RG-AP880-L Redes para pequeñas y medianas empresas - 1
RG-AP880-L Redes para pequeñas y medianas empresas - 2
RG-AP880-L Redes para pequeñas y medianas empresas - 3
RG-AP880-L Redes para pequeñas y medianas empresas - 4
RG-AP880-L Redes para pequeñas y medianas empresas - 5
RG-AP880-L Redes para pequeñas y medianas empresas - 6
RG-AP880-L Redes para pequeñas y medianas empresas - 7
RG-AP880-L Redes para pequeñas y medianas empresas - 8
RG-AP880-L Redes para pequeñas y medianas empresas - 9
RG-AP880-L Redes para pequeñas y medianas empresas - 10
Higher Speed and Wider Channels with Wi-Fi 6E
Indoor Access Point RG-AP880-L
Wi-Fi 6E Wi-Fi 6E
Max. Data Rate: 7.780 Gbps Max. Data Rate: 7.780 Gbps
PoE/DC Power Supply PoE/DC Power Supply
Free cloud management Free cloud management
Wi-Fi 6E technology, supporting 6 GHz frequency band with wider spectrum resources and achieving fast and stable data transmission of up to 7.780 Gbps.
High concurrency
OFDMA and MU-MIMO technologies, supporting up to 100 concurrent clients
Low latency
OFDMA and BSS Coloring technologies, reducing latency to 10 ms
Secure connectivity
WPA3 encryption, greatly improving wireless connection security
Target Wake Time (TWT) for reducing the service period (SP) of clients, saving 30% of energy.
7.780
Gbps
Radio Isolation, Minimal Interference and
Stable Wireless Connections
Tri-radio design, enabling independent operation in 2.4 GHz, 5 GHz, and 6 GHz bands while ensuring no interference between them.
Intelligent channel optimization and precise radio isolation, ensuring pure and stable signal transmission.
Intelligent optimization, enabling balanced connections, efficient bandwidth allocation, and superior network performance for each client.
6 GHz Band, Delivering Greater Capacity
6 GHz frequency band and smart antennas, providing uninterrupted signals upon client movement and intelligent signal strength adjustment, and achieving optimal signal coverage. OFDMA technology, allowing for efficient network connections even in high-density scenarios. Plug-and-play, enabling efficient and stable connections.
Remote monitoring
Remote Wi-Fi management
Cloud portal authentication
RG-AP880-L
Unit dimensions
Main unit: 1.0 kg (2.20 lbs)
13.67 kg (30.14 lbs)
RG-AP880-L
Tri-radio and up to eight spatial streams:
● Radio 1: 2.4GHz: Two spatial streams, 2x2 MU-MIMO
● Radio 2: 5GHz: Two spatial streams, 2x2 MU-MIMO
● Radio 3: 6GHz: Four spatial streams, 4x4 MU-MIMO
Operating frequencies
Radio 1: 802.11b/g/n/ax
● 2.400 GHz to 2.483 GHz, channels 1 to 13
Radio 2: 802.11a/n/ac/ax
Radio 3: 802.11ax
● 5.925 GHz to 7.125 GHz, U-NII-4, channels 1 to 233
Data rates
Combined peak data rate: 7.780 Gbps
Radio 1: 2.4 GHz, 574 Mbps
Radio 2: 5 GHz, 2.402 Gbps
● Two spatial stream Single User (SU) MIMO for up to 2.402 Gbps wireless data rate to individual 4SS HE160 802.11ax client devices (maximum)
Radio 3: 6 GHz, 4.804 Gbps
Data rate set
● 802.11b: 1, 2, 5.5, 11
● 802.11n: 6.5 to 300 (MCS0 to MVC31, HT20 to HT40)
● 802.11ac: 6.5 to 1,733 (MCS0 to MCS9, NSS = 1 to 4, VHT20 to VHT160)
● 802.11ax: 8.6 to 2,402 (MCS0 to MCS11, NSS = 1 to 4, HE20 to HE160)
6 GHz
● 802.11ax:8.6 ~ 4,804 (MCS0 ~ MCS11, NSS = 1 to 4, HE20 to HE160)
