RG-AP9861-R ไร้สาย - 1
RG-AP9861-R ไร้สาย - 2
RG-AP9861-R ไร้สาย - 3
RG-AP9861-R ไร้สาย - 4
RG-AP9861-R ไร้สาย - 5
RG-AP9861-R, Wi-Fi 7 24.436 Gbps Indoor Access Point, 18 Spatial Streams, Built-in AI Radio
Applicable to Ruijie Simplified Optical Ethernet Solution and ideal for high-density indoor scenarios in the sectors covering higher education, government, general education, finance, and business.
  • Enterprise-class Wi-Fi 7 revolution, delivering a data rate of up to 24.436 Gbps
  • 10GE SFP+/RJ45 combo port for flexible networking, empowering future applications
  • Ruijie Simplified Optical Ethernet Solution, guaranteeing worry-free network running in the next decade
  • Self-developed AI radio technology, enabling real-time, full-band scanning and seamless roaming
ข้อมูลจำเพาะที่สำคัญ
ฟีเจอร์
AR Series High-Density Indoor Wi-Fi 7 Access Point
RG-AP9861-R
18 spatial
streams
Up to 24.436 Gbps
data rate
Five radios
(including one AI radio)
PoE/DC power
supply
IoT expansion
and Bluetooth 5.3
Delivering a Data Rate of Up to 24.436 Gbps
24.436 Gbps
  • 4096-QAM
    for High Data Rate
    The next-generation IEEE 802.11be standard uses 4096-QAM, achieving a data rate of up to 24.436 Gbps.
  • Multiple Wi-Fi Technologies
    for High-Density User Access
    Multiple Wi-Fi technologies are integrated to increase the average rate per user to up to 2.4 times that of 802.11ax in high-density deployment and access scenarios.
  • Fifth-Generation Smart Antennas
    for Wide Signal Coverage
    Fifth-generation smart antennas and dual-antenna mode are adopted to provide uninterrupted signals when clients move, enabling wide signal coverage.
Ruijie SOE Solution, Guaranteeing Worry-Free Network Running in the Next Decade
The RG-AP9861-R supports the all-optical architecture. Working with the optical i-Share master AP and hybrid cable, the RG-AP9861-R can achieve long-distance data and power transmission over 1,100 meters indoors, delivering an indoor bandwidth of up to 10 Gbps. This AP enables flat network architecture and elastic upgrade, and simplifies deployment and cabling while reducing costs.
Self-Developed AI Radio Technology
Seamless Roaming
for Service Continuity
Al Radio enables real-time, full-band scanning to eliminate coverage holes caused by traditional timeframe-based, single-band scanning, ensuring a robust network. Security scanning does not consume radio resources for communication, ensuring superior network experience and security without compromising wireless performance.
Al Radio Safeguarding
Traditional AP Safeguarding
24/7 real-time scanning
Security scanning
Data transmission
Digital Twin Network,
Intelligent O&M functions are supported, including visualized fault locating, local network optimization, service network optimization, and VIP area network optimization. This greatly improves the O&M efficiency and experience for wireless networks.
