RG-AP680-O(V3) Sem fio - 1
RG-AP680-O(V3) Sem fio - 2
RG-AP680-O(V3) Sem fio - 3
RG-AP680-O(V3) Sem fio - 4
RG-AP680-O(V3) Sem fio - 5
RG-AP680-O(V3) Sem fio - 6
RG-AP680-O(V3) Sem fio - 7
RG-AP680-O(V3) Sem fio - 8
RG-AP680-O(V3) Sem fio - 9
RG-AP680-O(V3) Sem fio - 10
RG-AP680-O(V3) Sem fio - 11
RG-AP680-O(V3), Wi-Fi 6 Dual-Radio 2.976 Gbps Outdoor Access Point, Omnidirectional Antennas
  • Built-in Omnidirectional Antennas, Wide Wi-Fi Coverage
Principais especificações
RG-AP680-O(V3) Wi-Fi 6 Outdoor Access Point
Omnidirectional
Antennas
160 MHz
Max. Data Rate
2.976 Gbps
IP68
Max number of
associated STAs 1024
2.5G SFP port
Gigabit Ethernet port
The transmit power reaches 28 dBm.
STAs in all directions can enjoy good wireless signal strength.
IP68
Wide Temperature Range
Lightning Protection
IP68 dustproof and waterproof
160MHz 丨 2.976 Gbps
Go to WIS Cloud Network
Cloud O&M
24 h Network Optimization
Real-Time Warning
Fault Locating
Especificações
RG-AP680-O(V3)
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 4 dBi.
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 6 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 5 dBi.
1 x 100/1000Base-T port
1 x Bluetooth 5.0
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Whether bridging is enabled
Main unit: 251 mm x 168 mm x 64 mm (9.88 in. x 6.61 in. x 2.52 in.)
Shipping: 405 mm x 232 mm x 325 mm (15.94 in. x 9.13 in. x 12.80 in.)
Main unit: 1.0 kg (2.2 lbs)
Shipping: 3.15 kg (6.94 lbs)
Ceiling/Wall/Pole-mount (a mounting bracket is delivered with the main unit)
● 48 V DC/0.35 A power input over DC connector: The DC connector accepts the center-positive circular plug with the inner diameter of 2.0 mm (0.08 in.) or outer diameter of 6.3 mm (0.25 in.) and the length of 9.8 mm (0.39 in.). A DC power supply needs to be purchased independently.
● DC power: 12.95 W
● 802.3at (PoE+): 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6.0 W
IP Rating
IP68
512 MB DRAM, 128 MB flash
● Maximum transmit power: 28 dBm (630.96 mW)
● The transmit power adjusted in percentage.
RG-AP680-O(V3)
25 dBm
–92 dBm
25 dBm
25 dBm
–84 dBm
25 dBm
–78 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–63 dBm
25 dBm
–84dBm
25 dBm
–51 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–81 dBm
–63 dBm
25dBm
–84 dBm
19 dBm
–61 dBm
25 dBm
–81 dBm
19 dBm
–56 dBm
25 dBm
–78 dBm
19 dBm
25 dBm
–84 dBm
25 dBm
–81 dBm
–51 dBm
25 dBm
–78 dBm
–48 dBm
5 GHz, 802.11ax (HE160)
25 dBm
–73 dBm
–43 dBm
RG-AP680-O(V3)
RGOS11.9(6)W2B4 or later
128
Maximum number of WLAN IDs
MU and TAG device locating
Application management
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP)
Rogue device discovery
Optimization of rogue AP containment for all STA types
Fuzzy containment
SSID-based blocklist
DDoS attack identification
Automatic detection of STA attacks, and adding STAs to the blocklist when ICMP attacks or TCP SYN attacks are detected
STA isolation
Dynamic Policy
CoA/DM
MAC address table size: 1,024
Jumbo frame length: 1,518
Ethernet II
1000M SFP ports modules
2.5G ports
Layer 2 isolation of wired interfaces (including aggregate interfaces) within VLANs
Maximum number of SVIs: 191
VLAN ID range: 1–4,094
Detection of IP address conflicts among downlink hosts
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-AP680-O(V3)
Big data capabilities
RG-AP680-O(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN 62311, EN IEC 62311, EN 50665, IEC 62368-1, EN 62368-1, IEC 60950-22, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-O(V3)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-O(V3)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Informações do pedido
RG-AP680-O(V3)
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3at/at PoE and local DC power supply
Perguntas frequentes