Packet aggregation
Built-in omnidirectional antennas (two 2.4 GHz antennas, two 5 GHz antennas and four 6 GHz antennas)
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 5 dBi
6 GHz: 5 dBi
Maximum transmit power
2.4 GHz: 27 dBm (24dBm per chain)
5 GHz: 26 dBm (23dBm per chain)
6 GHz: 26 dBm (23dBm per chain)
Thailand
5.470 GHz to 5.725 GHz, EIRP ≤ 30 dBm
5.945 GHz to 6.425 GHz, EIRP ≤ 23 dBm
Vietnam:
5150-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, and CCK
RG-AP880-L
Maximum Receive Sensitivity
 per Receive Chain
24 dBm
–96 dBm
24 dBm
–95 dBm
–93 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–62 dBm
24 dBm
–88 dBm
5GHz 802.11a
22 dBm
22 dBm
21 dBm
–74 dBm
5GHz 802.11n (HT20)
–90 dBm
–68 dBm
5GHz 802.11n (HT40)
–88 dBm
–68 dBm
5GHz 802.11ac (VHT20)
–90 dBm
–68 dBm
5GHz 802.11ac (VHT40)
–88 dBm
–63 dBm
5GHz 802.11ac (VHT80)
5GHz 802.11ax (HE20)
–90 dBm
5GHz 802.11ax (HE40)
–86 dBm
–56 dBm
5GHz 802.11ax (HE80)
–83 dBm
5GHz 802.11ax (HE160)
–81 dBm
–51d Bm
6GHz 802.11ax (HE20)
22 dBm
–90 dBm
6GHz 802.11ax (HE40)
22 dBm
–86 dBm
–56 dBm
6GHz 802.11ax (HE80)
22 dBm
–83 dBm
6GHz 802.11ax (HE160)
22 dBm
–81 dBm
–51 dBm
Bluetooth Radio
Bluetooth Radio
RG-AP880-L
Bluetooth 5.1
Maximum antenna gain
4.6 dBi, with roughly 30 degrees downtilt
10 dBm (Class 1)
Receive sensitivity
–98 dBm
RG-AP880-L
● Auto MDI/MDIX crossover
● PoE-PD: 54 V DC (nominal) 802.3af/at/bt(Class 3 or higher)
● 802.3az EEE
1 x 10/100/1000BASE-T port
● 802.3az EEE
USB 3.0 (Type-A connector)
RG-AP880-L
● 54 V DC/1.1 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter is delivered with the main unit.
● When powered by 802.3af (PoE), the AP starts up normally. 2.4 GHz, 5 GHz and 6 GHz radio cards can work only in one spatial stream mode . LAN 2 and USB port cannot supply power to external devices.
Overall power consumption
Maximum power consumption: 40 W
DC powered: 40 W
PoE+ powered (802.3at): 23 W
PoE++ powered (802.3bt): 40 W
Idle mode: 10.3 W
RG-AP880-L
Operating temperature: –10°C to 50°C (14°F to 122°F)
Operating humidity: 5% to 95% (non-condensing)
Storage humidity: 5% to 95% (non-condensing)
RG-AP880-L
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
ETSI EN 303 687
EN IEC 62311
FCC Part 15
Applicable Software Version
RG-AP880-L
RGOS11.9(6)W3B4 or higher
RG-AP880-L
Recommended maximum number of active devices per AP
300
1536
 Note
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP880-L
WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal, WPA2-Enterprise, WPA3-Personal (WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP), WPA3-Enterprise (GCMP), WPA3-OWE, WPA3-OWE transition mode
Dynamic ACL assignment
RG-AP880-L
IP service
NAT, FTP ALG, DNS ALG
IPv6 basics
IPv6 DHCP Client
PPPoE Client
RG-AP880-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
When the AP works in Cloud mode, it can be managed through Ruijie Cloud.
Información sobre pedidos
RG-AP880-L
Wi-Fi 6E tri-radio wireless access point
2.4 GHz 2 x 2:2 MU-MIMO + 5 GHz 2 x 2:2 MU-MIMO + 6 GHz 4 x 4: 4 MU-MIMO
Up to eight spatial streams
Data rate of up to 7.780 Gbps
Compliance with IEEE 802.11a/b/g/n/ac and 802.11ax
Fat/fit/cloud mode switchover
Each AP occupying one wireless controller license
