| Item |
RG-S6250-48XS8CQ |
| Dimensions (W x D x H) |
442 mm x 387 mm x 44 mm (17.40 in. x 15.24 in. x 1.73 in.) |
| Rack height |
1 RU |
| Unit weight |
5.6 kg (12.35 lbs., empty chassis) 8.2 kg (18.08 lbs., a chassis installed with two power modules and four fan modules) |
| Switching capacity |
2.56 Tbps |
| Packet forwarding rate |
1920 Mpps |
| Service port |
48 x 1G/10G SFP+ ports 8 x 40G/100G QSFP28 ports |
| Management port |
1 x RJ45 console port 1 x RJ45 MGMT port |
| USB port |
1 x USB 2.0 port (Type A connector) |
| Module slot |
2 x power module slots 4 x fan module slots |
| Power consumption |
Maximum power consumption: 300 W Typical power consumption: 165 W Static power consumption: 98 W |
| Power input |
RG-PA550I-F (AC input): Rated input voltage: 100 V AC to 240 V AC, 50 Hz/60 Hz Maximum input voltage: 90 V AC to 140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 7.2 A to 3.5 A (100 V AC to 240 V AC) Power port type: C14
RG-PA550I-F (HVDC input): Rated input voltage: 240 V DC Maximum input voltage: 180 V DC to 310 V DC Rated current: 3.6 A Power port type: C14
RG-PHD550I-F (AC input): Rated input voltage: 100 V AC to 240 V AC, 50 Hz/60 Hz Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 10 A Power port type: C14
RG-PHD550I-F (HVDC input): Rated input voltage: 336 V DC Maximum input voltage: 160 V DC to 400 V DC Rated input current: 10 A Power port type: C14
RG-PD800I-F (DC input): Rated input voltage: –48 V DC Maximum input voltage: –36 V DC to –72 V DC Rated input current: 23 A Power port: three-pin power port |
| Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) Note: At altitudes ranging from 1800 m (5,905.51 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation. |
| Humidity |
| Altitude |
Operating altitude: ≤ 5,000 m (16,404.20 ft.) Storage altitude: ≤ 5000 m (16,404.20 ft.) |
| Cooling |
Air cooling, front-to-rear airflow (port-side intake) |
| Item |
RG-S6250-48XS8CQ |
| Layer 2 protocols |
IEEE802.3ae (10GBase), IEEE802.3ak, IEEE802.3an, IEEE802.3x, IEEE802.3ad (static link aggregation, LACP, M-LAG), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), STP root guard, and BPDU guard IEEE802.1w(RSTP), IEEE802.1s(MSTP) IGMP Snooping v1/v2, MLD Snooping, Jumbo Frame(9Kbytes) IEEE 802.1ad (QinQ and selective QinQ), GVRP, Three modes (access, trunk, and hybrid), LLDP, static MAC address, MAC address filtering, MAC address quantity limit |
| N/A |
| Layer 3 protocols (IPv4) |
Static routing, BGP4, OSPFv2, IS-IS, RIPv1, RIPv2, MBGP, LPM routing, policy-based routing (PBR), route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, and Any-RP, BFD for BGP/IS-IS/OSPF/static routing, manual tunnel, GRE tunnel |
| Basic IPv6 protocols |
Neighbor discovery, ICMPv6, path MTU discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, IS-ISv6, ACLv6, IPv6 TCP/UDP, SNMPv6, IPv6 Ping/Traceroute, IPv6 RADIUS, IPv6 Telnet/SSH, IPv6 FTP/TFTP, NTPv6, IPv6 MIB for SNMP, IPv6 VRRP, IPv6 QoS |
| IPv6 features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, IS-ISv6, IPv6 VRRP, MLDv1/v2, PIM-SMv6, manual tunnel, GRE tunnel, automatic tunnel, IPv4 over IPv6 tunnel, and ISATAP tunnel |
| Data center features |
VXLAN routing and VXLAN bridging EVPN VXLAN VXLAN mapping IPv4 VXLAN over IPv4 IPv6 VXLAN over IPv4 IPv6 VXLAN over IPv6 IPv6 VXLAN over IPv6
VXLAN over IPv6
M-LAG OpenFlow 1.3 RDMA, RoCEv2, PFC, and ECN |
| Process |
gRPC sFlow sampling IPFIX sampling |
| QoS |
IEEE 802.1p, ToS, and DSCP priority mapping ACL traffic classifier, and priority tagging Mark/Remark Various queue scheduling mechanisms such as SP (PQ), WRR, DRR, SP (PQ)+WRR, and SP (PQ)+DRR Flexible queue scheduling algorithms based on ports or queues Congestion avoidance mechanisms such as WRED and tail discarding Ingress/egress port-based rate limiting and CAR |
| MPLS |
MPLS VPN |
| Virtualization |
Virtual switching unit (VSU) |
| Buffer management |
Buffer usage monitoring and traffic microburst detection |
| High availability |
GR for RIP/OSPF/BGP, BFD, DLDP, VRRP, VRRP load balancing/dual-active, BFD for VRRP, REUP, RLDP, 1+1 power redundancy and fan redundancy, and hot swappable line cards and power modules |
| Security features |
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), DDoS/DoS attack defense, ICMP attack defense, unauthorized packet detection, data encryption, source IP spoofing defense, IP scanning attack defense, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL, port-based ACL, or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, uRPF, broadcast packet suppression, DHCP snooping, ARP spoofing defense (ARP anti-spoofing), ARP check, and hierarchical user management |
