RG-SAP150-SP-W Wireless - 1
RG-SAP150-SP-W Wireless - 2
RG-SAP150-SP-W Wireless - 3
RG-SAP150-SP-W Wireless - 4
RG-SAP150-SP-W Wireless - 5
RG-SAP150-SP-W Wireless - 6
RG-SAP150-SP-W Wireless - 7
RG-SAP150-SP-W Wireless - 8
RG-SAP150-SP-W Wireless - 9
RG-SAP150-SP-W Wireless - 10
RG-SAP150-SP-W Wireless - 11
Key Specification View More
WaaS Series Wall-Plate Access Point
86 mm Junction Box RG-SAP150-SP-W
Scenarios
PoE Input
2.4 GHz/5 GHz Dual-Radio
Three Spatial Streams
Max Data Rate 733 Mbps
Max Power Consumption 8 W
Ultra-Thin and Stylish Design, Ease of Use
10 mm Ultra-Thin | Stylish | Secure and User-Friendly
Secure Access for All Scenarios,
Enterprise-Level Security Protection
Comprehensive Authentication
Security Protection
PSK, WPA, WPA2,
and WAP Authentication
(for retail stores)
802.1X
Authentication
(enterprise-level)
Web-based
Authentication
(enterprise-level)
QR Code-based Guest Authentication
(for guest management scenarios such
as meeting rooms and cafes)
SMS-based Authentication
(for public areas such
as mall lobbies)
Fat/Fit Mode Switching, Flexible Networking,
Easy Network Expansion
Fat/Fit mode switching caters to diverse networking requirements, enabling
plug-and-play and smooth upgrade from a small-scale network to a medium- or large-scale network, This allows flexible networking and maximizes the return on investment (ROI).
Suitable for medium- and large-scale network construction. In fit mode, the AP needs to work with a Ruijie access controller (AC) that can centrally manage multiple APs, achieving Zero-Touch Provisioning and plug-and-play while simplifying wireless management.
Suitable for small-scale network construction. In fat mode, the AP can work independently without an AC, reducing wireless networking costs.
One Ethernet Cable for Power and Data Transmission
PoE input is adopted, eliminating the need for external power supply and high-voltage construction. This saves both time and effort during installation.
The AP can be installed wherever the Ethernet cable is routed, enabling plug-and-play and convenient network connection.
WIS Cloud enables network-wide configuration and optimization, eliminating the need for on-site operations.
Network issue warnings allows wireless networks to be monitored anytime and anywhere.
Go to WIS Cloud >>
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
RG-SAP150-SP-W
Three spatial streams
● Radio 2 – 5 GHz: 1x1 MIMO, one spatial streams
Channels:
One spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 433 Mbps
● Radio 2 – 5 GHz: 6.5 Mbps to 433 Mbps (MCS0 to MCS9)
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 3 dBi.
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5 dBi.
Uplink: 1 x 10/100BASE-T port, compliant with IEEE 802.3af/at standard (PoE/PoE+)
Downlink: 1 x 10/100BASE-T port
● CAPWAP tunnel timeout
Main unit: 86 mm x 86 mm x 40 mm (3.39 in. x 3.39 in. x 1.57 in.)
Shipping: 125 mm x 115 mm x 60 mm (4.92 in. x 4.53 in. x 2.36 in.)
Main unit: 0.1 kg (0.22 lbs)
Shipping: 0.18 kg (0.40 lbs)
86 mm junction box-mount
PoE input over the WAN port: compliance with 802.3af (PoE)
Maximum power consumption: 8 W
● DC power: 8 W, 2.4 GHz radio 2x2, 5 GHz radio 1x1.
● 802.3af (PoE) : 8 W, 2.4 GHz radio 2x2, 5 GHz radio 1x1.
● Idle mode: 6.02 W
Storage altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
Operating altitude: 0 m to 3,000 m (0 ft. to 9,842.52 ft.)
128 MB DRAM, 32 MB flash
● Maximum transmit power: 20 dBm (100 mW)Note:
RG-SAP150-SP-W
2.4GHz 802.11b
17 dBm
–90 dBm
15 dBm
–87 dBm
2.4GHz 802.11g
–78 dBm
15 dBm
–72 dBm
2.4GHz 802.11n (HT20)
15 dBm
–67 dBm
2.4GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11a
–78 dBm
15 dBm
–72 dBm
5GHz 802.11n (HT20)
15 dBm
–67 dBm
5GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11ac (VHT20)
13 dBm
–67 dBm
5GHz 802.11ac (VHT40)
13 dBm
–57 dBm
5GHz 802.11ac (VHT80)
13 dBm
Note: Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
Basic Functions
RG-SAP150-SP-W
RGOS11.1(5)B0 or higher
● 2.4 GHz radio: 156 STAs
● 5 GHz radio: 100 STAs
16 (up to 8 BSSIDs per radio)
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise
MAC address table size: 1,024
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 40
VLAN ID range: 1–4,094
ARP entry aging and proxy ARP
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
SNMPv1/v2c
Telnet and TFTP Management
RG-SAP150-SP-W
RG-SAP150-SP-W
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN IEC 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, EN 50665, EN 62311, FCC Part 15, and EN IEC 62311
RG-SAP150-SP-W
Wi-Fi 5 dual-radio wireless access point
Three spatial streams, peak data rate of 733 Mbps
802.11a/b/g/n/ac, switching between Fat, Fit, and cloud modes, and 802.3af PoE power supply
Note: The power source equipment (PSE) needs to be purchased separately.
Technical Support
Technical Support
Get in Touch
Get in Touch
