RG-AP850-AR(V3) Sans fil - 1
RG-AP850-AR(V3) Sans fil - 2
RG-AP850-AR(V3) Sans fil - 3
RG-AP850-AR(V3) Sans fil - 4
RG-AP850-AR(V3) Sans fil - 5
RG-AP850-AR(V3) Sans fil - 6
RG-AP850-AR(V3) Sans fil - 7
RG-AP850-AR(V3) Sans fil - 8
RG-AP850-AR(V3) Sans fil - 9
RG-AP850-AR(V3) Sans fil - 10
RG-AP850-AR(V3), Wi-Fi 6 Quad-radio 5.378 Gbps High-Density Indoor Access Point
  • 160 MHz high bandwidth, 5.378 Gbps high speed with Wi-Fi 6
Spécifications essentielles
Wi-Fi 6 AR Series High-Density Settled AP
RG-AP850-AR(V3) with Built-in AI Radio
8 spatial streams
Up to 5.378 Gbps data rate
Max. 1552 clients
PoE/DC power supply
Bluetooth 5.1
5 Gbps SFP Combo & Electrical Ports for Flexible Networking
A 5 Gbps SFP combo port supports >1 Gbps indoor connectivity with the All-Optical i-Share+ Solution.
A 5 Gbps Ethernet port meets current networking needs to maximize the return on investment (ROI).
Seamless Client Roaming Enabled by AI Radio
The built-in AI radio module can independently scan and transmit client status information to the AC, which directs clients to swiftly connect to nearby APs with stronger signals. This achieves optimal signal quality and zero stalling during roaming.
Built-in AI Radio
<30 ms average roaming delay
<0.5% packet loss rate
Conventional settled APs
300 ms average roaming delay
2% packet loss rate
AI Radio enables real-time, full-band scanning to eliminate dead zones traditionally caused by timeframe-based, single-band scanning, ensuring a robust network.
The secure scanning approach does not consume radio resources for communication, uncompromising wireless performance.
24/7 real-time scanning
AI Radio safeguarding
Traditional AP safeguarding
Secure scanning
Data transmission
5.378 Gbps Ultra-Fast Speed with Wi-Fi 6
5.378
Gbps
High concurrency
OFDMA and MU-MIMO transfer technologies, ensuring concurrent robust multi-client connection for multiple users
High rate
Low delay
OFDMA technology reduces the delay to as low as 20 ms when data is transmitted to multiple clients simultaneously.
High security
Next-gen wireless encryption protocol WPA3 significantly enhances wireless security.
Go to WIS Cloud Network >
Cloud O&M
24 h Network Optimization
Real-Time Warning
Fault Locating
Spécifications
RG-AP850-AR(V3)
Eight spatial streams
● Radio 3 – 5 GHz: 2x2 MIMO, two spatial streams
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – 5 GHz: 20 MHz and 40 MHz
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
● Radio 3 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15)
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
Six spatial streams
● Radio 4 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 4 – AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 3.466 Gbps
● Radio 3 – 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
● Radio 4 – AI Radio, 5 GHz: AI Radio for scanning only
Six spatial streams
● Radio 3 – 5 GHz: 2x2 uplink/downlink MU-MIMO, two spatial streams
Channels:
● Radio 3 – 5 GHz: 8.6 Mbps to 2.402 Gbps (MCS0 to MCS11)
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.4 dBi.
● 5 GHz: six built-in omnidirectional antennas, with peak antenna gain of 5.2 dBi.
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 1.0 kg (2.2 lbs)
Shipping: 1.42 kg (3.13 lbs)
● DC power: 40 W, 2.4 GHz radio 2x2, 5 GHz radio1 2x2, 5 GHz radio2 2x2, AI Radio enabled, LAN 2 for PoE supply, and USB port enabled
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 2x2, 5 GHz radio1 2x2, 5 GHz radio2 2x2, AI Radio enabled, LAN 2 for PoE supply, and USB port enabled
● 802.3at (PoE+): 23 W, 2.4 GHz radio 2x2, 5 GHz radio1 2x2, 5 GHz radio2 2x2, AI Radio enabled , LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3af (PoE): 12.95 W, 2.4 GHz radio 1x1, 5 GHz radio1 1x1, 5 GHz radio2 1x1, AI Radio is disabled, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● Idle mode: 10.3 W
External power supply
1 GB DRAM, 256 MB flash
● Maximum transmit power: 27 dBm (501.19 mW)
● Minimum transmit power: 19 dBm (79.43 mW)
● Maximum transmit power: 26 dBm (398.11 mW)
● Minimum transmit power: 21 dBm (125.89 mW)
RG-AP850-AR(V3)
24 dBm
24 dBm
–90 dBm
22 dBm
–87 dBm
24 dBm
–78 dBm
21 dBm
–72 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–78 dBm
21 dBm
–72 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
18.5 dBm
24 dBm
18.5 dBm
–57 dBm
24 dBm
18.5 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
24 dBm
–76 dBm
–49 dBm
Basic Functions
RG-AP850-AR(V3)
RGOS11.9(6)W2B7 or later
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP)
ACL Remark
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
NTP server and NTP client
SNMPv1/v2C/v3
RG-AP850-AR(V3)
Big data capabilities
RG-AP850-AR(V3)
Ressources
Informations sur la commande
RG-AP850-AR(V3)
Quad-radio, eight spatial streams, peak data rate of 5.378 Gbps
● Radio 3: 5 GHz: two spatial streams, 2x2 MU-MIMO, peak data rate of 2.402 Gbps
● Radio 4: AI Radio, 2.4 GHz/5 GHz: two spatial streams, 2x2 MIMO, AI Radio for scanning only