Second-Level Detection
of Numerous APs
Network-Wide
Visualization
Network-Wide
Client Diagnosis
One-Click
Precise Optimization
Go to WIS Digital Twin Network->
ข้อมูลจำเพาะ
Radio Specifications
RG-AP9861-R
14 spatial streams
● Radio 1 – 2.4 GHz: 4x4 MIMO, four spatial streams
● Radio 2 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 3 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 5 – AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channel:
● Radio 1 – 2.4 GHz: 20 MHz and 40 MHz
● Radio 2 – 5 GHz: 20 MHz and 40 MHz
● Radio 3 – 5 GHz: 20 MHz and 40 MHz
● Radio 5 – AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
Combined peak data rate: 1.800 Gbps
Radio 1 – 2.4 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
Radio 2 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
Radio 3 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
Radio 5 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
10 spatial streams
● Radio 5 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channel:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 3 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 5 – AI Radio, 5GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 6.934 Gbps
Radio 2 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
Radio 3 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
Radio 5 – AI Radio, 5 GHz: AI Radio for scanning only
16 spatial streams
● Radio 1 – 2.4 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
● Radio 2 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
● Radio 3 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
● Radio 4 – 6 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channel:
● Radio 4 – 6 GHz: 20 MHz, 40 MHz, 80 MHz and 160 MHz
Combined peak data rate: 15.559Gbps
● Radio 1 – 2.4 GHz: 7.3 Mbps to 1.147 Gbps (MCS0 to MCS11)
● Radio 2 – 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
● Radio 3 – 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
● Radio 4 – 6 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
802.11be
16 spatial streams
Channel:
● Radio 4 – 6 GHz: 20 MHz, 40 MHz, 80 MHz, 160 MHz, and 320 MHz
Combined peak data rate: 24.436 Gbps
● Radio 1 – 2.4 GHz: 7.3 Mbps to 1.377 Gbps (MCS0 to MCS13)
● Radio 2 – 5 GHz: 7.3 Mbps to 5.765 Gbps (MCS0 to MCS13)
● Radio 3 – 5 GHz: 7.3 Mbps to 5.765 Gbps (MCS0 to MCS13)
● Radio 4 – 6 GHz: 7.3 Mbps to 11.529 Gbps (MCS0 to MCS13)
● 2.4 GHz: four built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
● 5 GHz: eight built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
● 6 GHz: four built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi
● One built-in omnidirectional antenna, with peak antenna gain of 3 dBi
1 x 100/1000/2.5G/5G/10GBASE-T port (10G/PoE IN port on the AP)
1 x 1000/2.5G/5G/10GBASE-T port (10G/WAN2 port on the AP), shared with one 10GE SFP+ port
1 x 10GE SFP+ port, compatibility with 1GE/2.5GE/10GE modules, shared with one 10GE RJ45 port (10G/WAN2 port on the AP)
1 x 10/100/1000BASE-T port
1 x USB 3.0 (Type-A connector)
1 x Bluetooth 5.3
GPS positioning
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 245 mm x 245 mm x 67 mm (9.65 in. x 9.65 in. x 2.64 in.)
Shipping: 485 mm x 346 mm x 340 mm (19.09 in. x 13.62 in. x 13.39 in.)
Main unit: 2.0 kg (4.41 lbs)
Shipping weight: 2.76 kg (6.08 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit)
Securing latch and Kensington lock
The AC supports the following two power supply modes:
● 54 V DC/1.25 A power input over DC connector: The DC connector accepts the center-positive circular plug with the inner diameter of 2.5 mm (0.10 in.) or outer diameter of 5.5 mm (0.22 in.) and the length of 9.5 mm (0.37 in.). A DC power supply needs to be purchased independently.
● PoE input over WAN 1: The power sourcing equipment (PSE) complies with IEEE 802.3at/bt standard (PoE+/PoE++)
● DC power: 60 W, Radio 1 (2.4 GHz) 4x4, Radio 2 (5 GHz) 4x4, Radio 3 (5 GHz) 4x4, Radio 4 (6 GHz) 4x4, Radio 5 (AI Radio) 2x2, LAN1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/5 W)
● 802.3bt (PoE++): 60 W, Radio 1 (2.4 GHz) 4x4, Radio 2 (5 GHz) 4x4, Radio 3 (5 GHz) 4x4, Radio 4 (6 GHz) 4x4, Radio 5 (AI Radio) 2x2, LAN1 for PoE power supply (48 V/12.95 W), USB port for external power supply (5 V/5 W)
● 802.3at (PoE+): 25 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 2x2, both Radio 4 and AI Radio disabled, LAN1 that can transmit data but does not support PoE power supply, USB port that fails to supply power to an external device
● Idle mode: 20 W
External power supply
● The USB port can source 5 V/5 W power to an attached device.
● The LAN 1 port can source 48 V/12.95 W power to an IoT unit.
SDRAM: 8 GB
NAND: 2 GB
SPI: 32 MB
● Maximum transmit power: 30 dBm (1000 mw)
● Minimum transmit power: 10 dBm (10 mw)
6 GHz
● Maximum transmit power : 30 dBm (1000 mw)
● Minimum transmit power : 10 dBm (10 mw)
Note: The transmit power adjusted in percentage. The transmit power is limited by local regulatory requirements. For details, see WLAN Country or Region Codes and Channel Compliance.
