RG-AP9520-RDX ไร้สาย - 1
RG-AP9520-RDX ไร้สาย - 2
RG-AP9520-RDX ไร้สาย - 3
RG-AP9520-RDX ไร้สาย - 4
RG-AP9520-RDX ไร้สาย - 5
RG-AP9520-RDX ไร้สาย - 6
RG-AP9520-RDX, Wi-Fi 7 Tri-Radio 6.453 Gbps AR Series High-Density Indoor Access Point
Designed for high-density indoor wireless deployments in education, government, enterprise, and other industries.
  • Multi-mode beam-optimized antenna design for flexible coverage and interference mitigation
  • Intelligent client steering and AP load balancing for efficient resource utilization
  • Dynamic multi-frame concurrency for lower latency
  • Intelligent beamforming for targeted signal enhancement and improved edge client experience
  • WIS digital twin network for superior network O&M efficiency
ข้อมูลจำเพาะที่สำคัญ
ฟีเจอร์
RG-AP9520-RDX Wi-Fi 7 AR Series High-Density Indoor Access Point
Featuring an innovative multi-mode beam-optimized antenna design, the RG-AP9520-RDX provides flexible coverage control. It supports Wi-Fi 7 and integrates multiple wireless technologies to enhance network performance and client access experience in high-density environments.
Multi-Mode Beam-Optimized Antenna Design for Flexible Coverage and Interference Mitigation
75° Coverage
45° Coverage
20° Coverage
The built-in 75° beam antenna reduces overlapping coverage and minimizes co-channel interference between APs. It is recommended for indoor deployments with a mounting height of less than 5 meters.
Intelligent Client Steering and AP Load Balancing for Efficient Resource Utilization
The built-in dedicated AI Radio continuously scans the entire RF spectrum in real time, creating a comprehensive view of the RF environment and connected clients across the network. It intelligently steers clients to better-performing APs when needed, helping prevent sticky clients, balance AP loads, and improve network stability.
Dynamic Multi-Frame Concurrency for Lower Latency
The dynamic multi-frame concurrency technology enables the RG-AP9520-RDX to transmit data to multiple clients within a single transmission opportunity, ensuring that data reaches clients in a timely manner. This improves transmission efficiency and reduces application latency in environments with large numbers of connected clients and high traffic concurrency.
Intelligent Beamforming for Targeted Signal Enhancement and Improved Edge Client Experience
Unlike conventional Transmit Beamforming (TxBF), which is applied uniformly across clients, the RG-AP9520-RDX dynamically identifies edge clients with poor signal quality based on traffic volume, data rate, and signal strength, and selectively enhances their signals. This improves performance for clients at the edge of the coverage area.
WIS integrates intelligent O&M functions, including visualized fault locating, along with local, service and key area network optimization. These capabilities aim to improve operational efficiency and enhance the user experience for wireless networks.
Go to WIS >
ข้อมูลจำเพาะ
RG-AP9520-RDX
Eight spatial streams
● Radio 2 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 3 – AI Radio – 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – AI Radio – 5 GHz: 20 MHz and 40 MHz
● Radio 2 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
● Radio 3 – AI Radio – 5 GHz: AI Radio used for scanning only
Six spatial streams
Channels:
Combined peak data rate: 3.467 Gbps
● Radio 2 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
Radio technologies: OFDM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● Radio 2 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
● Radio 3 – AI Radio – 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – AI Radio – 2.4 GHz/5 GHz: 20 MHz, 40 MHz, and 80 MHz
● Radio 1 – 2.4 GHz: 7.3 Mbps to 574 Mbps (MCS0 to MCS11)
● Radio 2 – 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
● Radio 3 – AI Radio – 2.4 GHz/5 GHz: AI Radio used for scanning only
Radio technologies: Uplink/Downlink Orthogonal Frequency-Division Multiple Access (OFDMA)
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
802.11be
Six spatial streams
Channels:
Combined peak data rate: 6.453 Gbps
● Radio 1 – 2.4 GHz: 7.3 Mbps to 688 Mbps (MCS0 to MCS13)
● Radio 2 – 5 GHz: 7.3 Mbps to 5.765 Gbps (MCS0 to MCS13)
Radio technologies: Uplink/Downlink OFDMA
Modulation types: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
● A-MPDU
● A-MSDU
DFS
CDD/CSD
MRC
STBC
LDPC
TxBF
● 2.4 GHz: Two built-in smart antennas, with the peak antenna gain of 7.3 dBi
● 5 GHz: Four built-in smart antennas, with multi-mode switching. For mode 1, the peak gain is 8.2 dBi; for mode 2, the peak gain is 11.6 dBi. They can be switched to external antennas.
