GE-SFP-LH40-SM1310-BIDI Commutateurs - 1
GE-SFP-LH40-SM1310-BIDI Commutateurs - 2
GE-SFP-LH40-SM1310-BIDI Commutateurs - 3
GE-SFP-LH40-SM1310-BIDI Commutateurs - 4
GE-SFP-LH40-SM1310-BIDI Commutateurs - 5
GE-SFP-LH40-SM1310-BIDI Commutateurs - 6
GE-SFP-LH40-SM1310-BIDI 1000BASE-LX SFP 1310nm-TX/1550nm-RX 40-km DDM Simplex LC SMF Transceiver Module
GE-SFP-LH40-SM1310-BIDI Module
The GE-SFP-LH40-SM1310-BIDI is aligned to IEEE 1000BASE-LH optical specifications and supports a link length of up to 40 kilometers over an SMF with a BIDI LC connector. It adopts the SFP form factor and operates at a wavelength of 1310 nm. The transceiver conforms to IEEE 802.3, SFF-8472, SFF-8431, SFF-8432, SFP+ MSA, and RoHS standards.
MINI-GBIC-GT
1.25 Gbps
1000base-X to 1000base-T
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Informasi Pemesanan
Technical Support
Technical Support
Get in Touch
Get in Touch
