Centralized VXLAN
Distributed VXLAN
Layer 3 gateway location
Layer 3 gateway is deployed at Spine
Layer 3 gateway is deployed at Leaf
Layer 2 gateway location
Layer 2 gateway is deployed at Leaf
Traffic forwarding rules
Layer 3 traffic under the same -Leaf needs to detour the Spine
Layer 3 traffic under the same -Leaf does not need to detour the Spine
Table item storage rule
The Spine needs to store the MAC and ARP of the entire network
The Spine does not need to store the MAC and ARP of the entire network
Control Plane
Static or EVPN
EVPN
Operation and Management (O&M)
Simple, because the gateway is at Spine
Complex, because the gateway is at Leaf
Applicable Data center scale
Suitable for small scale networking
Suitable for medium and large scale networking
Static mode
IS-IS mode
EVPN mode
Controller mode
Tunnel Construction method
Adopts a static configuration approach
ENDP(Enhanced Neighbor Discovery Protocol) must be configured on VTEPs to discover VTEPs and establish tunnels
The extended BGP attribute enables neighbor discovery, automatically discovers VTEPs in VXLAN networks, and automatically creates VXLAN tunnels between VTEPs
Controller
System-controller
Tunnel establishment method between VTEPs
IS-IS protocol extension mode
VXLAN tunnels are automatically established through BGP extended attribute associations
Controller
System-controller
Address learning
Learns MAC address flooding
IS-IS protocol is implemented to learn remote addresses
Implementation of extended MP-BGP protocol
First packet reported,
The forwarding table item is issued by the Controller
Standardization
No control plane
Private protocol, extend IS-IS packets
The control protocol of EVPN has been standardized, see RFC 7348RFC7209, RFC7432
VTEP and Controller are based on the standard protocol framework Netconf/0penFlow, but each manufacturer has its own private definition, so they are not compatible
Related Blog:
