RG-AP680-AR Sans fil - 1
RG-AP680-AR Sans fil - 2
RG-AP680-AR Sans fil - 3
RG-AP680-AR Sans fil - 4
RG-AP680-AR Sans fil - 5
RG-AP680-AR Sans fil - 6
RG-AP680-AR Sans fil - 7
RG-AP680-AR Sans fil - 8
RG-AP680-AR Sans fil - 9
RG-AP680-AR Sans fil - 10
RG-AP680-AR, Wi-Fi 6 Quad-Radio 10.755 Gbps High-Density Outdoor Access Point
Outdoor scenarios covering higher education, wireless cities, energy, and business malls
  • 10G Optical Port and 5G Ethernet Port for Flexible Networking
  • Upgraded to Wi-Fi 6, a combined data rate of up to 10.755 Gbps
  • Industrial-grade product design, IP68 rating, 6 kV lightning protection, Operating temperature: –40°C to +70°C
  • Independent AI radio for secure scanning, safeguarding wireless network security
Spécifications essentielles
Wi-Fi 6 AR Series High-Density Outdoor AP RG-AP680-AR
Product
The AP can be flexibly deployed in the scenarios covering higher education, wireless cities, energy, business malls.
14 Spatial Streams
Maximum Data Rate 10.755 Gbps
IP68 Rating
PoE/DC Power
Bluetooth 5.1
10G optical port: supports All-Optical i-Share+ Solution, meeting outdoor AP deployment requirements for over 1 km distance and high bandwidth.
5G Ethernet port: supports network cable connection, meeting existing networking demands and protecting investments.
Upgraded to Wi-Fi 6
10.755
Gbps
High Concurrency
Low Latency
is as low as 20 ms.
High Security
High Speed
802.11ac.
Industrial-Grade Product Design, Ensuring Stable Running
in Harsh Outdoor Environments
IP68 Rating
6 kV Lightning Protection
Wide Temperature Range
The built-in independent AI Radio can perform full-radio secure scanning and troubleshooting in real time.
Unlike traditional, periodic, single-radio scanning with blind spots, AI Radio guarantees wireless network security in public scenarios such as stadiums, business malls, and subways.
AI Radio
Traditional AP
24/7 real-time scanning
5G/2.4G full-radio scanning
Periodic, single-radio scanning
Occupying communication radio resources
Legend: Secure scanning Data transmission
Unified Cloud Management
Go to WIS ->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
Spécifications
RG-AP680-AR
14 spatial streams
● Radio 2 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 3 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – 5 GHz: 20 MHz and 40 MHz
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
Combined peak data rate: 1.800 Gbps
● Radio 1 – 2.4 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
● Radio 3 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
10 spatial streams
● Radio 4 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 4 – AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 6.934 Gbps
● Radio 3 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
● Radio 4 – AI Radio, 5 GHz: AI Radio for scanning only
12 spatial streams
● Radio 3 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
Combined peak data rate: 10.755 Gbps
● Radio 2 – 5 GHz: 8.6 Mbps to 4.804 Gbps (MCS0 to MCS11)
● Radio 3 – 5 GHz: 8.6 Mbps to 4.804 Gbps (MCS0 to MCS11)
● 2.4 GHz: four built-in omnidirectional antennas, with peak antenna gain of 6 dBi.
● 5 GHz: eight built-in omnidirectional antennas, with peak antenna gain of 8 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 4 dBi.
1 x 100/1000BASE-T port
2 x 10GE SFP+ ports, compatibility with 1GE and 2.5GE modules
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Whether bridging is enabled
Main unit: 4.3 kg (9.48 lbs)
Shipping: 7.18 kg (15.83 lbs)
● 100–240 V AC power supply: The AC power supply needs to be purchased separately.
● PoE input over ETH/PoE: The power source equipment (PSE) complies with IEEE 802.3af/at/bt standard (PoE/PoE+/PoE++).
Note: If both AC power and PoE are available, AC power is preferred.
Maximum power consumption: 50 W
● AC power: 50 W, 2.4 GHz radio 4x4, 5 GHz radio1 4x4, 5 GHz radio2 4x4, AI radio enabled, LAN 2 for PoE supply
● 802.3bt (PoE++) : 50 W, 2.4 GHz radio 4x4, 5 GHz radio1 4x4, 5 GHz radio2 4x4, AI radio enabled, LAN 2 for PoE supply
● 802.3at (PoE+) : 25 W, 2.4 GHz radio 4x4, 5 GHz radio1 4x4, 5 GHz radio2, AI Radio disabled, LAN 2 fails to provide power for external devices.
● 802.3af (PoE) : 12.95 W, all radios do not work, and LAN 2 fails to provide power for external devices
● Idle mode: 10 W
Operating temperature: –40°C to +70°C (–40°F to +158°F)
Operating altitude: –500 m to +3,000 m (–1,640.42 ft. to +9,842.52 ft.)
IP68
6 kV
2 GB DRAM, 256 MB flash
● Maximum transmit power: 29 dBm (794.33 mW)
● Maximum transmit power: 27 dBm (501.19 mW)
RG-AP680-AR
–94 dBm
22 dBm
–90 dBm
21 dBm
–88 dBm
–89.5 dBm
22 dBm
–83 dBm
22 dBm
–73 dBm
–86 dBm
–68 dBm
–83 dBm
–65 dBm
–86 dBm
–68 dBm
–83 dBm
21 dBm
–89.5 dBm
–83 dBm
–73 dBm
21 dBm
–86 dBm
–68 dBm
21 dBm
–83 dBm
–65 dBm
21 dBm
–86 dBm
17 dBm
–61 dBm
21 dBm
–83 dBm
17 dBm
–57 dBm
21 dBm
17 dBm
21 dBm
–86 dBm
14 dBm
–58 dBm
21 dBm
–83 dBm
14 dBm
21 dBm
14 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
21 dBm
–77 dBm
14 dBm
–49 dBm
Basic Functions
RG-AP680-AR
RGOS11.9(6)W1B5 or later
Maximum number of WLAN IDs
MU and TAG device locating
Application management
PSK and web authentication
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 187
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
IPv6 addressing, Neighbor Discovery (ND), IPv6 ND proxy, ICMPv6, IPv6 ping
NTP server and NTP client
RG-AP680-AR
Big data capabilities
RG-AP680-AR
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, EN 62311, EN IEC 62311, EN 50665, IEC 62368-1, EN 62368-1, IEC 60950-22, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-AR] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-AR] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Ressources
Informations sur la commande
Remarks
RG-AP680-AR
Quad-radio, 14 spatial streams, peak data rate of 10.755 Gbps
● Radio 1: 2.4 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 1.147 Gbps
● Radio 2: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
● Radio 3: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
● Radio 4: AI Radio, 2.4GHz/5 GHz: two spatial streams, 2x2 MIMO, AI Radio for scanning only
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3at/at/bt PoE and local AC power supply
● The AC power supply needs to be purchased separately.
Required
RG-ANTx4-2400D
External antenna used by the RG-AP680-AR, panel directional antenna, 2.4 GHz, 4×4 MIMO, antenna gain of 12 dBi, and built-in feeder set: 1 m, N-N, four feeders
Each RG-AP680-AR can be equipped with only one feeder set.
Optional
RG-ANTx4-5000D
External antenna used by the RG-AP680-AR switches, panel directional antenna, 5 GHz, 4×4 MIMO, antenna gain of 12 dBi, and built-in feeder set: 1 m, N-N, four feeders
Each RG-AP680-AR can be equipped with two feeder sets.
Optional
