| Feature |
RG-S5310-E Series |
| Ethernet Switching |
IEEE 802.1Q (supporting 4K VLANs) |
| *802.3az EEE(Specialized software version) |
| Jumbo frame (maximum length: 9,216 bytes) |
| Maximum number of VLANs that can be created: 4,094 |
| Voice VLAN |
| Super VLAN and private VLAN |
| MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
| GVRP |
| Basic QinQ and selective QinQ |
| STP (IEEE 802.1.d), RSTP (IEEE 802.1w), and MSTP (IEEE 802.1s) |
| Auto errdisable recovery BPDU filter Port fast Root guard |
| ERPS (G.8032) |
| LLDP/LLDP-MED, LLDP IPv6, and LLDP-POE |
| IP Service |
| DHCP client, DHCP relay, DHCP server, and DHCP snooping |
| DHCPv6 client, DHCPv6 relay, DHCPv6 server, and DHCPv6 snooping |
| MAC address filtering Setting the MAC address aging time |
| Neighbor Discovery (ND), ND proxy, and ND snooping |
| GRE tunnel |
| IP Routing |
IPv4 and IPv6 static routing |
| RIP and RIPng |
| OSPFv2, OSPFv3, and GR |
| IS-ISv4 and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4/IPv6 VRF |
| IPv4/IPv6 PBR |
| Multicast |
IGMPv1/v2/v3 |
| IGMPv1/v2 snooping |
| IGMP fast leave |
| PIM-DM, PIM-SM, PIM-SSM, PIM SMv6, and PIM-SSMv6 |
| MSDP for inter-domain multicast |
| MLDv1/v2 and MLD proxy |
| MLDv1/v2 snooping |
| PIM-SMv6 |
| Multicast querier |
| ACL and QoS |
Standard IP ACLs (hardware ACLs based on IP addresses) |
| Global ACLs |
| ACL redirection |
| Port traffic identification |
| Port traffic rate limiting |
| 802.1p/DSCP/ToS traffic classification |
| Congestion management: SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR, and SP+WFQ |
| Eight priority queues per port |
| Rate limiting in each queue |
| Security |
Multiple AAA modes |
| RADIUS and TACACS+ |
| IEEE802.1X authentication, MAC address bypass (MAB) authentication, and port-based and MAC address-based 802.1X authentication |
| Web authentication |
| Hypertext Transfer Protocol Secure (HTTPS) |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| ICMPv6 |
| Port security |
| IP source guard |
| SAVI |
| ARP spoofing prevention |
| CPP and NFPP |
| Multiple attack defense functions |
| 3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC address-based 802.1x authentication MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection Port protection |
| Reliability |
REUP |
| RLDP |
| DLDP |
| IPv4 VRRP v2/v3, IPv6 VRRP, and super-VLAN for VRRP |
| BFD, RAS, NSR, VRRR, VRRP+, and SDN loop detection |
| Basic LACP Inter-VSU AP |
| Link monitoring, fault notification, and remote loopback based on 802.3ah (EFM) |
| Hot swapping of power modules |
| Device virtualization |
VSU Local and remote stacking Inter-chassis link binding in a stack Virtualization through standard service interfaces |
| NMS and maintenance |
SPAN, RSPAN and ERSPAN 1:1 mirroring, N:1 mirroring, 1:N mirroring Flow-based local and remote mirroring |
| sFlow |
| NTP client, NTP server, NTPv6 client, and NTPv6 server |
| SNTP |
| CLI (Telnet/Console) |
| FTP client, FTP server, FTPv6 client, and FTPv6 server |
| TFTP client, TFTP server, TFTPv6 client, and TFTPv6 server |
| FTP and TFTP |
| SNMP v1/v2/c3 |
| Web |
| Syslog/Debug |
| RMON (1, 2, 3, 9) Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups RMON used to implement Ethernet statistics, historical statistics, and alarm functions |
| NETCONF |
| MACC |
| CWMP |
| gRPC |
| VXLAN |
VXLAN (authorized) |
| PoE |
RG-S5310-24GT4XS-P-E and RG-S5310-48GTXS-P-E: IEEE 802.3af and 802.3at power supply standards Automatic and energy-saving power supply management modes Uninterrupted power supply in hot start mode Scheduled power-on or power-off of PoE ports based on the time policy Port priority |
