radio technologies: Uplink/Downlink Orthogonal Frequency-Division Multiple Access (OFDMA)
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
802.11be
Channels:
● Radio 1 -- 2.4 GHz: 7.3 Mbps to 688 Mbps (MCS0 to MCS13)
Radio technologies: Uplink/Downlink OFDMA
Modulation types: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● 2.4 GHz: Two built-in omnidirectional smart antennas, with the peak antenna gain of 5.73 dBi
● 5 GHz: Two built-in omnidirectional smart antennas, with the peak antenna gain of 6.49 dBi
● One built-in omnidirectional antenna, with the peak antenna gain of 3.35 dBi
1 x 2.5G SFP port, which is compatible with the 1G SFP transceiver
4 x 10/100/1000BASE-T ports
1 x micro USB console port
1 x Bluetooth 5.3
1 x system status LED
● AP power-on status
● Uplink service port status
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Main unit: 86 mm x 160 mm x 38 mm (3.39 in. x 6.30 in. x 1.5 in.)
Main unit: 0.45 kg (0.99 lbs)
Mounting bracket: 0.05 kg (0.11 lbs)
Shipping: 9.78 kg (21.56 lbs)
Mounting in the 86 mm x 86 mm (3.39 in. x 3.39 in.) junction box or wall-mounting
Kensington lock
● 48 V DC/0.25 A power input over the DC connector
● IEEE 802.3af-compliant PoE power input using hybrid cables
Maximum power consumption: 12 W
● DC power: 12 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● 802.3af (PoE): 12 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
● Idle mode: 9 W
Storage altitude: --500 m to +5,000 m (--1640.42 ft. to +16,404.20 ft.)
Operating temperature: --10°C to +40°C (14°F to 104°F)
Operating altitude: --500 m to +5,000 m (--1640.42 ft. to +16,404.20 ft.)
Note: At an altitude in the range of 1,800--5,000 m (5,905.51--16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
512 MB DDR3L, 256 MB flash
● Maximum transmit power: +20 dBm (100 mW)
● Minimum transmit power: +12 dBm (15.85 mW)
● Minimum transmit power: +10 dBm (10 mW)
● Adjust the transmit power by percentage (recommended), with 1 dBm increments.
● The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance.
The following table lists the radio frequency performance of Wi-Fi including different frequency bands, protocols, and data rates. It is country-specific, and Ruijie Networks reserves the right of interpretation.
Wi-Fi Radio Performance
RG-MAP920-SF-M(V3)
2.4 GHz 802.11g
-91 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
-92 dBm
-72 dBm
2.4 GHz 802.11n (HT40)
-89 dBm
-70 dBm
2.4 GHz 802.11ax (HE20)
-92 dBm
14 dBm
-62 dBm
2.4 GHz 802.11ax (HE40)
-89 dBm
14 dBm
-59 dBm
2.4 GHz 802.11be (EHT20)
-91 dBm
MCS13
12 dBm
-57 dBm
2.4 GHz 802.11be (EHT40)
-89 dBm
MCS13
12 dBm
-53 dBm
5 GHz 802.11a
-92 dBm
-74 dBm
5 GHz 802.11n (HT20)
-92 dBm
-73 dBm
5 GHz 802.11n (HT40)
-91 dBm
-71 dBm
5 GHz 802.11ac (VHT20)
-92 dBm
MCS8
15 dBm
-69 dBm
5 GHz 802.11ac (VHT40)
-90 dBm
15 dBm
-65 dBm
5 GHz 802.11ac (VHT80)
-87 dBm
15 dBm
-63 dBm
5 GHz 802.11ax (HE20)
-93 dBm
14 dBm
-62 dBm
5 GHz 802.11ax (HE40)
-91 dBm
14 dBm
-60 dBm
5 GHz 802.11ax (HE80)
-87 dBm
14 dBm
-57 dBm
5 GHz 802.11ax (HE160)
-84 dBm
14 dBm
-54 dBm
5 GHz 802.11be (EHT80)
-87 dBm
MCS13
12 dBm
-51 dBm
5 GHz 802.11be (EHT160)
-84 dBm
MCS13
12 dBm
-48 dBm
Basic Functions
RG-MAP920-SF-M(V3)
RGOS11.9(6)W7B4 or later
1,024 (up to 256 STAs per radio)
Recommended number of STAs
Maximum number of WLAN IDs
Intelligent STA identification (the AC is required)
Mobile unit (MU) locating
Application management
PSK, web-based, 802.1X, WPA, WPA2, and WPA3 authentication
MAB
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3), WPA3-Enterprise (CCMP, GCMP), and WPA3-OWE
Dynamic policy
Static MAC address and MAC address filtering
MAC address table size: 1,024
Jumbo frame length: 1,518
Optical transceiver information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP)
Maximum number of SVIs: 256
VLAN ID range: 1--4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarms
Web management (eWeb)
When the AP works in cloud mode, it can be managed through WIS Cloud.
