RG-S6250-48XS8CQ Réseaux de centres de données - 1
RG-S6250-48XS8CQ Réseaux de centres de données - 2
RG-S6250-48XS8CQ Réseaux de centres de données - 3
RG-S6250-48XS8CQ Réseaux de centres de données - 4
RG-S6250-48XS8CQ Réseaux de centres de données - 5
RG-S6250-48XS8CQ Réseaux de centres de données - 6
RG-S6250-48XS8CQ 10GE Data Center Access Switch
  • 48 x 1G/10G SFP+ ports and 8 x 40G/100G QSFP28 ports
Spécifications essentielles
Data Center 10GE Access Switch RG-S6250-48XS8CQ
10GE high-density access switch with 10GE/100GE downlink ports and 100GE uplink ports backward compatible with 40GE for adaptation to different scenarios
Large buffer and advanced buffer scheduling mechanism, providing fast data processing and easily coping with burst traffic
De-stacking
M-LAG
Spécifications
RG-S6250-48XS8CQ
1 RU
5.6 kg (12.35 lbs., empty chassis)
8.2 kg (18.08 lbs., a chassis installed with two power modules and four fan modules)
2.56 Tbps
1920 Mpps
Service port
Management port
2 x power module slots
4 x fan module slots
Typical power consumption: 165 W
RG-PA550I-F (AC input):
Power port type: C14
RG-PA550I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 3.6 A
RG-PHD550I-F (AC input):
Rated input current: 10 A
RG-PHD550I-F (HVDC input):
Rated input voltage: 336 V DC
RG-PD800I-F (DC input):
Rated input voltage: –48 V DC
Rated input current: 23 A
Power port: three-pin power port
RG-S6250-48XS8CQ
Layer 2 protocols
IEEE802.3ae (10GBase), IEEE802.3ak, IEEE802.3an, IEEE802.3x, IEEE802.3ad (static link aggregation, LACP, M-LAG), IEEE802.1p, IEEE802.1Q,
IEEE802.1D (STP), STP root guard, and BPDU guard
IEEE802.1w(RSTP), IEEE802.1s(MSTP)
IGMP Snooping v1/v2, MLD Snooping, Jumbo Frame(9Kbytes)
IEEE 802.1ad (QinQ and selective QinQ), GVRP, Three modes (access, trunk, and hybrid), LLDP, static MAC address, MAC address filtering, MAC address quantity limit
Layer 3 protocols (IPv4)
Static routing, BGP4, OSPFv2, IS-IS, RIPv1, RIPv2, MBGP, LPM routing, policy-based routing (PBR), route-policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, and Any-RP, BFD for BGP/IS-IS/OSPF/static routing, manual tunnel, GRE tunnel
Basic IPv6 protocols
Neighbor discovery, ICMPv6, path MTU discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, IS-ISv6, ACLv6, IPv6 TCP/UDP, SNMPv6, IPv6 Ping/Traceroute, IPv6 RADIUS, IPv6 Telnet/SSH, IPv6 FTP/TFTP, NTPv6, IPv6 MIB for SNMP, IPv6 VRRP, IPv6 QoS
IPv6 features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, IS-ISv6, IPv6 VRRP, MLDv1/v2, PIM-SMv6, manual tunnel, GRE tunnel, automatic tunnel, IPv4 over IPv6 tunnel, and ISATAP tunnel
Data center features
EVPN VXLAN
VXLAN mapping
IPv4 VXLAN over IPv4
IPv6 VXLAN over IPv4
IPv6 VXLAN over IPv6
VXLAN over IPv6
M-LAG
OpenFlow 1.3
RDMA, RoCEv2, PFC, and ECN
Process
sFlow sampling
IPFIX sampling
IEEE 802.1p, ToS, and DSCP priority mapping
ACL traffic classifier, and priority tagging Mark/Remark
Various queue scheduling mechanisms such as SP (PQ), WRR, DRR, SP (PQ)+WRR, and SP (PQ)+DRR
Flexible queue scheduling algorithms based on ports or queues
Ingress/egress port-based rate limiting and CAR
MPLS VPN
Virtualization
Virtual switching unit (VSU)
Buffer management
Buffer usage monitoring and traffic microburst detection
High availability
GR for RIP/OSPF/BGP, BFD, DLDP, VRRP, VRRP load balancing/dual-active, BFD for VRRP, REUP, RLDP, 1+1 power redundancy and fan redundancy, and hot swappable line cards and power modules
