RG-AP820-AR(V3) Sem fio - 1
RG-AP820-AR(V3) Sem fio - 2
RG-AP820-AR(V3) Sem fio - 3
RG-AP820-AR(V3) Sem fio - 4
RG-AP820-AR(V3) Sem fio - 5
RG-AP820-AR(V3) Sem fio - 6
RG-AP820-AR(V3) Sem fio - 7
RG-AP820-AR(V3) Sem fio - 8
RG-AP820-AR(V3) Sem fio - 9
RG-AP820-AR(V3) Sem fio - 10
RG-AP820-AR(V3), Wi-Fi 6 Tri-Radio 2.976 Gbps Indoor Access Point
Indoor scenarios in the higher education, government, general education, finance, and business sectors
  • 160 MHz high bandwidth, 2.976 Gbps high speed with Wi-Fi 6
Principais especificações
Wi-Fi 6 AR Series Indoor AP
RG-AP820-AR(V3) with Built-in AI Radio
Six spatial streams
Max. data rate: 2.976 Gbps
160 MHz channel width
PoE/DC power supply
Bluetooth 5.1
5 Gbps Combo Port, Flexible Networking
The 5 Gbps SFP port is designed for Ruijie All-Optical i-Share+ Solution, unleashing the bandwidth performance to achieve ultra-gigabit access.
Moreover, one 5 Gbps electrical port is provided for wired connection, maximizing the return on investment (ROI).
Built-in AI Radio, Superior Roaming Experience
The built-in AI radio module can perform real-time client scanning and report the scanning results to the AC. Based on the information, the AC steers clients to connect to nearby APs with stronger signals. This enables optimal signal quality and service continuity for superior roaming experience.
Built-in AI Radio
Average roaming latency < 30 ms
Packet loss rate < 0.5%
Conventional settled APs
Average roaming latency of 300 ms
Packet loss rate of 2%
Real-Time and Full-Band Scanning, High Security
AI radio enables real-time and full-band scanning to eliminate potential risks compared with timeframe-based and single-band scanning, ensuring high network security.
The secure scanning approach does not consume radio resources for communication, enabling high wireless performance and sound user experience.
24/7 real-time scanning
2.4 GHz/5 GHz full-band scanning
AI Radio safeguarding
Traditional AP safeguarding
Secure scanning
Data transmission
Upgraded to Wi-Fi 6, High-Speed Access at 2.976 Gbps
2.976
Gbps
High Concurrency
High Rate
Low Latency
High Security
Go to WIS->
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
Especificações
RG-AP820-AR(V3)
Six spatial streams
● Radio 3 – AI Radio, 2.4 GH/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – AI Radio, 2.4 GH/5 GHz: 20 MHz and 40 MHz
● Radio 3 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
Four spatial streams
● Radio 3 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 3 – AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
● Radio 3 – AI Radio, 5 GHz: AI Radio for scanning only
Channels:
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.2 dBi.
1 x 100/1000/2.5G/5GBASE-T port, compliant with IEEE 802.3af/at/bt standard (PoE/PoE+/PoE++)
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 1.0 kg (2.2 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, AI Radio enabled, LAN 2 for PoE supply, and USB port enabled
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, AI Radio enabled, LAN 2 for PoE supply, and USB port enabled
● 802.3at (PoE+): 23 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, AI Radio enabled, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3af (PoE): 12.95 W, 2.4 GHz radio 1x1, 5 GHz radio 1x1, AI Radio is disabled, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● Idle mode: 10.3 W
External power
supply
1 GB DRAM, 256 MB flash
● Maximum transmit power: 27 dBm (501.19 mW)
● Minimum transmit power: 19 dBm (79.43 mW)
● Maximum transmit power: 26 dBm (398.11 mW)
● Minimum transmit power: 21 dBm (125.89 mW)
RG-AP820-AR(V3)
24 dBm
24 dBm
–90 dBm
22 dBm
–87 dBm
24 dBm
–78 dBm
21 dBm
–72 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–78 dBm
21 dBm
–72 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
18.5 dBm
24 dBm
18.5 dBm
–57 dBm
24 dBm
18.5 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
24 dBm
–76 dBm
–49 dBm
Basic Functions
RG-AP820-AR(V3)
RGOS11.9(6)W2B5 or later
Maximum number of WLAN IDs
Intelligent load balancing based on the STA quantity, traffic, and frequency band
Rate set settings
MU and TAG device locating
Application management
PSK and web authentication
ACL Remark
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
NTP server and NTP client
SNMPv1/v2C/v3
RG-AP820-AR(V3)
Big data capabilities
RG-AP820-AR(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP820-AR(V3)] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP820-AR(V3)] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Informações do pedido
RG-AP820-AR(V3)
Wi-Fi 6 (802.11ax-compliant) indoor high-density wireless access point
Tri-radio, six spatial streams, peak data rate of 2.976 Gbps
● Radio 3: AI Radio, 2.4 GHz/5 GHz: two spatial streams, 2x2 MIMO, AI Radio for scanning only
Perguntas frequentes
