RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 1
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 2
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 3
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 4
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 5
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 6
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 7
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 8
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 9
RG-AP180P-L Reti enterprise di piccole e medie dimensioni - 10
RG-AP180P-L, Wi-Fi 6 Dual-Radio 2.976 Gbps Wall Plate AP
High-density small-sized scenarios covering star hotels, enterprise VIP offices, and apartments
  • Flat Rear Panel, Easy Installation on Any Wall in All Countries
  • 2.5 Gbps Uplink Port, Achieving Ultra-High Speed Access in Rooms
  • PoE Out for IP Phones and Other IoT Devices
Specifiche chiave
Caratteristiche
Wall Plate AP for All Countries
Ruijie Wall Plate Wireless AP RG-AP180P-L
Appearance
Scenario
Wi-Fi 6
AX3000
Universal Mounting Kit
PoE Out
Free Cloud Management
Flat Rear Panel,
Innovative rear panel,Simple wall mounting
AX3000 chip, increasing data transmission volume
2.976 Gbps, smoother experiences
160MHz 丨 2.976 Gbps
PoE out on LAN1, one cable for data and power transmission
Plug-and-play IP phones, no service interruption in a power failure
Soaring transmission rate, Superior Internet experience
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Specifiche
RG-AP180P-L
Unit dimensions(W x H x D)
86 mm x 170 mm x 43 mm (3.39 in. × 6.69 in. × 1.69 in.)
Shipping dimensions
(W x H x D)
367 mm x 399 mm x 245 mm (14.45 in. × 15.71 in. × 9.65 in.)
Unit weight
Main unit: 0.3 kg (0.66 lbs)
Mounting bracket: 0.1 kg (0.22 lbs)
Shipping weight
11.53 kg (25.42 lbs)
Wall-mount (a mounting bracket is delivered with the main unit)
Junction box-mount (86 mm/European-standard/American-standard junction box)
Elegant white
Kensington lock
RG-AP180P-L
● Radio 1: 2.4 GHz, two spatial streams, 2x2 MU-MIMO
● Radio 2: 5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz (HE20/HE40), ISM, channels 1 to 13
Radio 2, 802.11a/n/ac/ax:
Data rates
Radio 1: 2.4 GHz, 574 Mbps
Radio 2: 5 GHz, 2.402 Gbps
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 5 dBi
Maximum transmit power
2.4 GHz radio: 20 dBm (17 dBm per chain)
5 GHz radio: 20 dBm (17 dBm per chain)
Thailand
5.725 GHz to 5.825 GHz, EIRP ≤ 30 dBm
Vietnam:
5150-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Configurable in increments of 1 dBm
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP180P-L
1 Mbps
–96 dBm
-10 dBm
–94 dBm
-10 dBm
–93 dBm
11 Mbps
-10 dBm
6 Mbps
19 dBm
24 Mbps
17 dBm
36 Mbps
17 dBm
54 Mbps
–74 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
12 dBm
–58 dBm
17 dBm
12 dBm
6 Mbps
24 Mbps
17 dBm
36 Mbps
17 dBm
–78 dBm
54 Mbps
15 dBm
–72 dBm
14 dBm
–67 dBm
17 dBm
14 dBm
–64 dBm
13 dBm
17 dBm
13 dBm
–57 dBm
13 dBm
–56 dBm
12 dBm
–58 dBm
17 dBm
12 dBm
12 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
15 dBm
12 dBm
–50 dBm
Bluetooth Radio
RG-AP180P-L
Bluetooth 5.1
Maximum antenna gain
10 dBm
Receive sensitivity
–88 dBm (@BLE)
Ports Specifications
RG-AP180P-L
Uplink:
1 x 100/1000/2.5GBASE-T port, in compliance with IEEE 802.3af/802.3at standard (PoE/PoE+)
When powered by 802.3af PoE, LAN 1 cannot supply power to an attached device.
Downlink:
4 x 10/100/1000BASE-T ports
LAN 1 supports 48 V/10 W power supply to an attached device.
1 x Micro USB console port
RG-AP180P-L
● PoE input over PoE-in port: The power source equipment (PSE) complies with IEEE 802.3af/at standard (PoE/PoE+).
LAN 1 supports 48 V/10 W PoE output to an attached device.
Overall power consumption
Maximum power consumption: 25 W
● DC powered: 25 W
● PoE powered (802.3af): 15 W
● Idle mode: 8 W
RG-AP180P-L
Operating temperature: 0°C to 40°C (32°F to +104°F)
RG-AP180P-L
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN IEC 62311
FCC Part 15
RG-AP180P-L
RGOS11.9(6)W3B3 or higher
RG-AP180P-L
120
256
 Note
Maximum number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
Security and Authentication
RG-AP180P-L
Dynamic ACL assignment
Routing and Switching
RG-AP180P-L
IP service
IPv6 basics
IPv6 DHCP Client
RG-AP180P-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
STA access management
Fat/Fit/Cloud mode switchover
Risorse
Informazioni sull'ordine
RG-AP180P-L
Wi-Fi 6 dual-radio wall plate wireless access point
Up to four spatial streams
Data rate of up to 2.976 Gbps
IEEE 802.3af/at-compliant power supply and DC power supply
●    A 48 V/0.6 A power adapter needs to be purchased separately.
Domande frequenti
