RG-AP180 Redes para pequenas e médias empresas - 1
RG-AP180 Redes para pequenas e médias empresas - 2
RG-AP180 Redes para pequenas e médias empresas - 3
RG-AP180 Redes para pequenas e médias empresas - 4
RG-AP180 Redes para pequenas e médias empresas - 5
RG-AP180 Redes para pequenas e médias empresas - 6
RG-AP180 Redes para pequenas e médias empresas - 7
RG-AP180 Redes para pequenas e médias empresas - 8
RG-AP180 Redes para pequenas e médias empresas - 9
RG-AP180, Wi-Fi 6 Dual Radio 1.775 Gbps Indoor Wall Plate Wireless AP
Recommended for indoor scenarios such as dormitories, offices, hotels, stores, and classrooms
  • Multi-service Linkage, All-in-One for Office Scenarios
  • 1.775 Gbps Ultra-Fast Speed with Wi-Fi 6
  • Full-Scenario Enterprise-class Authentication for Enhanced Security
  • Ruijie Cloud Management, Intelligent Optimization, and Easy O&M
Principais especificações
RG-AP180 Indoor Wall Plate Wireless Access Point
Scenario
2.4 GHz and 5 GHz Dual Radios
Four Spatial Streams
PoE and DC Power Input
Combined Rate Up to 1.775 Gbps
Max. Power Consumption of 10 W
1.775
Gbps
High speed
With 1024-QAM modulation, the data transmission rate is 25% higher than 802.11ac.
High concurrency
OFDMA and MU-MIMO are introduced to ensure stable access of multiple STAs
High security
The next-generation wireless encryption protocol WPA3 greatly improves the
Low latency
OFDMA is applied to transmit data to multiple STAs simultaneously. The latency is as low as 20 ms.
Remote monitoring
Remote Wi-Fi management
Cloud portal authentication
Especificações
RG-AP180
Unit dimensions
(W x H x D)
In-wall: 86 mm x 116 mm x 19 mm (3.39 in. x 4.57 in. x 0.75 in.)
Above-wall: 86 mm x 116 x mm x 24 mm (3.39 in. x 4.57 in. x 0.94 in.)
(W x H x D)
375 mm x 499 mm x 160 mm (14.76 in. x 19.65 in. x 6.30 in.)
0.19 kg (0.42 lbs)
9.67 kg (21.32 lbs)
Wall-mount
Junction box-mount (86 mm/European-standard junction box)
Note: If you want to use an American-standard junction box, purchase an RG-AP180-MNT mounting bracket separately.
Elegant white
RG-AP180
Operating frequencies
Radio 1: 802.11b/g/n/ax
● 2.400 GHz to 2.4835 GHz, ISM, channels 1 to 13
Radio 2: 802.11a/n/ac/ax
Egypt
Data rates
Radio 1: 2.4 GHz, 574 Mbps
Radio 2: 5 GHz, 1.201 Gbps
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
Built-in intelligent antennas (two 2.4 GHz antennas and two 5 GHz antennas)
Antenna gain
2.4 GHz: 2.5 dBi
5 GHz: 5.5 dBi
Maximum transmit power
Thailand
Egypt
Vietnam
2.400 GHz to 2.4835 GHz, EIRP ≤ 23 dBm
5.725 GHz to 5.850 GHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP180
17 dBm
–90 dBm
15 dBm
–87 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–77 dBm
15 dBm
–64 dBm
12 dBm
–58 dBm
12 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
13 dBm
13 dBm
–57 dBm
13 dBm
12 dBm
–58 dBm
12 dBm
12 dBm
–52 dBm
Bluetooth Radio
RG-AP180
Bluetooth 5.0
Maximum antenna gain
10 dBm
Receive sensitivity
–88 dBm (@BLE)
Ports Specifications
RG-AP180
Uplink:
1 x 10/100/1000BASE-T port, in compliance with IEEE 802.3af/802.3at standard (PoE/PoE+).
Downlink:
4 x 10/100/1000BASE-T ports
1 x Micro USB console port (under the decorative cover)
RG-AP180
● 12 V DC/1 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
● PoE input over the PoE-in port: The power source equipment (PSE) complies with the IEEE 802.3af standard. The IEEE 802.3at (PoE+) standard is backward compatible with the IEEE 802.3af (PoE) standard.
Overall power consumption
Maximum power consumption: 10 W
● DC powered: 10 W
● PoE powered (802.3af): 10 W
● Idle mode: 3.3 W
RG-AP180
Storage temperature: –40°C to+ 70°C (–40°F to +158°F)
RG-AP180
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN IEC 62311
FCC Part 15
RG-AP180
RGOS11.9(6)W1B9 or later
RG-AP180
120
256
 Note
Maximum number of BSSIDs
16 (up to 8 BSSIDs per radio)
RG-AP180
Dynamic ACL assignment
RG-AP180
NAT ALG FTP and NAT ALG DNS
IPv6 basics
RG-AP180
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
Informações do pedido
RG-AP180
802.11ax dual-radio wall plate wireless access point
Up to four spatial streams
Data rate of up to 1.775 Gbps
●    A 12 V/1 A power adapter needs to be purchased separately.
RG-AP180-MNT
(Optical) Mounting bracket for the US standard junction box. Each set contains 10 pieces.
Perguntas frequentes
