RG-S6510-32CQ Redes para datacenter - 1
RG-S6510-32CQ Redes para datacenter - 2
RG-S6510-32CQ Redes para datacenter - 3
RG-S6510-32CQ Redes para datacenter - 4
RG-S6510-32CQ Redes para datacenter - 5
RG-S6510-32CQ Redes para datacenter - 6
RG-S6510-32CQ Redes para datacenter - 7
RG-S6510-32CQ Redes para datacenter - 8
RG-S6510-32CQ Redes para datacenter - 9
RG-S6510-32CQ Redes para datacenter - 10
RG-S6510-32CQ Redes para datacenter - 11
RG-S6510-32CQ Data Center 100GE DCI Access Switch
They are highlighted by their high performance, high density, and the data speed of up to 100 Gbps. They meet the Spine-Leaf network architecture design requirements.
  • Non-blocking Data Center Networks and Powerful Cache Capacity
  • Hardware-level redundancy, ensuring nonstop services
  • Lossless Ethernet, ensuring zero packet loss in RDMA E2E communication
  • Telemetry network monitoring and automatic O&M, making management simple and efficient
Principais especificações
Data Center 100GE Access Switch RG-S6510-32CQ
32 x 100GE QSFP28 ports, delivering line-rate forwarding capacity, multiple forms of split interfaces, and adaptation to different scenarios
32 MB buffer and advanced buffer scheduling mechanism, providing fast data processing and easily coping with burst traffic
Hot-swappable redundant power modules
Hot-swappable redundant fan modules
Power modules in 1+1 redundancy mode, and failover in seconds, providing nonstop services
De-stacking
M-LAG
With RDMA technology, data does not need to be handled by the CPU during device communication. This reduces the CPU burden and effectively solves the network latency problem.
Especificações
RG-S6510-48VS8CQ
RG-S6510-32CQ
442 mm x 560 mm x 44 mm (17.40 in. x 22.05 in. x 1.73 in.)
5.6 kg (12.35 lbs., empty chassis)
8.2 kg (18.08 lbs., a chassis with two power modules and four fan modules)
8.4 kg (18.52 lbs., empty chassis)
11.4 kg (25.13 lbs., a chassis with two power modules and five fan modules)
4.0 Tbps
6.4 Tbps
2000 Mpps
2030 Mpps
Service port
48 x 10G/25G SFP28 ports
8 x 40G/100G QSFP28 ports
32 x 100G QSFP28 ports
Management port
4 x fan module slots
5 x fan module slots
Typical power consumption: 172 W
Maximum power consumption: 450 W
Typical power consumption: 270 W
Static power consumption: 150 W
RG-PA550I-F (AC input):
Rated input voltage:
100V AC to 240V AC, 50 Hz/60Hz
Maximum input voltage:
90 V AC to140 V AC, 180 V to 264 V AC, 47 Hz to 63 Hz
Rated input current:
7.2 A to3.5 A(100 V AC to 240 V AC)
Power port type: C14
RG-PA550I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 3.6 A
RG-PA550I-R (AC input):
100 V AC to 240 V AC, 50 Hz/60 Hz
90 V AC to140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz
7.2 A to 3.5 A(100 V AC to 240 V AC)
RG-PA550I-R (HVDC input):
RG-PHD550I-F (AC input):
100 V AC to240 V AC, 50 Hz/60 Hz
90 V AC to 264 V AC, 47 Hz to 63 Hz
Rated input current: 10 A
RG-PHD550I-F (HVDC input):
Rated input voltage: 336 V DC
RG-PD800I-F (DC input):
Rated input voltage: –48 V DC
Rated input current: 23 A
Note: At altitudes ranging from 1800 m (5905.51 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation.
Note: At altitudes ranging from 3000 m (9842.52 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation.
Air cooling, front-to-rear airflow (port-side intake): used with the RG-PA550I-F, RG-PD800I-F, and RG-PHD550I-F power modules
Air cooling, rear-to-front airflow (port-side exhaust): used with the RG-PA550I-R power module
RG-S6510-48VS8CQ
RG-S6510-32CQ
Layer 2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and Selective QinQ), GVRP
Layer 3 Protocols (IPv4)
IPv6 Basic Protocols
IPv6 Features
Data Center Features
IPv6 VXLAN over IPv4 and EVPN VXLAN
PFC, ECN, and RDMA
M-LAG
OpenFlow 1.3
Visualization
sFLOW sampling
INT
Priority marking/remarking
Virtualization
Virtual Switching Unit
Buffer Management
HA Design
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management
Management Mode
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, Python, fan and power alarm, and temperature alarm
Other Protocols
Informações do pedido
RG-S6510-48VS8CQ
48 × 25GE ports and 8 × 100GE ports.
Two power supply module slots and four fan module slots.
The power module model is RG-PA550I-F, and the fan model is M6510-FAN-F.
RG-S6510-32CQ
Provides 32 × 100G ports.
Two power supply module slots and five fan module slots.
The power module model is RG-PA550I-F, and the fan model is M1HFAN I-F.
Fan and Power Supply Modules
RG-PA550I-F
550 W power supply module (AC and 240 V HVDC)
RG-PA550I-R
550 W power supply module (port-side exhaust, supporting AC and 240 V HVDC), applicable only to RG-S6510-48VS8CQ
RG-PHD550I-F
550 W power supply module (336 V HVDC), applicable only to RG-S6510-48VS8CQ
RG-PD800I-F
800 W AC power module (48 V LVDC)
M6510-FAN-F
Fan module of RG-S6510-48VS8CQ, supporting 3+1 redundancy, hot swapping, and front-to-rear ventilation design.
M1HFAN I-F
Fan module of RG-S6510-32CQ, supporting 4+1 redundancy, hot swapping, and front-to-rear ventilation design.
25GE Optical Transceivers
VG-SFP-AOC5M
25G AOC, SFP28 form factor, 5 m (16.40 ft.)
25G LR optical transceiver, SFP28 form factor, LC, 1310 nm, 10 km (32,808.40 ft.) over single-mode fiber (SMF)
40G Optical Transceivers
100G Optical Transceivers
For more information about optical transceiver compatibility, refer to Ruijie RG-S6510 Series Data Center Switches Optical Transceiver Compatibility Matrix.
Perguntas frequentes
