RG-AP680-CD(V3) Sem fio - 1
RG-AP680-CD(V3) Sem fio - 2
RG-AP680-CD(V3) Sem fio - 3
RG-AP680-CD(V3) Sem fio - 4
RG-AP680-CD(V3) Sem fio - 5
RG-AP680-CD(V3) Sem fio - 6
RG-AP680-CD(V3) Sem fio - 7
RG-AP680-CD(V3) Sem fio - 8
RG-AP680-CD(V3) Sem fio - 9
RG-AP680-CD(V3) Sem fio - 10
RG-AP680-CD(V3) Sem fio - 11
RG-AP680-CD(V3), Wi-Fi 6 Dual-Radio 2.976 Gbps Outdoor Access Point, Directional Antennas
  • Built-in Directional Antennas, Focused Coverage and Strong Signal
Principais especificações
RG-AP680-CD(V3) Wi-Fi 6 Outdoor Access Point
Directional
Antennas
160 MHz
Max. Data Rate
2.976 Gbps
IP68
Max number of
associated STAs 1024
2.5G SFP port
Gigabit Ethernet port
28 dBm transmit power enables strong signal beam.
The design applies to outdoor scenarios such as streets and security monitoring backhaul.
IP68
Wide Temperature Range
Lightning Protection
IP68 dustproof and waterproof
160MHz 丨 2.976 Gbps
Go to WIS Cloud Network
Cloud O&M
24 h Network Optimization
Real-Time Warning
Fault Locating
Especificações
RG-AP680-CD(V3)
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in directional antennas, with peak antenna gain of  9 dBi.
● 5 GHz: two built-in directional antennas, with peak antenna gain of 9 dBi.
● One integrated vertically polarized omnidirectional antenna, t with peak antenna gain of 4.5 dBi.
1 x 2.5GE SFP port
1 x 10/100/1000Base-T port
1 x Bluetooth 5.0
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Whether bridging is enabled
Main unit: 1.5 kg (3.31 lbs)
Shipping: 2.92 kg (6.44 lbs)
● DC power: 12.95 W
● 802.3at (PoE+): 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6 W
512 MB DRAM, 128 MB flash
● Maximum transmit power: 28 dBm (631mW)
● Minimum transmit power: 10 dBm (10 mW)
RG-AP680-CD(V3)
25 dBm
–92 dBm
25 dBm
25 dBm
–84 dBm
25 dBm
–78 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–63 dBm
25 dBm
–84dBm
25 dBm
–51 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–81 dBm
–63 dBm
25 dBm
–84 dBm
19 dBm
–61 dBm
25 dBm
–81 dBm
19 dBm
–56 dBm
25 dBm
–78 dBm
19 dBm
25 dBm
–84 dBm
25 dBm
–81 dBm
–51 dBm
25 dBm
–78 dBm
–48 dBm
5 GHz, 802.11ax (HE160)
25 dBm
–73 dBm
–43 dBm
RG-AP680-CD(V3)
RGOS11.9(6)W2B4 or later
128
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
Dynamic Policy
CoA/DM
ACL REMARK
MAC address table size: 1,024
Jumbo frame length: 1518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-AP680-CD(V3)
Big data capabilities
RG-AP680-CD(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN 62311, EN IEC 62311, IEC 62368-1, EN 50665, EN 62368-1, IEC 60950-22, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-CD(V3)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-CD(V3)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Informações do pedido
RG-AP680-CD(V3)
802.11ax-compliant outdoor wireless access point
Perguntas frequentes
