RG-WS7110 ไร้สาย - 1
RG-WS7110 ไร้สาย - 2
RG-WS7110 ไร้สาย - 3
RG-WS7110 ไร้สาย - 4
RG-WS7110 ไร้สาย - 5
RG-WS7110 ไร้สาย - 6
RG-WS7110, Next-Generation High-Performance 10 Gbps Wireless Access Controller
Applicable to large- and medium-sized network management and suitable for deployment on a Layer 2 or Layer 3 network
  • Supporting 32 licenses by default and up to 512 licenses after expansion
  • Intelligent load balancing, improving network performance
  • MAB, 802.1X, and Web-based authentication, ensuring network security
  • Unified cloud management, enabling remote O&M
ข้อมูลจำเพาะที่สำคัญ
ฟีเจอร์
RG-WS7110 Next-Generation High-Performance 10 Gbps Access Controller
The RG-WS7110 can be applicable to large- and medium-sized network management and deployed on a Layer 2 or Layer 3 network, enabling visualized management and control of the wireless network.
Intelligent Load Balancing
  • Client-based load balancing, steering clients to less congested APs to prevent overload.
  • Band-based load balancing, steering clients to the 5 GHz frequency band to enhance bandwidth utilization.
  • Traffic-based load balancing, steering clients to APs with less traffic to increase the average bandwidth for client access.
Multiple Authentication Modes
  • MAB authentication: It frees a user from repeatedly entering the username and password that are required only upon first login.
  • Other authentication modes: 802.1X, Web-based, and PPSK authentication.
Unified Cloud Management
Unified management through WIS Cloud, eliminating the need for on-site provisioning.Real-time warning and intelligent troubleshooting, improving O&M efficiency.
ข้อมูลจำเพาะ
RG-WS7110
4 GB
RG-WS7110
Unit dimensions (W x D x H)
Rack size
2.7 kg (5.95 lbs)
3.5 kg (7.72 lbs)
Rack-mount
RG-WS7110
8 x 10/100/1000BASE-T ports
2 x 1GE SFP/RJ45 combo ports
2 x 10GE SFP+ ports
1 x system status LED
1 x power status LED
2 x 10GE SFP+ port LEDs
  • Note
RG-WS7110
30 W
Power output
12 V/3.33 A
RG-WS7110
Applicable Software Version
RG-WS7110
RGOS11.9(6)W3B15
Performance Indicators
RG-WS7110
Default number of managed APs
32
Note: The default number of APs that can be managed by the RG-WS7110 is subject to the AP model. For details, see the Ordering Information.
2,048
Maximum number of managed APs
512 (Generic APs)
1024 (Wall-Plate APs)
Note: The maximum number of APs that can be managed by the RG-WS7110 is subject to the AP model. For details, see the Ordering Information.
Maximum number of managed clients
5,120
Note: The maximum number of clients that can be managed by the RG-WS7110 is subject to the network environment. Contact technical support team for details.
Forwarding capacity
Maximum number of WLAN IDs
2,048
Maximum number of clients supported by the built-in Portal server
1,500
4,096
MAC address table
32,768
ARP table
32,768
Intra-AC roaming handoff time
< 50 ms
RG-WS7110
IEEE 802.11 protocols
802.11, 802.11b, 802.11a, 802.11g, 802.11d, 802.11h, 802.11w, 802.11k, 802.11v, 802.11r, 802.11i, 802.11e, 802.11n, 802.11ac, 802.11ax, and 802.11be
Roaming
Forwarding mode
Centralized forwarding
Local forwarding
Wireless QoS
Fair scheduling
AC-based user isolation
AP-based user isolation
WLAN-based user isolation
AC virtualization
AC failover
Multi-AC cluster (N-to-N)
WLAN optimization
RF management
Coverage Hole Detection
Band selection
Real-time RF configuration changes with minimal user disruption
RG-WS7110
IPv4 security authentication
802.1X authentication
MAB authentication
IPv6 security authentication
802. 1X authentication
Multi-SSID mode
WPA and WPA2
WEP (WEP/WEP128)
TKIP
CCMP
ARP anti-spoofing
AP virtualization
Protocols
RG-WS7110
IPv4 protocols
Ping and Traceroute
DNS client
NTP
Telnet
TFTP server and TFTP client
FTP server and FTP client
IPv6 protocols
DNSv6 client
TFTPv6 client
FTPv6 server and FTPv6 client
IPv6 CAPWAP
IPv6 ping
IPv6 traceroute
Neighbor discovery
IPv4 routing
Static routing, RIP, and OSPF
IPv6 routing
RG-WS7110
RMON
Syslog
Remote probe
On-demand diagnosis with packet capture
Remote Packet Capture Protocol (RPCAP) with third-party tools for remote packet review
Eweb
RG-WIS
Wi-Fi heat map
RG-WS7110
IEC 62368-1, EN 62368-1
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, and EN 300 386
แหล่งข้อมูล
ข้อมูลการสั่งซื้อ
Main Unit
RG-WS7110
The next-generation wireless access controller provides 8 x 10/100/1000BASE-T ports, 2 x 1GE SFP/RJ45 combo ports, and 2 x 10GE SFP+ ports.
It supports 32 licenses by default, and up to 512 licenses are available.
The maximum number of APs that can be managed by the RG-WS7110 is subject to the AP model:
● A generic AP occupies one license. The RG-WS7110 can manage up to 512 generic APs.
● A wall plate AP occupies half of the license. The RG-WS7110 can manage up to 1,024 wall plate APs.
● An i-Share micro AP occupies no license. The RG-WS7110 can manage up to 1,024 i-Share micro APs.
● The number of licenses occupied by an i-Share master AP is subject to the model. For details, see the Ordering Information in the datasheet of corresponding i-Share master AP.
Optical Transceivers
License
Product Description
RG-LIC-WS-16
RG-LIC-WS-32
RG-LIC-WS-128
RG-LIC-WS-512
RG-LIC-WS-1024
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
