RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 1
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 2
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 3
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 4
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 5
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 6
RG-WS6012-L Reti enterprise di piccole e medie dimensioni - 7
RG-WS6012-L High-Performance 10 Gbps Wireless Access Controller
Fit for scenarios such as hotels, offices, campuses, and hospitals.
  • Multiple high-speed interfaces, delivering 10 Gbps forwarding capability
  • Management of 32 APs by default, which can be expanded to 896 APs to flexibly meet service expansion needs
  • Intelligent load balancing for improved user experience
  • Ruijie Cloud used for unified management and simplified O&M
Specifiche chiave
Caratteristiche
The RG-WS6012-L access controller (AC) is designed for small- and medium-scale networks, delivering 10 Gbps forwarding capacity. It provides high scalability, enabling flexible configuration and management of access points (APs).
High Performance and High Capacity
Intelligent Load Balancing
User- and traffic-based load balancing used to allocate users to different APs, preventing AP overload
Frequency-based load balancing used to steers dual-band clients to the 5 GHz frequency band, enhancing bandwidth utilization
Cloud Unified Management, Efficient O&M
Unified management through Ruijie Cloud, eliminating the need for onsite provisioning
Real-time alarms and intelligent troubleshooting, improving O&M efficiency
Specifiche
RG-WS6012-L
4 GB
RG-WS6012-L
Unit dimensions (W x D x H)
Shipping dimensions (W x D x H)
550 mm x 460 mm x 368 mm (21.65 in. x 18.11 in. x 14.49 in.)
Rack size
2.7 kg (5.95 lbs)
3.5 kg (7.72 lbs)
Rack-mount
RG-WS6012-L
8 x 10/100/1000BASE-T ports
2 x 1GE SFP/RJ45 combo ports
2 x 10GE SFP+ ports
1 x system status LED
1 x power status LED
2 x 10GE SFP+ port LEDs
  • Note
RG-WS6012-L
30 W
Input voltage
Input current
0.25 A (maximum RMS current)
Output voltage
12 V/3.33 A
RG-WS6012-L
< 78 dB
RG-WS6012-L
32
Note: The default number of APs that can be managed by the RG-WS6012-L is subject to the AP model. See the Ordering Information for details.
2,048
896
Note: The maximum number of APs that can be managed by the RG-WS6012-L is subject to the AP model. See the Ordering Information for details.
4,480
Note: The maximum number of STAs that can be managed by the RG-WS6012-L is subject to the network environment. Contact technical support team for details.
WLAN service
Maximum number of associated STAs per WLAN: 4,480
Intra-AC roaming handoff time
< 50 ms
896
Forwarding capacity
Number of MAC address entries
32,768
Number of VLANs
4,096
Number of ARP entries
32,768
DHCP address pools
Number of routing entries
IPv4 routing entries: 8,192
IPv6 routing entries: 10,000
1,500
Number of ACL entries
65,536
Applicable Software Version
RG-WS6012-L
AC_RGOS 11.9(6)W6B1 or later
RG-WS6012-L
IEEE 802.11 protocols
Roaming
Forwarding mode
Centralized forwarding
Local forwarding
Wireless QoS
Fair scheduling
AC-based user isolation
AP-based user isolation
WLAN-based user isolation
AC virtualization
AC failover
Multi-AC cluster (N-to-N)
WLAN optimization
RF management
Coverage Hole Detection
Band selection
RG-WS6012-L
IPv4 security authentication
Web-based authentication
802.1X authentication
MAB authentication
SMS authentication
IPv6 security authentication
Multi-SSID mode
WPA and WPA2
WEP (WEP/WEP128)
TKIP
CCMP
ARP anti-spoofing
AP virtualization
 *To implement SMS-based authentication, the AC needs to interconnect with the authentication server that is connected to the SMS gateway.
Protocols
Protocols
RG-WS6012-L
IPv4 protocols
Ping and traceroute
DNS client
NTP
Telnet
TFTP server and TFTP client
FTP server and FTP client
IPv6 protocols
DNSv6 client
TFTPv6 client
FTPv6 server and FTPv6 client
IPv6 CAPWAP
IPv6 ping
IPv6 traceroute
Neighbor discovery
IPv4 routing
Static routing, RIP, and OSPF
IPv6 routing
RG-WS6012-L
RMON
Syslog
Remote probe
Eweb
Wi-Fi heat map
RG-WS6012-L
IEC 62368-1, EN 62368-1
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, and ETSI EN 300 386
Risorse
Informazioni sull'ordine
Main Unit
RG-WS6012-L
The next-generation wireless access controller provides 8 x 10/100/1000BASE-T ports, 2 x SFP/RJ45 combo ports, and 2 x 10GE SFP+ ports.
It supports 32 licenses by default.
  • A generic AP occupies one license. The RG-WS6012-L can manage up to 448 generic APs.
  • A wall plate AP occupies half of the license. The RG-WS6012-L can manage up to 896 wall plate APs.
Optical Transceivers
License
Product Description
RG-LIC-WS-16
RG-LIC-WS-32
RG-LIC-WS-128
RG-LIC-WS-512
RG-LIC-WS-1024