RG-MAP920-SF-M(V3)
One-click diagnosis -- analyzing problems and providing suggestions
Baseline analysis -- recording the configuration, version, and other changes, and tracking network KPI changes
Time capsule -- analyzing the device version and configuration change history
Batch generation of building floor information -- uploading floor plans, and dragging and dropping AP positions
One-click health report -- generating a report on the overall operation of a network
Deployment through Zero Touch Provisioning (ZTP) -- creating configuration templates and automatically applying configured templates
Big data capabilities
RG-MAP920-SF-M(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP920-SF-M(V3)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at https://www.ruijienetworks.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-MAP920-SF-M(V3)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at https://www.ruijienetworks.com/.
  • The functions of Wireless Access Systems including Radio Local Area Networks (WAS/RLANs) within the band 5150-5350 MHz for this device are restricted to indoor use only within European Union countries and other relevant European regions (BE/BG/CZ/DK/DE/EE/IE/EL/ES/FR/HR/IT/CY/LV/LT/LU/HU/MT/NL/AT/PL/PT/RO/SI/SK/FI/SE/TR/NO/CH/IS/LI/UK(NI)).
แหล่งข้อมูล
ข้อมูลการสั่งซื้อ
Mandatory/Optional
RG-MAP920-SF-M(V3)
Wi-Fi 7 dual-radio wall-plate access point
    ● Radio 1 -- 2.4 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 688 Mbps
    ● Radio 2 -- 5 GHz: Two spatial streams, 2x2 MU-MIMO, peak data rate of 2.882 Gbps
It complies with 802.11a/b/g/n/ac/ax/be, and supports switchover among Fat, Fit, and cloud modes.
It provides PoE and DC power supply.
● The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.25 A.
● The RG-MAP920-SF-M(V3) does not have a built-in optical transceiver by default, and BIDI optical transceivers must be used in pairs. Therefore, a pair of optical transceivers needs to be purchased separately. Recommended 2.5GE models: 2.5G-SFP-LX03-SM1310-BIDI-I and 2.5G-SFP-LX03-SM1550-BIDI-I.
Optional
RG-AM5528-SF
24 x 1G/2.5G downlink SFP ports
24 x PoE/PoE+ ports (with four ports supporting PoE/PoE+/PoE++)
4 x 10G uplink SFP+ ports
In i-Share mode, each master AP consumes eight AC licenses.
Optional
RG-HybridBox
Optional
RG-AM5832-SF-P
Ruijie SOE O-Share master AP
24 x 1G/2.5G/10G downlink SFP+ ports
24 x PoE/PoE+/PoE++ power supply ports
Select the RG-M5800-8VS (8 x 25G SFP28 ports) or the RG-M5800-2QXS (2 x 40G QSFP+ ports) for the uplink slot as needed.
The card features low-noise operation and is equipped with one power module. Each device occupies eight AC licenses, and must be equipped with an uplink card upon delivery.
Optional
Optional
RG-M5800-8VS
Uplink card of the 24-port 10G SOE O-Share master AP RG-AM5832-SF-P
8 x 1G/10G/25G SFP ports, which can be switched to the 10G SFP+ mode simultaneously
Optional
RG-M5800-2QXS
2 x 40G SFP+ ports
Optional
RG-24DUP1DB48LC
1 x DB-78 power connector
Optional
2DP48DC-E
Power patch panel: Provides two groups of uplink DB-78 power connectors and 48 downlink power ports. Each group of DB-78 connectors is independently interconnected with 24 power ports. An ODF must be purchased separately.
Optional
RG-OEHC-SM-1B6A2-2x0.5-I-305
Optional
RG-OEHC-SM-2B6A2-2x1.0-R-I-305
Indoor dual-core 2 x 1.0 mm² hybrid cable, single roll, 305 m (1,000.66 ft) in length
Optional
RG-OEHC-SM-2B6A2-2x1.5-O-1000
Outdoor dual-core 2 x 1.5 mm² hybrid cable, single roll, 1,000 m (3,280.84 ft) in length
Optional
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
