RG-IS5200-8GT4XS-DC Przełączniki - 1
RG-IS5200-8GT4XS-DC Przełączniki - 2
RG-IS5200-8GT4XS-DC Przełączniki - 3
RG-IS5200-8GT4XS-DC Przełączniki - 4
RG-IS5200-8GT4XS-DC Przełączniki - 5
RG-IS5200-8GT4XS-DC Przełączniki - 6
RG-IS5200-8GT4XS-DC Przełączniki - 7
RG-IS5200-8GT4XS-DC Industrial Ethernet Switch
Parametry Kluczowe
Charakterystyka
RG-IS5200 Series
This next-generation Gigabit Ethernet switch is designed for security, efficiency, and energy savings in industrial environments, featuring easy and flexible DIN rail mounting.
Specyfikacje
RG-IS5200-8GT4XS
RG-IS5200- 8GT4XS-DC
RG-IS5200-8GT4XS-UP-DC
RG-IS5200-24GT4XS-UP-DC
Fixed ports
8x10/100/1000BASE-T ports
8 x 10/100/1000BASE-T ports
RS-485 Port
DIDO
1 x DI, 1 x DO
PoE-REP
Fixed ports
RG-IS5200-8GT4XS
72Mpps
72Mpps
72Mpps
96 Mpps
96 Gbps
96 Gbps
96 Gbps
128 Gbps
512 MB
1GB DDR4
PoE-REP
4Gbps
RG-IS5200-8GT4XS
150mm x 133mm x 86mm
442mm x 220mm x 43.6mm
1.49kg
1.5kg
1.53kg
2.85kg
installation method
PoE-REP
Power supply and Consumption
RG-IS5200-8GT4XS
Power connector type
Terminal block
Not Supported
AC input:
● Rated current:0.6A
HVDC input:
● Rated voltage:240V DC
● Rated current:0.3A
● Rated current: 2 A to 0.5 A
110 V AC:16.7W
220 V AC:16.8W
240 V AC:16.8W
12 V DC: 19.8W
48 V DC: 17.5W
Leakage current
≤3.5mA
Terminal block
● Rated voltage: 56 V DC
● Maximum voltage:
PoE only: 48 V DC
● Rated current: 10 A
PoE not supported: 12 V DC
PoE only: 48 V DC
23.8W (Without PoE)
503.8W (full PoE load)
12V DC input: 36.8W
56V DC input:
● 35.5W (Without PoE)
● 515.5W (full PoE load)
PoE budget: 480 W
PoE budget: 480 W
PoE distance
PoE-REP used:
Ports 5 to 8:
PoE-REP used:
Ports 21 to 24:
PoE-REP
PoE Powered (Input)
PoE power (output)
RG-IS5200-8GT4XS
IP40
AC power port:
Service ports:
DI/DO/RS-485 port:
Service ports:
DI/DO/RS-485 port:
Conducted immunity
Performance criterion: A
AC power port: 3 V
Service port: 3 V
DI/DO/RS-485 port: 3 V
AC power port: 3 V
Service port: 3 V
Voltage dip
AC power port:
Vibration
Shock
IEC61000-3-3,GB17625.2
European Limits
PoE-REP
10 kV
RG-IS5200-8GT4XS
RG-IS5200 Series
ND and ND snooping
 TACAS+
REUP, RLDP, and DLDP
Dual-boot redundancy
Fan fault alarming
Virtualization
SPAN, RSPAN
SNMPv1/v2/v3
RMON (groups 1, 2, 3, and 9)
Zasoby
Informacje o zamawianiu
RG-IS5200-8GT4XS
RG-IS5200-
8GT4XS-DC
RG-IS5200-
8GT4XS-UP-DC
RG-IS5200-
24GT4XS-UP-DC
IPA240-P
IPA60
Accessories
PoE-REP
IS52-shield
GE-SFP-SR-MM850-I
GE-SFP-LR-SM1310-I
XG-SFP-SR-MM850-I
XG-SFP-LR-SM1310-I
