RG-S5360-24GT4XS-P-E Commutateurs - 1
RG-S5360-24GT4XS-P-E Commutateurs - 2
RG-S5360-24GT4XS-P-E Commutateurs - 3
RG-S5360-24GT4XS-P-E Commutateurs - 4
RG-S5360-24GT4XS-P-E Commutateurs - 5
RG-S5360-24GT4XS-P-E Commutateurs - 6
RG-S5360-24GT4XS-P-E 24-Port GE Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
Ideal for large enterprises, campuses, and institutions, providing gigabit access, secure networking, and efficient support for IP phones, APs, cameras, and server clusters.
  • Multiple port types with full gigabit access, flexible 10GE uplink, and PoE/PoE+ for enhanced speed and performance
  • Nano Coating Protection for Enhanced Durability
  • Hot-pluggable Dual Power Modules for Higher Reliability
  • Stronger Interference Resistance with Wide Temperature Range & 10kV Surge Protection
  • INC Provides Easy and Efficient O&M
Layer 3 Compact Access Switch for 10GE Uplink RG-S5360-24GT4XS-P-E
Next-gen gigabit Ethernet switches with secure, high-efficiency, and energy-saving features, providing full gigabit access, 10GE uplink support, and enhanced performance through the latest RGOS12.X modular OS.
Feature advanced nano-coating on PCBs, offering 30% improved durability with anti-corrosion, salt tolerance, and anti-sulfurization, making them ideal for coastal and industrial environments.
Equipped with two pluggable power modules that work in 1+1 redundancy backup mode, and can operates continuously without interruption, ensuring stable performance.
Support a temperature range from –40°C to +65°C and feature 10kV surge protection, providing consistent performance and improved protection against interference in extreme conditions.
Spécifications
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
RG- S5360-24GT4XS-P-E
RG- S5360-48GT4XS-P-E
4 x 1GE/2.5GE/10GE SFP+ ports
PA70IB
PA600IP-F
PA1000IP-F
(supporting mixed insertion)
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
115 Mpps
158 Mpps
115 Mpps
158 Mpps
System switching capacity*2
154 Gbps
211 Gbps
154 Gbps
211 Gbps
512 MB
1GB DDR4
ND table size
6,000
750
Ingress: 1,750
Egress: 800
Number of IGMP groups
Number of MLD groups
750
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
RG-PA70IB (AC input):
Rated input voltage: 100 V AC to 240 V AC, 50/60 Hz
Maximum input current: 2 A
RG-PA70IB: 70 W
30 W
Rated input voltage: 200 V AC to 240 V AC, 50/60 Hz
Maximum input voltage: 180 V AC to 264 V AC, 47 Hz to 63 Hz
100 V AC to 130 V AC: 930 W
200 V AC to 240 V AC: 1000 W
Note: When the ambient temperature is higher than 55°C (131°F), the maximum output power is reduced by 50%.
1 x RG-PA600I-P-F: 370 W
2 x RG-PA600I-P-F: 740 W;
1 x RG-PA1000I-P-F: 740 W;
2 x RG-PA1000I-P-F: 1480 W;
a maximum output of 720 W over 24 ports (30 W x 24)
a maximum output of 1440 W over 48 ports (30 W x 48)
35 W (without PoE load)
750 W (full PoE load)
45 W (without PoE load)
1485 W (full PoE load)
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
442mm x 420 mm x 43.6 mm (17.40 in. x 16.53 in. x 1.72 in.)
4.4 kg (9.70 lbs)
4.4 kg (9.70 lbs)
4.2 kg (9.26 lbs)
4.9 kg (10.80 lbs)
Mounting on a workbench or in a rack (cabinet)
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
Operating temperature: 0°C to 45°C (32°F to 113°F) at an altitude range of 0 m to 1,800 m (0 ft. to 5,905.51 ft.)
Operating temperature: -40°C to +65°C (-40°F to +149°F) at an altitude range of 0 m to 1,800 m (0 ft. to 5,905.51 ft.)
When three or four 80-km long-reach optical transceivers are configured, the operating temperature range is –40°C to +50°C (–40°F to +122°F).
2x fixed fan module
Left-to-rear, front-to-rear
SPL: fanless, quiet, < 20 dB
SPL at ambient temperature of 27°C (80.6°F): 36 dB
SPL at ambient temperature of 27°C (80.6°F): 36 dB (30% PoE load, 2 RG-PA1000I-P-F power modules, adjusted fan speed)
RG- S5360-24GT4XS-E
RG- S5360-48GT4XS-E
RG-S5360-E Series
IEEE 802.1Q (4,000 VLANs)
Super VLAN and private VLAN
IPv4 and IPv6 VRF
IGMP v1/v2 snooping
Dual-boot redundancy
SPAN, RSPAN
RG-S5360-E-24GT4XS-P-E, and RG-S5360-E-48GT4XS-P-E:
Warm start
Interface priority
Ressources
Informations sur la commande
Follow the steps to order the RG-S5360-E series switches.
  • Select a switch and expansion modules based on port requirements.
  • Select optical transceivers based on port requirements.
RG-S5360-24GT4XS-E
24 x 10/100/1000BASE-T ports, 4 x 1GE/2.5GE/10GE SFP+ ports, 2 modular power supply slots (at least one power module needs to be configured)
RG-S5360-48GT4XS-E
48 x 10/100/1000BASE-T ports, 4 x 1GE/2.5GE/10GE SFP+ ports, 2 modular power supply slots (at least one power module needs to be configured)
24 x 10/100/1000BASE-T ports, supporting PoE/PoE+ and the maximum PoE output power of 720 W, 4 x 1GE/2.5GE/10GE SFP+ ports, 2 modular power supply slots (at least one power module needs to be configured, only when the PoE load of the whole device is less than PoE output power of single power supply and dual power supplies are used, redundancy is supported.)
RG-S5360-48GT4XS-P-E
48 x 10/100/1000BASE-T ports, supporting PoE/PoE+ and the maximum PoE output power of 1440 W, 4 x 1GE/2.5GE/10GE SFP+ ports, 2 modular power supply slots (at least one power module needs to be configured, only when the PoE load of the whole device is less than PoE output power of single power supply and dual power supplies are used, redundancy is supported.)
4 x 1GE/2.5GE/10GE SFP+ ports support 1GE SFP transceivers, 2.5GE SFP transceivers and 10GE SFP+ transceivers.
Power Module
RG-PA70IB
70 W AC power module
Optical Transceivers
2.5G-SFP-LX03-SM1310- BIDI-I
2.5G-SFP-LX03-SM1550- BIDI-I
