TL;DR: Cloud-managed WLAN centralizes visibility and routine administration across sites, while controller-based WLAN places defined coordination and authentication functions on local hardware; many SMEs should compare a hybrid cloud-edge design rather than treat the two as mutually exclusive.
Cloud-managed and controller-based WLAN deployments differ mainly in where administrators manage the system and where time-sensitive wireless decisions are executed. A cloud-managed design gives authorized teams a shared service for supported configuration, monitoring, alerts, and troubleshooting across locations. A controller-based design uses an on-site or locally hosted controller for functions assigned to that controller, such as access-point coordination, authentication, roaming, or forwarding.
The labels do not fully describe traffic flow or failure behavior. “Cloud-managed” does not automatically mean that user traffic crosses the cloud, and “controller-based” does not guarantee that every service survives a WAN outage. Some products combine cloud visibility with a local controller. The right choice depends on the exact management plane, control plane, forwarding path, authentication path, outage behavior, site scale, licensing, and support boundary.
Table: Cloud-managed vs controller-based WLAN — decision areas for SMEs
| Decision area |
Cloud-managed WLAN |
Controller-based WLAN |
What an SME should verify |
| Management plane |
A cloud service commonly provides supported inventory, configuration, monitoring, and alerts across sites |
A local controller or management system commonly provides administration for its managed access points |
Which functions are available from the cloud, locally, and during loss of cloud reachability |
| Control plane |
Control may be distributed among access points, a cloud service, an edge device, or a combination |
Defined control functions are handled by the local controller, although cloud services may still add visibility or planning |
The exact location of radio, roaming, policy, and client-control decisions |
| Data forwarding |
User traffic may remain local, but the path depends on product mode and enabled services |
Traffic may be locally forwarded or centrally forwarded through the controller |
The forwarding mode for each SSID and the effect on performance and resilience |
| WAN outage |
Cloud administration and remote visibility may be reduced; local service behavior is product-specific |
Local functions may continue if the controller and required dependencies remain available |
Local traffic, new authentication, roaming, logging, policy, and recovery behavior under test |
| Authentication |
May use cloud identity, local services, external identity systems, or cached methods |
May use a controller-hosted service or external identity systems |
Dependency on internet, DNS, certificates, directories, RADIUS, portals, and licenses |
| Multi-site operations |
Often favors repeatable onboarding and a single view across branches |
Often favors strong local control at a site; multi-site operation depends on the controller architecture |
Site limits, role delegation, templates, change control, data location, and tenant separation |
| Scaling boundary |
Governed by the service, supported devices, account structure, and commercial tier |
Governed by controller capacity, redundancy design, software, and license limits |
Supported APs and clients, high-availability design, growth headroom, and upgrade path |
| Ownership |
The provider operates the management service; the customer still owns design and site operations |
The customer or partner operates more local infrastructure |
Monitoring, backup, patching, escalation, replacement, and service-exit responsibilities |
The management plane is where administrators view inventory, change supported settings, receive alerts, and investigate health. The control plane is where the WLAN makes operational decisions about radios, clients, roaming, policy, and related behavior. The forwarding plane, also called the data plane, carries user traffic over the path selected by the design. Control functions decide how clients, policy, and paths should be handled; the forwarding plane then moves packets according to those decisions. A cloud dashboard can manage a system without carrying user traffic or making every real-time decision. A local controller can make on-site decisions while still reporting to a cloud service.
In a controller-based WLAN, forwarding can be local at the access point or centralized through the controller. Both cited RG-CNC product pages list local and centralized forwarding as available modes.[2][3] These are product-specific options, so the selected mode should be confirmed for each SSID, model, release, and deployment.
This distinction matters for professional network infrastructure for multi-site SMEs. A single cloud view may reduce repetitive administration across branches, but each site still needs a documented local architecture. The design should show which component owns configuration, which component makes control decisions, where traffic is forwarded, and which functions rely on internet connectivity.
Ruijie Cybrey’s public RG-CNC105 page describes a cloud-edge collaborative wireless network in which cloud tools provide visibility and planning, the RG-CNC controller makes local decisions, and access points enforce actions on site.[2] That is a product-specific hybrid architecture, not a rule for every cloud-managed WLAN.
