RDMA-capable high-density 25GE/100GE access switch for data center networks with low latency and no packet drop
four service slots, 25GE/100GE line cards
RG-S6510-32CQ32×100G ports
RG-S6510-48VS8CQNumber of IPv4/IPv6 host routing entries: 128K/64K
| Item |
RG-S6510-48VS8CQ |
RG-S6510-32CQ |
| Dimensions (W x D x H) |
442 mm x 387 mm x 44 mm (17.40 in. x 15.24 in. x 1.73 in.) |
442 mm x 560 mm x 44 mm (17.40 in. x 22.05 in. x 1.73 in.) |
| Rack height |
1 RU |
1 RU |
| Unit weight |
5.6 kg (12.35 lbs., empty chassis) 8.2 kg (18.08 lbs., a chassis with two power modules and four fan modules) |
8.4 kg (18.52 lbs., empty chassis) 11.4 kg (25.13 lbs., a chassis with two power modules and five fan modules) |
| Switching capacity |
4.0 Tbps |
6.4 Tbps |
| Packet forwarding rate |
2000 Mpps |
2030 Mpps |
| Service port |
48 x 10G/25G SFP28 ports 8 x 40G/100G QSFP28 ports |
32 x 100G QSFP28 ports |
| Management port |
1 x RJ45 console port 1 x RJ45 MGMT port |
| USB port |
1 x USB 2.0 port (Type A connector) |
| Module slot |
2 x power module slots 4 x fan module slots |
2 x power module slots 5 x fan module slots |
| Power consumption |
Maximum power consumption: 300 W Typical power consumption: 172 W Static power consumption: 98 W |
Maximum power consumption: 450 W Typical power consumption: 270 W Static power consumption: 150 W |
| Power input |
RG-PA550I-F (AC input): Rated input voltage: 100V AC to 240V AC, 50 Hz/60Hz Maximum input voltage: 90 V AC to140 V AC, 180 V to 264 V AC, 47 Hz to 63 Hz Rated input current: 7.2 A to3.5 A(100 V AC to 240 V AC) Power port type: C14
RG-PA550I-F (HVDC input): Rated input voltage: 240 V DC Maximum input voltage: 180 V DC to 310 V DC Rated current: 3.6 A Power port type: C14
RG-PA550I-R (AC input): Rated input voltage: 100 V AC to 240 V AC, 50 Hz/60 Hz Maximum input voltage: 90 V AC to140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 7.2 A to 3.5 A(100 V AC to 240 V AC) Power port type: C14
RG-PA550I-R (HVDC input): Rated input voltage: 240 V DC Maximum input voltage: 180 V DC to 310 V DC Rated current: 3.6 A Power port type: C14
RG-PHD550I-F (AC input): Rated input voltage: 100 V AC to240 V AC, 50 Hz/60 Hz Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 10 A Power port type: C14
RG-PHD550I-F (HVDC input): Rated input voltage: 336 V DC Maximum input voltage: 160 V DC to 400 V DC Rated input current: 10 A Power port type: C14
RG-PD800I-F (DC input): Rated input voltage: –48 V DC Maximum input voltage: –36 V DC to –72 V DC Rated input current: 23 A Power port: three-pin power connector |
RG-PA550I-F (AC input): Rated input voltage: 100 V AC to 240 V AC, 50 Hz/60 Hz Maximum input voltage: 90 V AC to 140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz Rated input current: 7.2 A to 3.5 A (100 V AC to 240 V AC) Power port type: C14
| Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) Note: At altitudes ranging from 1800 m (5905.51 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation. |
Operating temperature: 0°C to 40°C (32°F to 104°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) Note: At altitudes ranging from 3000 m (9842.52 ft.) to 5000 m (16,404.20 ft.), the maximum temperature decreases by 1°C (1.8°F) for every 200 m (656.17 ft.) increase in elevation. |
| Humidity |
| Altitude |
Operating altitude: ≤ 5,000 m (16,404.20 ft.) Storage altitude: ≤ 5000 m (16,404.20 ft.) |
| Cooling |
Air cooling, front-to-rear airflow (port-side intake): used with the RG-PA550I-F, RG-PD800I-F, and RG-PHD550I-F power modules Air cooling, rear-to-front airflow (port-side exhaust): used with the RG-PA550I-R power module |
Air cooling, front-to-rear airflow (port-side intake) |
| Item |
RG-S6510-48VS8CQ |
RG-S6510-32CQ |
| Layer 2 Protocols |
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and Selective QinQ), GVRP |
| Layer 3 Protocols (IPv4) |
BGP4, OSPFv2, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing (PBR), Route-policy, Equal-Cost Multi-Path Routing (ECMP), WCMP, VRRP, IGMP v1/v2/v3, DVMRP, PIM-SSM/SM/DM, MSDP, Any-RP |
