Mini-GBIC-GT Przełączniki - 1
Mini-GBIC-GT Przełączniki - 2
Mini-GBIC-GT Przełączniki - 3
Mini-GBIC-GT Przełączniki - 4
Mini-GBIC-GT Przełączniki - 5
Mini-GBIC-GT 1000BASE-T SFP Copper RJ45 100-m Transceiver Module
  • High-speed data transmission of up to 1.25Gbps
  • Maximum transmission distance of up to 100 meters
  • Hot-pluggable feature allows for easy installation or removal without disrupting the network
  • Compatible with various networking equipment, making it a versatile choice for different setups
  • Conforming to IEEE 802.3ab, SFP+ MSA, and RoHS standards
Charakterystyka
MINI-GBIC-GT Module
The MINI-GBIC-GT is an IEEE 1000base-X to 1000base-T media converter and supports a link length of up to 100 meters over a Cat 5e/6/6a cable with an RJ45 connector. It adopts the SFP form factor. The port needs to be conffgured with auto-negotiation. The transceiver conforms to IEEE 802.3ab, SFP+ MSA, and RoHS standards.
Specyfikacje
MINI-GBIC-GT
1.25 Gbps
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Zasoby
Informacje o zamawianiu
