PoF Solution
Optical-Electrical Convergence, Building an Intensive Simplified All-Optical Ethernet
Ruijie Networks Power over Fiber (PoF) Solution, enabled by optical-electrical convergence, significantly enhances network operations and production efficiency. It satisfies the needs of campus networks in diverse scenarios including production, office, and warehousing, and builds a set of scalable, high-performance, low-latency, intensive campus networks with simple O&M, low cost, and high efficiency.
Challenges Solution Architecture Benefit Products Success Stories Resources
Have You Encountered the Following Problems on Your Campus Network?
Campus Network?
Approve
Enterprise Production Workshop
  • Limited network cable transmission distance of 100 m, restricting device installation and power supply
  • Difficulties in re-cabling upon information point increase or change due to narrow space in cabinets or on cable trays
  • UPS required in key security areas, resulting in a long construction period and high deployment costs
Approve
Enterprise Warehousing
  • Large space and scattered cabinets, incurring low port usage of PoE switches and high construction costs
  • Switches deployed on overhead cable trays, leading to complex O&M
  • Lots of shelves, poor signal coverage, and high PLR
Approve
Enterprise Office and R&D
  • Difficulties in information point increase or change due to narrow space on cable trays
  • Multitudes of ELV rooms and access devices, causing complicated cabling and O&M
  • Growing mobile office terminals to be connected, posing challenges to information security
PoF Solution Dedicated for the Enterprise Market, Supporting
Various Enterprise Network Scenarios
500–1500 m
Data and power transmission over an ultra-long distance of 500–1500 m, enabling flexible device installation and power supply
–70%
Information point connection through nearby indoor switches, reducing network cabling by 70%
0.1%
Industrial wireless seamless roaming, reducing the PLR to 0.1% and empowering smooth AGV and PDA services
Electric cable
Optical cable
Network cable
Hybrid cable
One Optical Cable
to the Terminal
Simple O&M in equipment rooms without overhead PoE switches
> 500 m
Data and power transmission over 500+ m for easy connection of distant and scattered wireless surveillance terminals, delivering higher port usage and lower construction costs
–80%
Optical-electrical convergence on one cable, no independent power and environment monitoring system required, saving power cabling costs by 80%
Electric cable
Optical cable
Network cable
Hybrid cable
–80%
On-demand device deployment and replacement without re-planning or configuration, supporting flexible expansion and reducing network cabling by 80%
–90%
90% decrease in floor network cabinets, simplifying O&M
Security Policy Migration
Security policy configuration based on employee identities but not network segments or locations, guaranteeing information security anytime
Electric cable
Optical cable
Network cable
Hybrid cable
01 / 03
Simplified All-Optical Ethernet:
Fiber to the room, simple architecture
All-optical AP access, reducing cabling by 90% and network construction costs by 30%, no re-cabling for service expansion
02 / 03
Simplified Access:
Flexible deployment, uninterrupted connection upon power failures
One fiber-optic cable to the terminal, data and power transmission over a distance of 1500 m, easy connection of remote and scattered terminals
03 / 03
Simplified O&M:
High terminal security and efficient O&M
SDN network-wide management and refined service management, enhancing O&M efficiency by 50%
Optoelectronic Integration Enhances Campus Network
Operations and Boosts Productivity
Recommended Products
RG-PF2920 Series SOE Switch
Industrial-grade design standards, flexible deployment in various scenarios
Learn more
RG-S7808C-V2 Core PoF Switch
Integrated power and optical transmission over an ultra-long distance
Learn more
Success Stories
Sunwoda Electronic Co., Ltd.
The switch covers a distance of 20 m and its ports are flexible. The expansion of information points only requires network adjustment within 10–20 m, greatly improving production efficiency. With all-optical APs, the wireless network speed has been increased by four times, which is widely praised by employees.
Headquarters of Ruijie Networks in Fuzhou
The solution reduces the overall cabling cost by 65%, and SDN unified O&M improves efficiency by 50%, building an intelligent campus that meets the requirements in the next decade.
COFICAB Group
The solution saves wired cabling by 75%, and cables connected to small cabinets are all optical, halving cable management costs. The solution also features SDN unified O&M, zero-touch provisioning and replacement, as well as automatic loop detection and self-healing, dramatically cutting O&M costs.