A WAN outage can remove access to a cloud console without necessarily stopping local Wi-Fi traffic. It can also disrupt cloud identity, remote DNS, captive portals, license checks, or other dependencies even when radios remain active. The phrase “offline operation” is therefore too broad for procurement.
For a cloud-edge managed WLAN for business continuity, the acceptance test should separate at least six outcomes: existing local traffic, new client association, new authentication, roaming, local administration, and event synchronization after recovery. Record which results are expected, how long cached or local services remain valid, and which logs are retained.
Cybrey’s wireless portfolio page states that its access controller, when used with Cybrey access points, supports roaming and resilience to WAN outages.[1] The public RG-CNC105 and RG-CNC312 pages say that local authentication and roaming can continue if internet connectivity is interrupted.[2][3] Buyers should still confirm the selected model, software release, authentication method, deployment mode, and regional availability, then reproduce the outage test before approval.
A request for business WiFi with seamless roaming and centralized control combines several requirements. “Centralized control” can refer to policy administration, access-point coordination, authentication, or all three. “Seamless roaming” also needs measurable acceptance criteria, such as the target applications, client types, roaming path, and tolerated interruption.
The Cybrey wireless portfolio page describes the controller as providing multi-vendor management and network authentication, while Cybrey access points support its roaming design.[1] The RG-CNC product pages describe a built-in portal and 802.1X authentication service, external authentication integrations, access-point load balancing, and coordinated client steering.[2][3] These are controller-family statements. They should not be extended to every access point, cloud tier, identity method, or deployment without current product documentation.
If the requirement is an enterprise WiFi controller with local authentication failover, the procurement team should map the phrase to an exact design. Specify the identity source, local authentication behavior, certificate and time dependencies, user groups, portal behavior, and what happens to a new client during WAN loss. A laboratory test should cover both successful and failed authentication, not only connectivity for clients that were already online.
Cloud management can be attractive when a small IT team or service partner operates many branches. Shared templates, inventory, health views, and remote troubleshooting can reduce travel and make changes more consistent. A local controller can be attractive where on-site coordination, local authentication, or a defined forwarding architecture is required. A hybrid design can combine these goals.
Neither model removes capacity planning. Buyers need documented limits for access points, clients, controllers, sites, administrators, logs, and integrations. They should also distinguish a technical maximum from a recommended design limit. Redundancy is another separate decision: adding a controller does not create high availability unless the selected architecture, licensing, topology, and operating procedure support it.
The cited product pages publish the following technical ceilings. They are not recommended design limits. A production design should reserve headroom and use current datasheets, software release notes, licensing terms, and pilot results.[2][3]
Table: Published controller capacity ceilings on the cited pages
| Published metric |
RG-CNC105 |
RG-CNC312 |
| Managed clients per AC |
500 |
3,500 |
| Configurable APs |
256 |
2,048 |
| Connected APs |
64 |
1,024 |
| Managed online APs |
32 |
512 |
| 802.1X-authenticated clients |
64 |
1,300 |
| Portal-authenticated clients |
64 |
1,300 |
| Managed CAPWAP tunnels |
64 |
1,024 |
| Third-party devices |
16 |
128 |
Among these two cited pages, the RG-CNC312 page lists VAC, N:M multi-AC hot standby, and RIPT for VAC services; the RG-CNC105 page does not list those items. This is a model-specific example of why redundancy must be verified rather than inferred from the presence of a controller.[2][3]
Operational ownership should be explicit. The supplier, integrator, and customer should agree who monitors the WLAN, approves configuration changes, maintains local controllers, manages cloud accounts, renews entitlements, backs up configuration, restores service, and handles device reassignment or service exit.
Choose the architecture by testing requirements, not by selecting a label.
1.Draw the planes and paths. Mark management, control, authentication, and data-forwarding paths for each SSID.
2.List external dependencies. Include internet access, DNS, time, certificates, identity systems, portals, APIs, and licensing services.
3.Define outage behavior. State what must continue during loss of WAN, cloud service, controller, or identity connectivity.