| Management mode |
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, NETCONF, Python, fan and power alarm, temperature alarm, and configuration rollback |
| Other protocols |
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, Proxy ARP, and Syslog |
| Model |
Description |
| RG-S6250-48XS8CQ |
RG-S6250-48XS8CQ chassis, 48 x 10GE SFP+ ports, 8 x 100GE QSFP28 ports, 2 x power module slots, 4 x fan module slots. The chassis is equipped with two power modules (RG-PA550I-F) and four fan modules (M1EFAN II-F). |
Power Modules
| Model |
Description |
| RG-PA550I-F |
550 W power module (supporting AC and 240 V HVDC) |
| RG-PD800I-F |
800 W power module (supporting 48 V LVDC) for the RG-S6250-48XS8CQ and the RG-S6510-48VS8CQ |
| RG-PA550I-R |
550 W AC power module (rear-to-front airflow, supporting AC and 240 V HVDC), used with rear-to-front airflow fan module M1EFAN IV-R |
| RG-PHD550I-F |
550 W AC power module (supporting 336 V HVDC) |
Fan Modules
| Model |
Description |
| M1EFAN II-F |
Fan module (port-side intake) for the RG-S6250-48XS8CQ |
| M1EFAN III-F |
Fan module (port-side intake) for the RG-S6231-48XT8CQ, the RG-S6231-48XS8CQ, the RG-S6232-48XS8CQ, and the RG-S6501-48VS8CQ |
| M1EFAN IV-R |
Fan module (fan-side intake), applicable to the RG-S6231-48XS8CQ and the RG-S6231-48XT8CQ |
40G Optical Transceivers
| Model |
Description |
| 40G-AOC-5M |
40G QSFP+ active optical cable (AOC), 5 m (16.40 ft.) |
| 40G-AOC-30M |
40G QSFP+ active optical cable, 30 m (98.43 ft.) |
| 40G-QSFP-SR-MM850 |
40G SR optical transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over multimode fiber (MMF) |
| 40G-QSFP-LSR-MM850 |
40G SR optical transceiver, QSFP+ form factor, MPO, 400 m (1,312.34 ft.) over MMF |
| 40G-QSFP-LR4-SM1310 |
40G LR4 optical transceiver, QSFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over single-mode fiber (SMF) |
| 40G-QSFP-iLR4-SM1310 |
40G iLR4 optical transceiver, QSFP+ form factor, Duplex LC, 2 km (6,561.68 ft.) over SMF |
| 40G-QSFP-LX4-SM1310 |
40G LX4 optical transceiver, QSFP+ form factor, Duplex LC, 150 m (492.13 ft.) over OM3/OM4 MMF, or 2 km (6,561.68 ft.) over SMF |
100G Optical Transceivers
| Model |
Description |
| 100G-AOC-5M |
100G AOC, QSFP28 form factor, 5 m (16.40 ft.) |
| 100G-AOC-10M |
100G AOC, QSFP28 form factor, 10 m (32.81 ft.) |
| 100G-QSFP-SR-MM850 |
100G SR optical transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF |
| 100G-QSFP-iLR4-SM1310 |
100G iLR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF |
| 100G-QSFP-LR4-SM1310 |
100G LR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF |
| 100G-QSFP-ER4-SM1310 |
100G ER4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 40 km (131,233.60 ft.) over SMF |
GE Optical Transceivers
| Model |
Description |
| GE-SFP-LH40-SM1310-BIDI |
1G LH optical transceiver, SFP form factor, BIDI LC, 40 km (131,233.60 ft.) over SMF |
| GE-SFP-LX20-SM1310-BIDI |
1G LX optical transceiver, SFP form factor, BIDI LC, 20 km (65,616.80 ft.) over SMF |
| GE-SFP-LX20-SM1550-BIDI |
| MINI-GBIC-LH40-SM1310 |
1G LH optical transceiver, SFP form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF |
| MINI-GBIC-LX-SM1310 |
1G LX optical transceiver, SFP form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF |
| MINI-GBIC-SX-MM850 |
1G SR optical transceiver, SFP form factor, Duplex LC, 550 m (1,804.46 ft.) over MMF |
| MINI-GBIC-ZX80-SM1550 |
1G ZX optical transceiver, SFP form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF |
GE Copper Transceivers
| Model |
Description |
| Mini-GBIC-GT(F) |
1G copper transceiver, SFP form factor, RJ45, used with Cat5e, Cat 6, and Cat6a, transmission distance of up to 100 m (328.08 ft.) For the RG-S6200 series products, the Mini-GBIC-GT(F) transceiver is applicable only to the RG-S6250-48XS8CQ. |
10GE Optical Transceivers
| Model |
Description |
| XG-SFP-SR-MM850 |
10G SR optical transceiver, SFP+ form factor, Duplex LC, 300 m (984.25 ft.) over MMF |
| XG-SFP-LR-SM1310 |
10G LR optical transceiver, SFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF |
| XG-SFP-ER-SM1550 |
10G ER optical transceiver, SFP+ form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF |
| XG-SFP-ZR-SM1550 |
10G ZR optical transceiver, SFP+ form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF |
| XG-LR-SM1310 |
| XG-SFP-AOC1M |
10G AOC, SFP+ form factor, 1 m (3.28 ft.) |
| XG-SFP-AOC3M |
10G AOC, SFP+ form factor, 3 m (9.84 ft.) |
| XG-SFP-AOC5M |
10G AOC, SFP+ form factor, 5 m (16.40 ft.) |
| XG-SR-MM850 |
For more information about optical transceiver compatibility, refer to Ruijie RG-S6200 Series Data Center Switches Optical Transceiver Compatibility Matrix.
