High-density 400GE/100GE ports, supporting high-bandwidth and large-capacity server access
| Item |
RG-S6580-48CQ8QC |
RG-S6580-24DC8QC |
| Dimensions (W x D x H) |
442 mm x 670 mm x 43.6 mm (17.40 in. x 26.38 in. x 1.72 in.) |
| Rack height |
1 RU |
1 RU |
| Unit weight |
11.5 kg (25.35 lbs., a chassis with two power modules and six fan modules) |
11 kg (24.25 lbs., a chassis with two power modules and six fan modules) |
| Switching capacity |
16.0 Tbps |
16.0 Tbps |
| Packet forwarding rate |
2680 Mpps |
2680 Mpps |
| Service port |
48 x 100G DSFP ports 8 x 100G/400G QSFP-DD ports |
24 x 100G/200G QSFP56 ports 8 x 100G/400G QSFP-DD ports |
| Management port |
1 x RJ45 console port 1 x RJ45 MGMT port |
| USB port |
1 x USB 2.0 port (Type A connector) |
| Module slot |
2 x power module slots 6 x fan module slots |
| Power consumption |
Maximum power consumption: 742 W Typical power consumption: 633 W Static power consumption: 178 W |
Maximum power consumption: 850 W Typical power consumption: 700 W Static power consumption: 300 W |
| Power input |
RG-PA1200I-F (AC input) Rated input voltage: 100 V AC to 127 V AC, 200 V AC to 240 V AC, 50 Hz/60Hz Maximum input voltage: 90 V AC to 140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 13.8 A(100 V AC to 127 V AC) 8.5 A (200 V AC to 240 V AC) Power port type: C14
RG-PA1200I-F (HVDC input): Rated input voltage: 240 V DC Maximum input voltage: 180 V DC to 300 V DC Rated current: 6.5 A Power port type: C14 |
| Temperature |
Operating temperature: 0°C to 40°C (32°F to 104°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) Note: At altitudes ranging from 1800 m (5,905.51 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation. |
| Humidity |
| Altitude |
Operating altitude: ≤ 5,000 m (16,404.20 ft.) Storage altitude: ≤ 5000 m (16,404.20 ft.) |
| Cooling |
Air cooling, front-to-rear airflow (port-side intake) |
| Item |
RG-S6580-48CQ8QC |
RG-S6580-24DC8QC |
| Layer 2 Protocols |
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB) |
| Layer 3 Protocols (IPv4) |
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, Policy-based Routing (PBR), route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP |
| IPv6 Basic Protocols |
Neighbor Discovery, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS |
| IPv6 Features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+ |
| Data Center Features |
PFC, ECN, and other data center features RDMA VXLAN bridge VXLAN gateway IPv6 VXLAN over IPv4 IPv4 VXLAN over IPv4 ECN over VXLAN PFC over VXLAN |
| Visualization |
gRPC sFlow sampling IPFIX |
| QoS |
Mapping of IEEE 802.1p, DSCP, and ToS priorities |
| HA Design |
GR for RIP/OSPF/BGP, BFD, DLDP, REUP dual-link fast switching, RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swapping for all cards and power supply modules |
| Security Features |
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management |
| Management Mode |
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm |
| Other Protocols |
DHCP client, DHCP relay, DHCP server, DNS client, ARP proxy, and Syslog |
Chassis, Fan Module
| Product Model |
Description |
| RG-S6580-48CQ8QC |
48 × 100GE DSFP ports + 8 × 400GE QSFP-DD ports Two power slots and six fan slots The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules. |
| RG-S6580-24DC8QC |
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports Two power slots and six fan slots The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules. |
Power Supply Module
| Product Model |
Description |
| RG-PA1200I-F |
1200 W AC module (AC/240 V HVDC) |
Fan Module
| Product Model |
Description |
| M1HFAN II-F |
Fan module (front-to-rear ventilation) |
100GE Optical Transceivers
| Model |
Description |
| 100G-AOC-5M |
100G AOC, QSFP28 form factor, 5 m (16.40 ft.) |
| 100G-AOC-10M |
100G AOC, QSFP28 form factor, 10 m (32.81 ft.) |
| 100G-QSFP-SR-MM850 |
100G SR optical transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over multimode fiber (MMF) |
| 100G-QSFP-iLR4-SM1310 |
100G iLR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF |
| 100G-QSFP-LR4-SM1310 |
100G LR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF |
| 100G-QSFP-ER4-SM1310 |
100GE ER4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 40 km (131,233.60 ft.) over SMF |
400GE Optical Transceivers
| Model |
Description |
| 400G-QDD-SR8-MM850 |
400G optical transceiver, QSFP-DD form factor, MPO-16 APC, 850 nm, 100 m (328.08 ft.) over MMF |
| 400G-QDD-DR4-SM1310 |
400G optical transceiver, QSFP-DD form factor, MPO-12 APC, 1310 nm, 500 m (1,640.42 ft.) over SMF |
| 400G-QDD-FR4-SM1310 |
400G FR4 module, QSFP-DD form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF |
| *400G-QDD-ZR-SM1550 |
400G ZR optical transceiver, QSFP-DD, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF |
For more information about optical transceiver compatibility, refer to Ruijie RG-S6580 Series Data Center Switches Optical Transceiver Compatibility Matrix.