Security features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), DDoS/DoS attack defense, ICMP attack defense, unauthorized packet detection, data encryption, source IP spoofing defense, IP scanning attack defense, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL, port-based ACL, or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, uRPF, broadcast packet suppression, DHCP snooping, ARP spoofing defense (ARP anti-spoofing), ARP check, and hierarchical user management
Management mode
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, NETCONF, Python, fan and power alarm, temperature alarm, and configuration rollback
Other protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, Proxy ARP, and Syslog
Ressources
Informations sur la commande
RG-S6250-48XS8CQ
RG-S6250-48XS8CQ chassis, 48 x 10GE SFP+ ports, 8 x 100GE QSFP28 ports, 2 x power module slots, 4 x fan module slots. The chassis is equipped with two power modules (RG-PA550I-F) and four fan modules (M1EFAN II-F).
Power Modules
RG-PA550I-F
550 W power module (supporting AC and 240 V HVDC)
RG-PD800I-F
800 W power module (supporting 48 V LVDC) for the RG-S6250-48XS8CQ and the RG-S6510-48VS8CQ
RG-PA550I-R
550 W AC power module (rear-to-front airflow, supporting AC and 240 V HVDC), used with rear-to-front airflow fan module M1EFAN IV-R
RG-PHD550I-F
550 W AC power module (supporting 336 V HVDC)
Fan Modules
M1EFAN II-F
Fan module (port-side intake) for the RG-S6250-48XS8CQ
M1EFAN III-F
Fan module (port-side intake) for the RG-S6231-48XT8CQ, the RG-S6231-48XS8CQ, the RG-S6232-48XS8CQ, and the RG-S6501-48VS8CQ
M1EFAN IV-R
Fan module (fan-side intake), applicable to the RG-S6231-48XS8CQ and the RG-S6231-48XT8CQ
40G Optical Transceivers
40G QSFP+ active optical cable (AOC), 5 m (16.40 ft.)
40G QSFP+ active optical cable, 30 m (98.43 ft.)
40G SR optical transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over multimode fiber (MMF)
40G SR optical transceiver, QSFP+ form factor, MPO, 400 m (1,312.34 ft.) over MMF
40G LR4 optical transceiver, QSFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over single-mode fiber (SMF)
40G iLR4 optical transceiver, QSFP+ form factor, Duplex LC, 2 km (6,561.68 ft.) over SMF
100G Optical Transceivers
GE Optical Transceivers
1G LH optical transceiver, SFP form factor, BIDI LC, 40 km (131,233.60 ft.) over SMF
1G LH optical transceiver, SFP form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
1G LX optical transceiver, SFP form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
1G ZX optical transceiver, SFP form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
GE Copper Transceivers
Mini-GBIC-GT(F)
1G copper transceiver, SFP form factor, RJ45, used with Cat5e, Cat 6, and Cat6a, transmission distance of up to 100 m (328.08 ft.) For the RG-S6200 series products, the Mini-GBIC-GT(F) transceiver is applicable only to the RG-S6250-48XS8CQ.
10GE Optical Transceivers
10G ER optical transceiver, SFP+ form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
10G ZR optical transceiver, SFP+ form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
XG-LR-SM1310
10G AOC, SFP+ form factor, 1 m (3.28 ft.)
10G AOC, SFP+ form factor, 3 m (9.84 ft.)
10G AOC, SFP+ form factor, 5 m (16.40 ft.)
XG-SR-MM850
For more information about optical transceiver compatibility, refer to Ruijie RG-S6200 Series Data Center Switches Optical Transceiver Compatibility Matrix.
