RG-S6910-3C Sieci w centrach danych - 1
RG-S6910-3C Sieci w centrach danych - 2
RG-S6910-3C Sieci w centrach danych - 3
RG-S6910-3C Sieci w centrach danych - 4
RG-S6910-3C Sieci w centrach danych - 5
RG-S6910-3C Sieci w centrach danych - 6
RG-S6910-3C Sieci w centrach danych - 7
RG-S6910-3C Sieci w centrach danych - 8
RG-S6910-3C – Data Center 100GE High-Density Modular Core Switch (Backward Compatible with 40GE) in the 4-RU Space
16 GB buffer that supports high-performance routing connections, and future evolution to 400GE data center network
  • Various ports, 100GE line cards, and up to 96 x 100GE ports
  • Support of IPv4/IPv6 dual-stack protocols, providing flexible networking
Parametry Kluczowe
Charakterystyka
Data Center 100GE DCI Core Switch RG-S6910-3C
16 GB powerful buffer capability and buffer scheduling mechanism, providing a maximum of 96 x 100GE ports within 4 RU height,
which is suitable for DCI core scenarios in data centers
Support of high-performance routing connections, meeting future expansion needs of data center networks
Power modules in 2+2 redundancy mode, hot swapping, and failover in seconds, providing nonstop services
Specyfikacje
RG-S6910-3C
442 mm x 735 mm x 173.6 mm (17.40 in. x 28.94 in. x 6.83 in.)
4 RU
22.9 kg (50.49 lbs., empty chassis)
32 kg (70.55 lbs., a chassis with four power modules and six fan modules)
19.2 Tbps
4000 Mpps
Management port
3 x expansion module slots
4 x power module slots
6 x  fan module slots
Maximum power consumption: 2046 W
Typical power consumption: 1092 W
Static power consumption: 760 W
RG-PA1200I-F (AC input)
8.5A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1200I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 6.5 A
RG-S6910-3C
Layer 2 Protocols
IEEE 802.3ae (10GBase), IEEE 802.3ak, IEEE 802.3an, IEEE 802.3x, IEEE 802.3ad (link aggregation), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), IGMP Snooping, Jumbo Frame (9 KB), IEEE 802.1ad (QinQ), GVRP
Layer 3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing, Route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP
IPv6 Basic Protocols
IPv6 Features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunneling, IPv4 over IPv6 tunneling
Visualization
sFLOW and IPFIX
Mapping of 802.1p, DSCP, and ToS priorities, ACL-based traffic classification, priority marking/remarking, multiple queue scheduling mechanisms available including SP, WFQ, and SP+WRR
HA Design
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swap for all cards and power modules
Security Features
Network foundation protection policy, CPP, DDoS attack defense, illegitimate packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, and SPAN/RSPAN/ERSPAN
Other Protocols
Zasoby
Informacje o zamawianiu
Chassis, Expansion Cards, Fan Modules, and Power Modules
RG-S6910-3C
Three expansion slot, four power module slots, and six fan module slots
M6900-32CQ
32-port 100GbE card
RG-PA1200I-F
RG-S6910-3C power module, supporting 2+2 redundancy, hot swapping, and front-to-rear ventilation design
M2EFAN I-F
RG-S6910-3C fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design
40G Optical Transceivers
100G QSFP28 AOC, 5 m (16.40 ft.)
100G QSFP28 AOC, 10 m (32.81 ft.)