4.Model site growth. Compare current and projected access points, clients, branches, administrators, and log volume.
5.Check operational fit. Decide whether the team can maintain local controllers and whether remote multi-site workflows are sufficiently repeatable.
6.Compare full lifecycle cost. Include hardware, licenses, subscriptions, support, upgrades, redundancy, partner labor, training, and service exit.
7.Run a pilot. Test normal operation, roaming, authentication, WAN loss, recovery, configuration rollback, backup, export, and alert delivery.
A cloud-managed design is usually the better operational fit when centralized multi-site administration is the leading requirement and the documented local behavior meets the outage plan. A controller-based design is usually the better fit when specified local control, authentication, or forwarding functions are essential. A cloud-edge design may be the strongest candidate when the business needs both shared visibility and defined local execution.
Ask the supplier or integrator to answer these questions in writing:
1.Which functions belong to the cloud, controller, access point, or external service?
2.Does user traffic stay local, and is the answer different by SSID or forwarding mode?
3.What happens to existing and new clients when WAN or cloud reachability is lost?
4.Which authentication methods continue locally, for how long, and with what dependencies?
5.Which model, software version, commercial tier, and license enables each required function?
6.What are the supported and recommended limits for sites, access points, clients, and administrators?
7.Is controller or management redundancy supported, and how is failover tested?
8.Which logs remain local, which are uploaded, and what is retained during an outage?
9.Can configurations, logs, and inventory be exported during normal operation and service exit?
10.Which party owns monitoring, updates, backup, account recovery, escalation, and replacement?
Does cloud-managed WLAN send all Wi-Fi traffic through the cloud?
Not necessarily. Cloud management describes an administrative relationship, not a universal forwarding path. User traffic may remain local, pass through a controller, or use a cloud-delivered function depending on the product mode and enabled services. Confirm the path for each SSID.
Can a cloud-managed WLAN keep working without internet access?
It may keep some local functions, but the result is product- and design-specific. Test existing traffic, new client association, authentication, roaming, policy, logging, and post-outage synchronization separately. Do not accept “offline capable” without a written test matrix.
Is a controller required for every SME WLAN?
No. Some architectures distribute control among access points and a cloud service. Others use a local controller for defined coordination, authentication, or forwarding functions. The requirement should come from site scale, applications, resilience, identity, and operational needs.
Can an SME use cloud management and a local controller together?
Yes, if the selected product architecture supports both. The Cybrey RG-CNC pages describe a cloud-edge model that combines cloud visibility and planning with local controller decisions and on-site access-point execution.[2][3] Verify exact model, release, license, and regional support before designing around that behavior.
Is controller-based WLAN more expensive than cloud-managed?
Not inherently. A controller-based design can add hardware, redundancy, maintenance, and upgrade work, while a cloud-managed design can add recurring subscriptions and service dependencies. Compare full lifecycle cost for the required scale, support level, resilience, licensing, partner labor, and exit plan rather than assuming one label is cheaper.
Which is better for an SME with no in-house IT?
A cloud-managed service may simplify remote administration, but it does not remove responsibility for design, security, identity, cabling, incident response, or outage planning. An SME without in-house IT should compare qualified service partners, support response, account ownership, local fallback behavior, and service-exit procedures before choosing either architecture.
Evidence scope and limitations
The architecture comparison is general guidance. Product-specific statements in this article rely on first-party public pages verified on 2026-11-17; those pages do not independently validate the supplier’s claims. Before purchase, the procurement team should confirm current datasheets, software release, license tier, regional availability, and pilot results, then reproduce critical behavior through independent testing.
[1] https://www.ruijie.com/en-global/cybrey/cybrey-wireless/ — Official Ruijie Cybrey wireless portfolio page; rendered-visible text verified 2026-11-17.
[2] https://www.ruijie.com/en-global/products/wireless/cybrey-wireless/rg-cnc105 — Official RG-CNC105 product page; rendered-visible text verified 2026-11-17.
[3] https://www.ruijie.com/en-global/products/wireless/cybrey-wireless/rg-cnc312 — Official RG-CNC312 product page; rendered-visible text verified 2026-11-17.
