RG-AP820-L(V3) Redes para pequenas e médias empresas - 1
RG-AP820-L(V3) Redes para pequenas e médias empresas - 2
RG-AP820-L(V3) Redes para pequenas e médias empresas - 3
RG-AP820-L(V3) Redes para pequenas e médias empresas - 4
RG-AP820-L(V3) Redes para pequenas e médias empresas - 5
RG-AP820-L(V3) Redes para pequenas e médias empresas - 6
RG-AP820-L(V3) Redes para pequenas e médias empresas - 7
RG-AP820-L(V3) Redes para pequenas e médias empresas - 8
RG-AP820-L(V3) Redes para pequenas e médias empresas - 9
RG-AP820-L(V3) Redes para pequenas e médias empresas - 10
RG-AP820-L(V3) Redes para pequenas e médias empresas - 11
RG-AP820-L(V3), Wi-Fi 6 AX3000 Indoor AP
Indoor scenarios for higher education, government, general education, finance, and business sectors.
  • 2.5 Gbps SFP Port, Multi-Gigabit Networking
  • Next-generation AX3000 chip, supporting 160 MHz 2.976 Gbps
  • Next-generation Wi-Fi 6 technology, higher concurrency, lower latency
  • Unified cloud management, intelligent tuning, easy O&M
Principais especificações
Ruijie Wi-Fi 6 High Performance Indoor AP
2.5 Gbps SFP Port
Next-Generation AX3000 Chip
Max. Rate of 2.976 Gbps
Bluetooth 5.1
2.5 Gbps SFP Port, Multi-Gigabit Connectivity
The 2.5 Gbps SFP port unleashes the performance of bandwidth for multi-gigabit connectivity.
2.976 Gbps Ultra-Fast Speed with 160 MHz Band
The next-generation AX3000 chip supports 160 MHz band, doubling the Wi-Fi speed.
Wi-Fi 6 dual radios enable a combined rate of 2.976 Gbps, delivering smooth video streaming, instant audio messaging, and file download in seconds.
Ultimate Speed and Capacity with Wi-Fi 6, Up To 2.976 Gbpss
2.976
Gbps
High Concurrency
OFDMA is introduced to
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
  • Remote monitoring
  • Cloud portal authentication
  • Remote Wi-Fi management
Especificações
RG-AP820-L(V3)
Unit dimensions
514 mm x 326 mm x 292 mm (20.24 in. x 12.83 in. x 11.50 in.)
Main unit: 0.6 kg (1.32 lbs)
Mounting bracket: 0.2 kg (0.44 lbs)
8.46 kg (18.65 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit)
RG-AP820-L(V3)
● Radio 1: 2.4 GHz, two spatial streams, 2x2 MIMO
● Radio 2: 5 GHz, two spatial streams, 2x2 MIMO
Operating frequencies
Radio 1, 802.11b/g/n/ax:
Radio 2, 802.11a/n/ac/ax:
Egypt
Data rates
2.4 GHz radio
● Two spatial stream Single User (SU) MIMO for up to 287 Mbps wireless data rate to individual 2SS HE20 802.11ax client devices (typical)
5 GHz radio
● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client devices (typical)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
● 802.11ax: 8.6 to 574 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE40)
5 GHz radio
● 802.11ac: 6.5 to 1,733 (MCS0 to MCS9, NSS = 1 to 4, VHT20 to VHT160)
● 802.11ax: 8.6 to 2,402 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE160)
Packet aggregation
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 5 dBi
Maximum transmit power
Thailand
Egypt
Vietnam:
5150-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
RG-AP820-L(V3)
2.4 GHz 802.11b
-91 dBm
-91 dBm
-90 dBm
-87 dBm
2.4 GHz 802.11g
-89 dBm
22 dBm
-82 dBm
22 dBm
-78 dBm
-72 dBm
2.4 GHz 802.11n (HT20)
-85dBm
19 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
-82 dBm
19 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
-85 dBm
15 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
-82 dBm
15 dBm
-54 dBm
5 GHz 802.11a
-89 dBm
22 dBm
-82 dBm
22 dBm
-78 dBm
-72 dBm
5 GHz 802.11n (HT20)
-85 dBm
19 dBm
-67 dBm
5 GHz 802.11n (HT40)
-82 dBm
19 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
-85 dBm
-60 dBm
5 GHz 802.11ac (VHT40)
-82 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
-79 dBm
-53 dBm
5 GHz 802.11ax (HE20)
-85 dBm
-58 dBm
5 GHz 802.11ax (HE40)
-82 dBm
-54 dBm
5 GHz 802.11ax (HE80)
-79 dBm
-52 dBm
5 GHz 802.11ax (HE160)
-77 dBm
-50 dBm
Bluetooth Radio
RG-AP820-L(V3)
Bluetooth 5.1
Maximum antenna gain
17 dBm (GFSK)
14 dBm (π/4-DQPSK, 8-DPSK)
Receive sensitivity
–95.5 dBm (DH5)
–95 dBm (π/4-DQPSK)
–87.5 dBm (8-DPSK)
Ports Specifications
RG-AP820-L(V3)
1 x 10/100/1000BASE-T port
● Auto MDI/MDIX crossover
● 802.3az EEE
1 x 2.5GE SFP port, compatibility with 1GE module
RG-AP820-L(V3)
Overall power consumption
● DC powered: 12.95 W
● Idle mode: 6 W
 Note:When the 2.5GE SFP port of the RG-AP820-L(V3) is used as an uplink port, the port supports PoE or DC power supply. When PoE is adopted, the auto-negotiation Ethernet port (LAN/1G/PoE) serves as a PoE-in port only.
RG-AP820-L(V3)
IP41
Operating humidity: 0% RH to 95% RH (non-condensing)
RG-AP820-L(V3)
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN IEC 62311
FCC Part 15
Applicable Software Version
RG-AP820-L(V3)
RGOS11.9(6)W1B4 or higher
RG-AP820-L(V3)
120
256
 Note
Maximum number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
Bridge Vlan
RG-AP820-L(V3)
WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2/WPA3(AES), WPA2-Personal, WPA2-Enterprise, WPA3-Personal (WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP), WPA3-OWE, WPA3-OWE transition mode
Dynamic ACL assignment
Routing and Switching
RG-AP820-L(V3)
IP service
Static IPv4 address
IPv4 DHCP Client
FTP ALG and DNS ALG
IPv6 basics
IPv6 DHCP Client
PPPoE Client
LLDP-MED
LLDP-PoE
RG-AP820-L(V3)
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Console, Telnet, SSH, SNMP and TFTP-based management
Fat/Fit/Cloud mode switchover
Videos
RG-AP820-L(V3) Drop impact Experiment
Nov. 12, 2024
Views
Informações do pedido
RG-AP820-L(V3)
Wi-Fi 6 dual-radio indoor wireless access point
Up to four spatial streams
Data rate of up to 2.976 Gbps
Compliance with IEEE 802.11a/b/g/n/ac and 802.11ax standards
RG-E-120(GE)
PSE with 1 x GE port in compliant with IEEE 802.3af standard (PoE)
Perguntas frequentes
