RG-S6930-2C Sieci w centrach danych - 1
RG-S6930-2C Sieci w centrach danych - 2
RG-S6930-2C Sieci w centrach danych - 3
RG-S6930-2C Sieci w centrach danych - 4
RG-S6930-2C Sieci w centrach danych - 5
RG-S6930-2C Sieci w centrach danych - 6
RG-S6930-2C Sieci w centrach danych - 7
RG-S6930-2C Sieci w centrach danych - 8
RG-S6930-2C Sieci w centrach danych - 9
RG-S6930-2C Sieci w centrach danych - 10
RG-S6930-2C – Next-Generation Data Center High-Density Centralized Modular Core Switch with 100GE/200GE Line Cards
Centralized modular core switch with large buffer and high-density ports in the 4-RU space, which is recommended for the data center gateway zone, MAN, and DCI
  • 100GE and 200GE line cards, and up to 144 x 100GE or 72 x 200GE ports
  • Straight front-to-rear airflow design, enhancing the cooling efficiency
Parametry Kluczowe
Charakterystyka
Data Center 100GE/200GE DCI Core Switch RG-S6930-2C
Data center high-density core switch that supports 100GE/200GE line cards and provides 144 x 100GE or 72 x 200GE ports, which can be flexibly configured
Buffer of 16 GB and millions of routing connections due to its high performance, adapting to future expansion requirements on a data center network
Hardware-level Redundancy,
Ensuring Nonstop Services and Data Center Network Stability
With MACsec, the switch achieves interface-based secure line-rate transmission, effectively preventing data from being intercepted and obtained maliciously and
ensuring service data security.
Specyfikacje
RG-S6930-2C
Dimensions (W × D × H)
4 RU
23.4 kg (51.59 lbs., empty chassis)
33.6 kg (74.08 lbs., a chassis with four power modules and eight fan modules)
28.8 Tbps
5400 Mpps
Management port
2 x expansion module slots
4 x power module slots
8 x fan module slots
Maximum power consumption: 2934 W
Typical power consumption: 1338 W
Static power consumption: 600 W
RG-PA1600II-F (AC input):
Rated input current: 12 A (100 V to 127 V AC)
9.5 A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1600II-F (HVDC input):
Rated input voltage: 240 V DC
Rated input current: 9.5 A
Software Specification
RG-S6930-2C
802.1Q VLAN
4094
Layer 2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (basic QinQ and *selective QinQ), and GVRP
Layer 3 Protocols
(IPv4)
BGP4, OSPFv2, IS-IS, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Routing Policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, and Any-RP
Basic IPv6 Protocols
Neighbor Discovery, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, and IPv6 QoS
IPv6 Features
Static routing, ECMP, PBR, BGP4+, OSPFv3, IS-ISv6, RIPng, MLDv1/v2, PIM-SMv6, manual tunnel, *automatic tunnel, IPv4 over IPv6 tunnel, and * ISATAP tunnel
Visualization
sFlow and IPFIX sampling
802.1p, DSCP, and ToS priority mapping
Queue scheduling mechanisms, including SP, WFQ, and SP+WFQ
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching, RLDP unidirectional link detection, 2+2 power redundancy, fan redundancy, and hot swapping for all line cards and power supply modules
Security Features
MACSec, Network foundation protection policy (NFPP), CPU Protection Policy (CPP), DDoS attack defense, unauthorized data packet detection, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 authentication for OSPF, RIPv2, and BGPv4 packets, uRPF, broadcast packet suppression, Telnet login and password mechanisms for restricted IP addresses
Management Modes
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, and SPAN/RSPAN/ERSPAN
Other Protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, ARP Proxy, and Syslog
Zasoby
Informacje o zamawianiu
Chassis and Supervisor Engine
RG-S6930-2C
RG-S6930-2C chassis equipped with four RG-PA1600II-F power supply modules and eight M2EFAN II-F fan modules
Two expansion slots, four power supply module slots, and eight fan module slots
Power Supply Modules
RG-PA1600II-F
1600 W power supply module (AC and 240 V HVDC)
Fan Modules
M2EFAN II-F
Fan module (port-side intake)
Line Cards
M6900-72CQ-CES
72 x 100GE QSFP28 ports
40GE Optical Transceivers
40G LR4 optical transceiver, QSFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
40G LSR optical transceiver, QSFP+ form factor, MPO, 400 m (1,312.34 ft.) over MMF
40G SR optical transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over MMF
40G LX4 optical transceiver, QSFP+ form factor, Duplex LC connector, 150 m (492.13 ft.) over OM3/OM4 MMF, or 2 km (6,561.68 ft.) over SMF
100GE Optical Transceivers
100G SR optical transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF
100G ER4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 40 km (131,233.59 ft.) over SMF
200GE Series Optical Transceivers
200G-Q56-SR4-MM850
200G SR4 optical transceiver, QSFP56 form factor, MPO-12 connector, 100 m (328.08 ft.) over OM4 MMF
For more information about optical transceiver compatibility, refer to Ruijie RG-S6930 Series Data Center Switches Optical Transceiver Compatibility Matrix.
