RG-AP9220 Sans fil - 1
RG-AP9220 Sans fil - 2
RG-AP9220 Sans fil - 3
RG-AP9220 Sans fil - 4
RG-AP9220 Sans fil - 5
RG-AP9220 Sans fil - 6
RG-AP9220, Wi-Fi 7 Dual-Radio 3.570 Gbps Indoor Access Point
Designed for all scenarios, such as corporate offices, universities, medical facilities, and others.
  • 2.5GE SFP port and 2.5GBASE-T port for flexible networking
  • Built-in smart antennas, offering better usage experience
Spécifications essentielles
RG-AP9220 Wi-Fi 7 Indoor AP, Designed for All Indoor Scenarios
The Ruijie RG-AP9220 is a next-generation indoor Access Point (AP) in compliance with Wi-Fi 7 (802.11be). Designed with four spatial streams, the AP achieves a peak data rate of 3.570 Gbps. It supports DC or PoE power supply and comes with 1 x 2.5GE SFP port and 1 x 2.5GBASE-T port, facilitating flexible networking and future-proof scalability. These highlights make it suitable for all indoor scenarios.
Seamless Upgrade to Wi-Fi 7
20% higher peak throughput
2-fold improvement in channel capacity with 320 MHz
Flexible Networking, Future-Proof Expansion
2.5GE SFP port: ready for all-optical networks, effortless upgrade your networks.
2.5GBASE-T port: support existing networks, protect your investments.
Signal Coverage on Demand and Everywhere
Built-in smart antennas locate devices with weak signals and adjust AP signal strength and coverage range to enhance device performance.
Digital Twin Network,
The AP supports intelligent O&M functions, including visualized fault locating, local network optimization, service network optimization, and network optimization in VIP areas.
Spécifications
RG-AP9220
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
Combined peak data rate: 2.976 Gbps:
802.11be
Channels:
Combined peak data rate: 3.570 Gbps:
● Radio 1 – 2.4 GHz: 7.3 Mbps to 0.688 Gbps (MCS0 to MCS13)
Modulation types: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● One built-in omnidirectional antenna, with peak antenna gain of 3.96 dBi.
1 x 100/1000/2.5GBASE-T port
1 x Bluetooth 5.3
1 x system status LED
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Main unit: 200 mm x 200 mm x 40 mm (7.87 in. x 7.87 in. x 1.57 in.)
Shipping: 240 mm x 227 mm x 72 mm (9.45 in. x 8.94 in. x 2.83 in.)
Main unit: 0.56 kg (1.23 lbs)
Mounting bracket: 0.05 kg (0.11 lbs)
Shipping: 0.8 kg (1.76lbs)
Ceiling/Wall-mount
Kensington lock and securing latch
● 48 V DC/0.54 A power input over DC connector
Maximum power consumption: 16 W
DC power: 16 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
802.3at (PoE+): 16 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2
802.3af (PoE): 12.7 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2 (Note: The maximum channel widths in the 2.4 GHz and 5 GHz frequency bands are reduced to 20 MHz and 40 MHz respectively.)
Idle mode: 7.4 W
512 MB DDR3, 128 MB flash
● Maximum transmit power: 22 dBm (158.49 mW)
● Minimum transmit power: 14 dBm (25.12 mW)
● Maximum transmit power: 24 dBm (251.19 mW)
● Minimum transmit power: 15 dBm (31.62 mW)
Wi-Fi Radio Performance
RG-AP9220
2.4 GHz 802.11g
22 dBm
-91 dBm
19 dBm
-85 dBm
18 dBm
-80 dBm
18 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
22 dBm
-85 dBm
17 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
21 dBm
-82 dBm
16 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
22 dBm
-85 dBm
15 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
21 dBm
-82 dBm
14 dBm
-54 dBm
2.4 GHz 802.11be (EHT20)
22 dBm
-85 dBm
15 dBm
-58 dBm
2.4 GHz 802.11be (EHT40)
21 dBm
-82 dBm
14 dBm
-54 dBm
5 GHz 802.11a
24 dBm
-91 dBm
22 dBm
-85 dBm
21 dBm
-80 dBm
20 dBm
-74 dBm
5 GHz 802.11n (HT20)
24 dBm
-85 dBm
-67 dBm
5 GHz 802.11n (HT40)
24 dBm
-82 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
24 dBm
-85 dBm
20 dBm
-67 dBm
5 GHz 802.11ac (VHT40)
24 dBm
-82 dBm
18 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
24 dBm
-82 dBm
-56 dBm
5 GHz 802.11ax (HE20)
24 dBm
-85 dBm
17 dBm
-58 dBm
5 GHz 802.11ax (HE40)
24 dBm
-82 dBm
17 dBm
-54 dBm
5 GHz 802.11ax (HE80)
24 dBm
-82 dBm
-56 dBm
17 dBm
-52 dBm
5 GHz 802.11ax (HE160)
24 dBm
-79 dBm
-53 dBm
17 dBm
-50 dBm
5 GHz 802.11be (EHT80)
24 dBm
-82 dBm
18 dBm
-56 dBm
17 dBm
-52 dBm
MCS13
15 dBm
-46 dBm
5 GHz 802.11be (EHT160)
24dBm
-79 dBm
18 dBm
-53 dBm
17 dBm
-50 dBm
MCS13
15 dBm
-44 dBm
RG-AP9220
RGOS11.9(6)W3B19 or later
Maximum number of WLAN IDs
Mobile unit (MU) location
Application management
MAB authentication
Dynamic Policy
MAC address table size: 1,024
Jumbo frame length: 1,518
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarming
RG-AP9220
EN 301 489-3
EN 301 489-17
EN 300 328
EN IEC 62311
FCC Part 15
EN 62368-1
EN 18031-1
EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9220] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP9220] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Ressources
Informations sur la commande
RG-AP9220
Wi-Fi 7 dual-radio indoor access point
 Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 0.688 Gbps
 Radio 2: 5 GHz: two spatial streams,2x2 MIMO, peak data rate of 2.882 Gbps
The AP consumes one license of an AC.
Fat/Fit/Cloud mode switching. IEEE 802.3af/at-compliant (PoE/PoE+) and DC power supply
Note: The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.54 A.