RG-AP9861-R
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
17 dBm
–58 dBm
24dBm
17dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
24 dBm
–57 dBm
24 dBm
–56 dBm
5 GHz, 802.11ac (VHT160)
24 dBm
24 dBm
17 dBm
–58dBm
24 dBm
–82dBm
17 dBm
–54dBm
24 dBm
–56 dBm
17 dBm
–52dBm
5 GHz, 802.11ax (HE160)
24 dBm
17 dBm
–50 dBm
5 GHz, 802.11be (EHT80)
24 dBm
–56 dBm
17 dBm
–52 dBm
MCS13
15 dBm
–46 dBm
5 GHz, 802.11be (EHT160)
24 dBm
17 dBm
–50 dBm
MCS13
15 dBm
–44 dBm
6 GHz, 802.11ax (HE20)
24 dBm
17 dBm
–58dBm
6 GHz, 802.11ax (HE40)
24 dBm
–82dBm
17 dBm
–54dBm
6 GHz, 802.11ax (HE80)
24 dBm
–56 dBm
17 dBm
–52 dBm
MCS13
15 dBm
–46 dBm
6 GHz, 802.11ax (HE160)
24 dBm
17 dBm
–50 dBm
MCS13
15 dBm
–44 dBm
6 GHz, 802.11be (EHT20)
24 dBm
17 dBm
–58dBm
6 GHz, 802.11be (EHT40)
24 dBm
–82dBm
17 dBm
–54dBm
6 GHz, 802.11be (EHT80)
24 dBm
–56 dBm
17 dBm
–52 dBm
MCS13
15 dBm
–46 dBm
6 GHz, 802.11be (EHT160)
24 dBm
17 dBm
–50 dBm
MCS13
15 dBm
–44 dBm
6 GHz, 802.11be (EHT320)
24 dBm
–51 dBm
17 dBm
–50 dBm
MCS13
15 dBm
–44 dBm
Software Specification
Basic Functions
RG-AP9861-R
RGOS11.9(6)W3B17 or later
2,048 (up to 512 STAs per radio)
64 (up to 16 BSSIDs per radio)
Maximum number of WLAN IDs
STA management
Intelligent load balancing based on the STA quantity or traffic
Application management
Remote Authentication Dial-In User Service (RADIUS)
EXEC authorization, specifying source IP addresses of RADIUS packets, supporting authentication of other vendors, and built-in authentication server
QR code-based guest authentication, SMS-based authentication, and MAC address bypass (MAB) authentication
Dynamic Policy
IP standard ACL, MAC extended ACL, IP extended ACL, and expert-level ACL
MAC address table size: 4,096
Jumbo frame length: 1,518
IEEE 802.1p and IEEE 802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
IPv6 SAVI
IPv4/ IPv6 static route
NTP server and NTP client
Fault detection and alarming
Fat/Fit/Cloud mode switchover
RG-AP9861-R
SMS-based authentication, built-in account authentication, one-click authentication, Facebook authentication, Instagram authentication, Voucher authentication, and other authentication modes
Authentication implemented on the cloud, eliminating the need to deploy the local authentication server
Big data capabilities
RG-AP9861-R
EN 301 489-3
EN 301 489-17
EN 301 489-19
EN 300 328
EN 303 413
EN 303 687
FCC Part 15
EN IEC 62311
EN 62368-1
EN 18031-1
EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9861-R] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9861-R] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
แหล่งข้อมูล
ข้อมูลการสั่งซื้อ
RG-AP9861-R
Wi-Fi 7 flagship high-density indoor access point
Five radios, 18 spatial streams, peak data rate of 24.436 Gbps
● Radio 1 – 2.4 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 1.377 Gbps
● Radio 2 – 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 5.765 Gbps
● Radio 3 – 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 5.765 Gbps
● Radio 4 – 6 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 11.529 Gbps
● Radio 5 – AI Radio, 2.4 GHz/5 GHz: two spatial streams, 2x2 MIMO, AI Radio for scanning only
Consuming one AC license per device
Fat/Fit/Cloud mode switching
802.3at/bt-compliant PoE and DC power supply
● The power sourcing equipment (PSE) needs to be purchased separately.
● The DC power supply needs to be purchased separately, and the output voltage/current must be 54 V/1.25 A.
SFP BIDI Transceiver-TX1550/RX1310,20km,LC
2.5G-SFP-LX03-SM1550-BIDI
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