| IPv6 Basic Protocols |
Neighbor Discovery, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMP v6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS |
| IPv6 Features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunnel, automatic tunnel, IPv4 over IPv6 tunnel, and ISATAP tunnel |
| Data Center Features |
VXLAN routing and VXLAN bridging IPv6 VXLAN over IPv4 and EVPN VXLAN PFC, ECN, and RDMA M-LAG OpenFlow 1.3 |
| Visualization |
gRPC sFLOW sampling INT |
| QoS |
Mapping of IEEE 802.1p, DSCP, and ToS priorities |
| Virtualization |
Virtual Switching Unit |
| Buffer Management |
Buffer status monitoring and management, and identification of burst traffic |
| HA Design |
GR for RIP/OSPF/BGP, BFD, DLDP, REUP dual-link fast switching, RLDP unidirectional link detection, 1+1 power redundancy and fan redundancy, and hot swapping for all cards and power supply modules |
| Security Features |
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management |
| Management Mode |
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, Python, fan and power alarm, and temperature alarm |
| Other Protocols |
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP relay, ARP Proxy, and Syslog |
| Product Model |
Description |
| RG-S6510-48VS8CQ |
48 × 25GE ports and 8 × 100GE ports. |
| RG-S6510-32CQ |
Provides 32 × 100G ports. |
Fan and Power Supply Modules
| Product Model |
Description |
| RG-PA550I-F |
550 W power supply module (AC and 240 V HVDC) |
| RG-PA550I-R |
550 W power supply module (port-side exhaust, supporting AC and 240 V HVDC), applicable only to RG-S6510-48VS8CQ |
| RG-PHD550I-F |
550 W power supply module (336 V HVDC), applicable only to RG-S6510-48VS8CQ |
| RG-PD800I-F |
800 W AC power module (48 V LVDC) |
| M6510-FAN-F |
Fan module of RG-S6510-48VS8CQ, supporting 3+1 redundancy, hot swapping, and front-to-rear ventilation design. |
| M1HFAN I-F |
Fan module of RG-S6510-32CQ, supporting 4+1 redundancy, hot swapping, and front-to-rear ventilation design. |
25GE Optical Transceivers
| Model |
Description |
| VG-SFP-AOC5M |
25G AOC, SFP28 form factor, 5 m (16.40 ft.) |
| VG-SFP-LR-SM1310 |
25G LR optical transceiver, SFP28 form factor, LC, 1310 nm, 10 km (32,808.40 ft.) over single-mode fiber (SMF) |
| VG-SFP-SR-MM850 |
25G SR optical transceiver, SFP28 form factor, LC, 850 nm, 100 m (328.08 ft.) over multimode fiber (MMF) |
40G Optical Transceivers
| Model |
Description |
| 40G-QSFP-SR-MM850 |
40G SR optical transceiver, QSFP+ form factor, MPO, 150 m (492.13 ft.) over MMF |
| 40G-QSFP-LR4-SM1310 |
40G LR4 optical transceiver, QSFP+, Duplex LC, 10 km (32,808.40 ft.) over SMF |
| 40G-QSFP-LSR-MM850 |
40G SR optical transceiver, QSFP+ form factor, MPO, 400 m (1312.34 ft.) over MMF |
| 40G-QSFP-iLR4-SM1310 |
40G iLR4 optical transceiver, QSFP+, Duplex LC, 2 km (6,561.68 ft.) over SMF |
| 40G-QSFP-LX4-SM1310 |
40G LX4 optical transceiver, QSFP+, Duplex LC, 150 m (492.13 ft.) over OM3/OM4 MMF, 2 km (6,561.68 ft.) over SMF |
| 40G-AOC-30M |
40G QSFP+ AOC, 30 m (98.43 ft.) |
| 40G-AOC-5M |
40G QSFP+ AOC, 5 m (16.40 ft.) |
100G Optical Transceivers
| Model |
Description |
| 100G-QSFP-SR-MM850 |
100G SR optical transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF |
| 100G-QSFP-LR4-SM1310 |
100G LR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 10 km (32,808.40 ft.) over SMF |
| 100G-QSFP-iLR4-SM1310 |
100G iLR4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF |
| 100G-QSFP-ER4-SM1310 |
100GE ER4 optical transceiver, QSFP28 form factor, Duplex LC, 1310 nm, 40 km (131,233.60 ft.) over SMF |
| 100G-AOC-10M |
100G AOC, QSFP28 form factor, 10 m (32.81 ft.) |
| 100G-AOC-5M |
100G AOC, QSFP28 form factor, 5 m (16.40 ft.) |
For more information about optical transceiver compatibility, refer to Ruijie RG-S6510 Series Data Center Switches Optical Transceiver Compatibility Matrix.
