RG-AP1920 Wireless - 1
RG-AP1920 Wireless - 2
RG-AP1920 Wireless - 3
RG-AP1920 Wireless - 4
RG-AP1920 Wireless - 5
RG-AP1920 Wireless - 6
RG-AP1920, Wi-Fi 7 Dual-Radio 3.570 Gbps Wall-Plate Access Point
Suitable for VIP offices, meeting rooms, 5-star hotels, and other similar scenarios.
Seri
  • Flat rear panel design, compatible with 86 mm junction box mounting or wall mounting
  • Diversified ports for multi-service connectivity
Spesifikasi Utama
RG-AP1920 Wi-Fi 7 Wall-Plate AP, Compact in Design, Exceptional in Performance
The Ruijie RG-AP1920 is a Wi-Fi 7 (802.11be) wall-plate AP, designed to provide reliable indoor coverage in environments such as VIP offices, meeting rooms, hotels, and others. Equipped with four spatial streams, the AP achieves a peak data rate of 3.570 Gbps. It supports DC or PoE power supply and comes with 1 x 2.5GE uplink port, 4 x 1GE downlink ports, and 2 x pass-through ports, facilitating flexible deployment and service expansion.
Flat Rear Panel, Enabling Easy Installation
Innovative rear panel, simple wall mounting
Seamless Upgrade to Wi-Fi 7
20% higher peak throughput
2-fold improvement in channel capacity with 320 MHz
Diverse Ports for Multi-service Connectivity
1GBASE-T port: achieving high speed access in rooms
Pass-through port: supporting IP phone access
Digital Twin Network,
The AP supports intelligent O&M functions, including visualized fault locating, local network optimization, service network optimization, and network optimization in VIP areas.
RG-AP1920
Channel:
2 spatial streams
Channel:
Channel:
802.11be
Channel:
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 3 dBi.
1 x 100/1000/2.5GBASE-T port
4 x 10/100/1000BASE-T ports
1 x micro USB console port
1 x a pair of pass-through ports
1 x Bluetooth 5.3
1 x system status LED
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Dimensions (W x H x D)
Shipping: 347 mm x 383 mm x 270 mm (13.66 in. x 15.08 in. x 10.63 in.)
Main unit: 0.3 kg (0.66 lbs)
Shipping: 9.73 kg (21.45 lbs)
Kensington lock
● 54 V DC/0.35 A power input over DC connector
● Idle mode: 7.2 W
512 MB, 256 MB flash
● Maximum transmit power: 20 dBm (100 mW)
● Minimum transmit power: 0 dBm (1 mW)
Wi-Fi Radio Performance
RG-AP1920
2.4 GHz 802.11g
-91 dBm
17 dBm
-85 dBm
17 dBm
-80 dBm
-74 dBm
2.4 GHz 802.11n (HT20)
-85 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
-82 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
-85 dBm
14 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
-82 dBm
14 dBm
-54 dBm
2.4 GHz 802.11be (EHT40)
-82 dBm
14 dBm
-54 dBm
5 GHz 802.11a
-91 dBm
17 dBm
-85 dBm
17 dBm
-80 dBm
-74 dBm
5 GHz 802.11n (HT20)
-85 dBm
-67 dBm
5 GHz 802.11n (HT40)
-82 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
-85 dBm
-67 dBm
5 GHz 802.11ac (VHT40)
-82 dBm
15 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
-82 dBm
15 dBm
-56 dBm
5 GHz 802.11ax (HE20)
-85 dBm
14 dBm
-58 dBm
5 GHz 802.11ax (HE40)
-82 dBm
14 dBm
-54 dBm
5 GHz 802.11ax (HE80)
-82 dBm
15 dBm
-56 dBm
14 dBm
-52 dBm
5 GHz 802.11ax (HE160)
-79 dBm
15 dBm
-53 dBm
14 dBm
-50 dBm
5 GHz 802.11be (EHT80)
-82 dBm
15 dBm
-56 dBm
14 dBm
-52 dBm
MCS13
12 dBm
-46 dBm
5 GHz 802.11be (EHT160)
-79 dBm
15 dBm
-53 dBm
14 dBm
-50 dBm
MCS13
10 dBm
-44 dBm
RG-AP1920
RGOS11.9(6)W3B19 or later
Maximum number of WLAN IDs
Mobile unit (MU) location
Application management
Dynamic Policy
MAC address table size: 1,024
Jumbo frame length: 1,518
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Fault detection and alarming
RG-AP1920
EN 55032, EN 55035, EN IEC 61000-3-2, EN 61000-3-3, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, EN IEC 62311, FCC Part 15, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP1920] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP1920] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • Ruijie wireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
Sumber daya
Informasi Pesanan
RG-AP1920
Wi-Fi 7 dual-radio wall plate access point
Up to four spatial streams, peak data rate of 3.570 Gbps
 Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 0.688 Gbps
 Radio 2: 5 GHz: two spatial streams,2x2 MIMO, peak data rate of 2.882 Gbps
The AP consumes 0.5 licenses of an AC. 802.11a/b/g/n/ac/ax/be, switching between Fat, Fit, and cloud modes, and 802.3af/at-compliant (PoE/PoE+) and local power supply
 The DC power supply needs to be purchased separately, and the output voltage/current must be 50 V/0.35 A.