● One built-in antenna, with the peak antenna gain of 3.6 dBi
1 x 100/1000/2.5G/5GBASE-T port, supporting IEEE 802.3af/at PoE power supply, multiplexed with the 10GE SFP+ port
1 x 10GE SFP+ port, compatible with 10G/2.5G/1G optical transceivers, multiplexed with the 5GE RJ45 port
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.3
1 x system status LED
● Uplink service port status
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Press the button for less than 2 seconds. Then the device restarts.
Main unit: 220 mm x 220 mm x 42.7 mm (8.66 in. x 8.66 in. x 1.68 in.)
Shipping: 237 mm x 227 mm x 71 mm (9.33 in. x 8.94 in. x 2.8 in.)
Main unit: 1.1 kg (2.43 lbs)
Mounting bracket: 0.05 kg (0.11 lbs)
Shipping: 1.35 kg (2.98 lbs)
Ceiling: The mounting bracket delivered with the device is used.
Wall-mount: A mounting bracket is required separately.
● 54 V DC/0.56 A power input over the DC connector
● PoE/PoE+ input, in compliance with 802.3af/at
If both DC power and PoE are available, DC power is preferred.
Maximum power consumption: 25 W
● DC power: 30 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 4x4, Radio 3 (AI Radio) 2x2, USB for external power supply (5 V/0.5 A)
● 802.3at (PoE+): 30 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 4x4, Radio 3 (AI Radio) 2x2, USB for external power supply (5 V/0.5 A)
● 802.3af (PoE): 15.4 W, Radio 1 (2.4 GHz) 2x2
Radio 2 (5 GHz), Radio 3 (AI Radio), and the USB port are disabled.
250,000 hours (28 years) at the operating temperature of 25°C (77°F)
1 GB DRAM, 256 MB flash
● Maximum transmit power (802.3at): 26 dBm (23 dBm per chain)
● Minimum transmit power (802.3af): 19 dBm (16 dBm per chain)
● Maximum transmit power (802.3at): 28 dBm (22 dBm per chain)
● Minimum transmit power (802.3af): 22 dBm (16 dBm per chain)
● You can adjust the transmit power by percentage (recommended) or in 1 dBm increments.
● The transmit power is limited by local regulatory requirements.
The following table lists the radio frequency performance of Wi-Fi including different frequency bands, protocols, and data rates. It is country-specific, and Ruijie Networks reserves the right of interpretation.
Wi-Fi Radio Performance
RG-AP9520-RDX
Maximum EIRP
2.4 GHz 802.11g
2.4 GHz 802.11g
19 dBm
2.4 GHz 802.11g
19 dBm
2.4 GHz 802.11g
–74 dBm
2.4 GHz 802.11n (HT20)
–70 dBm
2.4 GHz 802.11n (HT40)
–67 dBm
2.4 GHz 802.11ax (HE20)
–58 dBm
2.4 GHz 802.11ax (HE40)
–55 dBm
2.4 GHz 802.11be (EHT20)
MCS13
–52 dBm
2.4 GHz 802.11be (EHT40)
MCS13
–49 dBm
5 GHz 802.11a
22 dBm
5 GHz 802.11a
22 dBm
5 GHz 802.11a
22 dBm
5 GHz 802.11a
–74 dBm
5 GHz 802.11n (HT20)
22 dBm
19dBm
–70 dBm
5 GHz 802.11n (HT40)
22 dBm
19 dBm
–64 dBm
5 GHz 802.11ac (VHT20)
22 dBm
–65 dBm
5 GHz 802.11ac (VHT40)
22 dBm
5 GHz 802.11ac (VHT80)
22 dBm
–56 dBm
5 GHz 802.11ax (HE20)
22 dBm
–88 dBm
17 dBm
–58 dBm
5 GHz 802.11ax (HE40)
22 dBm
17 dBm
5 GHz 802.11ax (HE80)
22 dBm
–56 dBm
17 dBm
–52 dBm
5 GHz 802.11ax (HE160)
22 dBm
–55 dBm
17 dBm
–50 dBm
5 GHz 802.11be (EHT80)
22 dBm
–56 dBm
17 dBm
–52 dBm
MCS13
–46 dBm
5 GHz 802.11be (EHT160)
22 dBm
17 dBm
–50 dBm
MCS13
–43 dBm
Basic Functions
RG-AP9520-RDX
RGOS11.9(6)W5 or later
768 (256 STAs for Radio 1 and 512 STAs for Radio 2)
Recommended number of STAs
Maximum number of WLAN IDs
STA limit for each WLAN: 256 STAs for Radio 1 and 512 STAs for Radio 2
Intelligent client identification (used with the AC)
Control And Provisioning of Wireless Access Points (CAPWAP)
CAPWAP through Network Address Translation (NAT)
Mobile unit (MU) locating
PSK, web-based, 802.1X, WPA, WPA2, and WPA3 authentication
WeChat-based authentication, QR code-based guest authentication, SMS-based authentication, and MAB
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), and WPA3
Dynamic policy
IP standard access control list (ACL), MAC extended ACL, IP extended ACL, expert ACL, and IPv6 ACL
CPU Protection Policy (CPP)
MAC address table size: 1,024
Maximum frame length: 1,518
IEEE 802.1p and IEEE 802.1Q
VLAN group (dynamic VLAN assignment based on the MAC address or 802.1X key)
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
IPv6 SAVI
NTP server and NTP client
Fault detection and alarms
Web management (eWeb)
The following value-added software functions can be achieved when the RG-AP9520-RDX is used with RG-WIS and the AC.
