RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 1
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 2
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 3
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 4
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 5
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 6
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 7
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 8
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 9
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 10
RG-WALL 1600-Z3200-S Redes para pequeñas y medianas empresas - 11
Serie
Functions
Basic Functions
Deployment scenarios
Routing mode
Transparent mode
Off-path mode
Quick onboarding wizard
Port scan
Traffic learning
Diagnostic center
Security Functions
Policy simulation
Redundant policy optimization
Expired policy optimization
Policy lifecycle management
DDoS attack defense
ARP attack defense
Virus protection templates
Threat intelligence
Management Functions
Visualized service security
Policy delivery on the cloud
Hot patches
SNMP
10G SFP+ Port
Cost-effective
Coping with heavy traffic
Ruijie Cloud Management
Scalable Performance
Flexible expansion by license
Port Scan + Traffic Learning,
knowledge.
1. Port Scan
2. Traffic Learning
3. Policy Generation
Intelligent Diagnostic Center
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Product Performance
Firewall Throughput4
Firewall (Traffic Mix)
IPS1
NGFW1,2
Threat Protection1,3
10 Gbps
1 Gbps
900 Mbps
850 Mbps
800 Mbps
10 Gbps
2 Gbps
1.6 Gbps
1.2 Gbps
900 Mbps
10 Gbps
3 Gbps
2 Gbps
1.6 Gbps
1 Gbps
10 Gbps
1.8 Mpps
Concurrent sessions (TCP)
500000
New sessions/second (TCP)
50000
Firewall policies
3000
SSL VPN throughput(1392-byte)
1.7 Gbps
500
3 Gbps
2.6 Gbps
1000
Product weight
2.9 kg (6.39 lbs)
4.0 kg (8.82 lbs)
1 RU rack
8 x 10/100/1000BASE-T ports
1 x GE SFP port
1 x 10GE SFP+ port
2 x USB 2.0 ports
Storage
Hard disk
RG-NSEC-HDD-1T
0.300 kg (0.661 lbs.)
Connector Type
SATA
Memory Capacity
1 TB
Hard Disk Type
Hard disk drive
Maximum Power Consumption
14 W
Hot Swapping of Hard Disk
Built-in single power module:
l Rated input current: 0.65 A
Max. Power Consumption
< 25 W
0°C to 45°C (32°F to 113°F)
Noise level
43.7 dB
Operating altitude
0–5000 m (0–16404 ft.)
Compliance
EMC SZEM2302000974ATV
LVD SZES2302001034AT
Network
Physical interface
Sub-interface
Bridge interface
Static route
PBR
Routing table
Address management list
Assigned DHCP address list
DNS server
Link detection
VRRP functions
High availability
Object
Address/Address group
Zone
Configuring security zones
Service/Service group
Time plan
Intrusion prevention template
SSL proxy certificate
Server certificate
Security rule base
Content identification
User authentication
Policy
Traffic learning
NAT
NAT and NAT policies
Policy import
Batch import of NAT policies
ALG
Server mapping
Address pool
Security policy
Security policy
Simulation policy
Policy configuration wizard
Policy optimization
Policy lifecycle
Port scan
DoS/DDoS attack defense
ARP attack defense
Local defense
Blocklist/Allowlist
SSL proxy policy
SSL proxy template
Allowlist
Allowlist
Behavior analysis
System
Administrator
Administrator role
Clock configuration
Service parameter
SD-WAN
Authorization management
Device information
System restart
System upgrade
Upgrading the system
Patch installation
Configuration backup
Factory settings restoration
Signature library upgrade
Cloud management platform
Device binding
Ping
Ping for troubleshooting
Tracert
Tracert for troubleshooting
Packet obtaining tool
One-click collection
Device health
Device health diagnosis
Service diagnosis
Service continuity diagnosis
Breakdown record
Breakdown information records
Device log retention
Videos
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls LDAP Configuration Guide
Oct. 28, 2025
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls Traffic Control Policy Configuration Guide
Oct. 28, 2025
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls IPsec VPN (Hub-and-Spoke) Configuration Guide
Oct. 28, 2025
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls Threat Intelligence Configuration Guide
Oct. 28, 2025
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls Source NAT44 Configuration Guide
Oct. 28, 2025
Ruijie RG-WALL 1600-Z-S Series Cloud-Managed Firewalls Load Balancing Configuration Guide
Oct. 28, 2025
Rapid Deployment of RG-WALL 1600-Z-S Series Firewall on Ruijie Reyee App (Transparent Mode)
Oct. 27, 2023
How to Install RG-WALL 1600-Z3200-S Cloud-Managed Firewall
Sep. 27, 2023
Views
Información de pedido
RG-WALL 1600-Z3200-S-LIS-M-1Y
RG-WALL 1600-Z3200-S-LIS-E-1Y
RG-NSEC-HDD-1T¹
RG-WALL 1600-Z3200-S-UA-G-LIC
