RG-S5310-24GT4XS-E Switches - 1
RG-S5310-24GT4XS-E Switches - 2
RG-S5310-24GT4XS-E Switches - 3
RG-S5310-24GT4XS-E Switches - 4
RG-S5310-24GT4XS-E Switches - 5
RG-S5310-24GT4XS-E Switches - 6
RG-S5310-24GT4XS-E Switches - 7
RG-S5310-24GT4XS-E Switches - 8
RG-S5310-24GT4XS-E Switches - 9
RG-S5310-24GT4XS-E Switches - 10
RG-S5310-24GT4XS-E 24-Port GE Layer 3 Managed Access Switch, 4-Port 10GE Uplink
  • Rich port types, 24 x 10/100/1000BASE-T ports for access, 4 x 1GE/10GE SFP+ ports for uplink
Layer 3 Access Switch for 10G Uplink RG-S5310-24GT4XS-E
24 x 10/100/1000BASE-T ports, providing high-speed network experience for short-distance services
Hot-Swappable Dual Power Modules, Dual Protection for Links
Hot-swappable dual power modules are provided for 1+1 power redundancy. Seamless power module failover can be realized if one power module fails, providing dual protection for links
achieving automatic O&M.
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-24GT4XS-P-E
RG-S5310-48GT4XS-P-E
24 x 1GE SPF ports
48 x 1GE SPF ports
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-PA70IB
RG-PD150IB-F
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
115 Mpps
158 Mpps
115 Mpps
158 Mpps
115 Mpps
158 Mpps
154 Gbps
211 Gbps
154 Gbps
211 Gbps
154 Gbps
211 Gbps
3 MB
32,000
4,000/16,000 (authorized)
ND table size
2,000/8,000 (authorized)
8,000/12,000 (authorized)
2,500
1,200
Ingress: 3,500
Egress: 1,500
Number of IGMP groups
2,500
Number of MLD groups
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
4.0 kg
(8.82 lbs)
4.3 kg
(9.48 lbs)
4.2 kg
(9.26 lbs)
4.5 kg
(9.92 lbs)
4.3 kg
(9.48 lbs)
4.6 kg
(10.14 lbs)
6.20 kg (13.67 lbs)
6.50 kg (14.33 lbs)
6.38 kg (14.07 lbs)
6.58 kg (14.51 lbs)
6.78 kg (14.95 lbs)
6.69 kg (14.75 lbs)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-PA150IB-F (AC input)
RG-PD150IB-F (DC input):
RG-PA70IB (AC input):
● Maximum input current: 2 A
RG-PA70IB: 70 W
RG-PD150IB-F: 150 W
RG-PD150IB-F: 150 W
55 W
85 W
108 W
65 W (without PoE load)
810 W (full PoE load)
75 W (without PoE load)
1,570 W (full PoE load)
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
27°C (80.6°F): 34.3 dB
45°C (113°F): 56.5 dB
27°C (80.6°F): 40.8 dB
45°C (113°F): 52.4 dB
27°C (80.6°F): 38.9 dB
45°C (113°F): 53.7 dB
27°C (80.6°F): 51.6 dB
45°C (113°F): 57.4 dB
45°C (113°F): 58.3 dB
Air discharge: 8 kV
Contact discharge: 6 kV
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
RG-S5310-E Series
Ethernet Switching
Super VLAN and private VLAN
Basic QinQ and selective QinQ
Auto errdisable recovery
BPDU filter
Port fast
Root guard
MAC address filtering
GRE tunnel
IP Routing
IPv4 and IPv6 static routing
OSPFv2, OSPFv3, and GR
IPv4/IPv6 PBR
IGMPv1/v2 snooping
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
Global IP-MAC binding
MAB authentication
Basic LACP
Inter-VSU AP
Hot swapping of power modules
Local and remote stacking
SPAN, RSPAN and ERSPAN
SNTP
CLI (Telnet/Console)
SNMP v1/v2/c3
Web
Syslog/Debug
MACC
VXLAN (authorized)
Información sobre pedidos
RG-S5310-24GT4XS-E
RG-S5310-48GT4XS-E
RG-S5310-24SFP4XS-E
RG-S5310-48SFP4XS-E
Power Module
RG-PA70IB
70 W AC power module
RG-PD150IB-F
150W DC power module
License
RG-VXLAN-MPLS-ENTRY-LIC
Optical Transceivers
Preguntas frecuentes
