MINI-GBIC-LX-SM1310 Switch - 1
MINI-GBIC-LX-SM1310 Switch - 2
MINI-GBIC-LX-SM1310 Switch - 3
MINI-GBIC-LX-SM1310 Switch - 4
MINI-GBIC-LX-SM1310 Switch - 5
MINI-GBIC-LX-SM1310 1000BASE-SX SFP 1310-nm 10-km DDM Duplex LC SMF Optical Transceiver Module
Caratteristiche
MINI-GBIC-LX-SM1310 Module
The MINI-GBIC-LX-SM1310 is aligned to IEEE 1000BASE-LX optical specifications and supports a link length of up to 10 kilometers over a single-mode fiber (SMF) with an LC connector. It adopts the SFP form factor and operates at a wavelength of 1310 nm. The transceiver conforms to IEEE 802.3, SFF-8472, SFF-8431, SFF-8432, SFP+ MSA, and RoHS standards.
Specifiche
MINI-GBIC-GT
1.25 Gbps
1000base-X to 1000base-T
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Risorse
Informazioni sull'ordine
