RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 1
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 2
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 3
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 4
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 5
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 6
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 7
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 8
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 9
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 10
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 11
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 12
RG-CS85-48GT4XS-HPD Сети малого и среднего бизнеса - 13
Hot-Swappable Power Modules
Abundant Multicast Protocols
Flexible management modes
Характеристики
RG-CS85-24GT8XS-D
RG-CS85-24SFP/8GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
8 x 1GE/10GE SFP+ ports
24 x 1GE SFP ports
48 x 1GE SFP ports
CM85-4XS2CQ
M2SFAN I-F (pre-installed 2)
Module service port
CM85-4XS2CQ:
● 4 x 1GE/10GE SFP+ ports
● 2 x 40GE/100GE QSFP28 ports
1 x USB 3.0 port
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Flash Memory
4 GB
1 GB
1 GB
1 GB
2 GB
Switch buffer
4 MB
14,000
Ingress: 7,000
Egress:1,500
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
Unit dimensions
440 mm x 340 mm x 44 mm
593 mm x 497 mm x 192 mm
563 mm x 563 x mm 210 mm
4.4 kg
(9.70 lbs)
4.3 kg
(9.48 lbs)
4.5 kg
(9.92 lbs)
5.3 kg
(11.68 lbs)
5.7 kg
(12.57 lbs)
6.20 kg
(13.67 lbs)
6.62 kg
(14.59 lbs)
6.30 kg
(13.89 lbs)
7.70 kg
(16.98 lbs)
7.80 kg
(17.20 lbs)
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
1+1 power redundancy
RG-CS85-48GT4XS-HPD
● Maximum input current: 10 A
120 W (without PoE)
1,600 W (full PoE load)
● 2 x RG-PA600I-P-F: 740 W
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
3 x fixed fan modules
45°C (113°F): 56.2 dB
45°C (113°F): 57.9 dB
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85 Series
Super VLAN, Private VLAN
Flexible QinQ
SPAN, RSPAN, and ERSPAN
Ресурсы
Информация о заказе
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
CM85-4XS2CQ
Часто задаваемые вопросы