RG-AP9520-RDX
Network operation analysis such as device stability and signal coverage
Measuring user network experience based on indicators including latency, packet loss, RSSI, and channel utilization, with visualized network experience results
Statistics on the number of online and offline failures of STAs associated with different APs, average RSSI, and other parameters
Note: These functions are supported only when the RG-AP9520-RDX works in Fit mode.
Network performance optimization, including one-click network optimization and optimization solution setting based on different scenarios
Sticky client roam steering and experience indicator comparison
Remote association steering and experience indicator comparison
One-click diagnosis for analyzing problems and providing suggestions
Baseline analysis, recording changes in configuration, software version, and other parameters, and tracking changes in network KPIs
Time capsule for analyzing the history of device version and configuration changes
Cloud site survey
Batch generation of building floor information, floor plan upload, and drag-and-drop AP placement
One-click health check report and generation of reports on the overall network operating status
Unauthorized Wi-Fi signal locating and classified display, as well as containment capabilities
Uniformly connecting, managing, and maintaining APs, ACs, and other devices
Batch device configuration and upgrade
ZTP deployment, creating configuration templates, and automatically applying configured templates
Discovering wired and wireless network topology with one click and generating the topology
Portal authentication page
Customizing Portal authentication pages for PCs and mobile phones
Interworking with Guodu and Alibaba Cloud SMS gateways
Big data capabilities
Data warehouse building based on Hive, data model conversion, and integration
Hierarchical and role-based access control
Administrators at different sites have different operation permissions.
System management functions including account operations, authorization configuration, email configuration, configuration backup, and exception alarms
Note: For details, refer to the latest hybrid cloud management solution of Ruijie Networks.
RG-AP9520-RDX
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, ETSI EN 303 687, EN IEC 62311, IEC 62368-1, and EN 62368-1
● EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9520-RDX] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at https://www.ruijie.com/.
● UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9520-RDX] is in compliance with UK Radio Equipment Regulations 2017. The full text of the UK declaration of conformity is available at https://www.ruijie.com/.
● The functions of Wireless Access Systems (WASs) including Radio Local Area Networks (RLANs) within the band 5,150–5,350 MHz for this device are restricted to indoor use only within European Union countries and other relevant European regions (BE/BG/CZ/DK/DE/EE/IE/EL/ES/FR/HR/IT/CY/LV/LT/LU/HU/MT/NL/AT/PL/PT/RO/SI/SK/FI/SE/TR/NO/CH/IS/LI/UK(NI)).
● Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
แหล่งข้อมูล
ข้อมูลการสั่งซื้อ
Mandatory/Optional
RG-AP9520-RDX
It is the Wi-Fi 7 (802.11be) tri-radio indoor access point and AI Radio series. It applies to Ruijie SOE solution.
It supports up to eight spatial streams and delivers a combined peak data rate of 6.453 Gbps.
It complies with 802.11a/b/g/n/ac/ax/be, and supports switchover among Fat, Fit, and cloud modes.
It provides 802.3af/at-compliant (PoE/PoE+) and DC power supply.
It occupies one AC license.
Mandatory
RG-ANTx2-5000D-PS
It is the indoor directional antenna with antenna with high side-lobe suppression. It is designed for indoor high-density deployments, with accurate coverage and strong anti-interference. It can work at the frequency band of 5,150 MHz to 5,850 MHz, with the peak gain of 16.5 dBi. It is suitable for  indoor deployments at heights of 12 m to 30 m (39.37 ft. to 98.43 ft.). It is used with the RG-AP9520-RDX, and the separately purchased laser pointer is required for positioning.
Optional
Single-core 1GE optical transceiver
Optional
2.5G-SFP-LX03-SM1550-BIDI
Single-core 2.5GE optical transceiver
Optional
Single-core 10GE optical transceiver
Optional
Dual-core 10GE optical transceiver
Optional
Note: Only some supported optical transceiver models are displayed here. For more information, contact Ruijie pre-sales engineers.
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
