RG-AP880-E Dispositivos Wireless - 1
RG-AP880-E Dispositivos Wireless - 2
RG-AP880-E Dispositivos Wireless - 3
RG-AP880-E Dispositivos Wireless - 4
RG-AP880-E Dispositivos Wireless - 5
RG-AP880-E, Wi-Fi 6E Tri-radio 7.780 Gbps Indoor Access Point
Indoor high-quality network scenarios in the higher education, medical industry, government and commerce
  • Multi-scenario adaptability, providing flexible solutions to meet diverse service needs
  • Upgraded to Wi-Fi 6E, a combined data rate of up to 7.780 Gbps
Product Overview
The RG-AP880-E is a Wi-Fi 6E wireless access point that delivers tri radios, high performance, and enterprise-grade encryption. Its hybrid cloud management mode and high-density access design allow the RG-AP880-E to be flexibly deployed in high-quality network scenarios, such as classrooms, dormitories, and large venues in the education industry, outpatient clinics and mobile ward rounds in the medical industry, and large conference centers in government and commerce industries.
Product Highlights
Ultra-High Performance
Tri-band design (2.4 GHz + 5 GHz + 6 GHz), six spatial streams, 1024-Quadrature Amplitude Modulation (QAM) high-speed access, and up to 7.780 Gbps peak data rate, realizing high-speed wireless access experience
Wi-Fi 6E technology to leverage 6 GHz spectrum resources and deliver a data rate of up to 4.804 Gbps at 6 GHz radio, providing supreme wireless experience to users
RF power adjustment and intelligent channel allocation to solve the problems such as co-channel interference and adjacent channel interference, thereby improving network transmission efficiency and stability
Flexible Networking
Local and cloud management modes, and intelligent wireless network optimization, reducing TCO and maximizing ROI
Access through optical and Ethernet cables for flexible networking and high-speed backhaul over 5 Gbps wired links
IEEE 802.11k/v/r support, roaming stickiness optimization, and client steering, achieving seamless roaming and improved user experience
Rich IoT features: PoE output, Bluetooth 5.1, and wireless locating
High Security and Reliability
Encryption and authentication technologies including Wi-Fi Protected Access 3 (WPA3), enhanced open security, 802.1X, and Private Pre-shared Key (PPSK), enhancing data security
Dynamic Frequency Selection (DFS), optimizing the use of available RF spectrum to prevent radar channel interference
Cyclic Delay/Shift Diversity (CDD/CSD), Maximum Ratio Combining (MRC), Space-Time Block Coding (STBC), and Low-Density Parity Check (LDPC), improving the signal quality, signal receiving, and reliability and performance of data transmission
Transmit beam-forming (TxBF) expands the signal coverage and enhances the reliability of specific devices, thereby improving the data rate
Intelligent identification and monitoring, multicast-to-unicast conversion, and other features, enhancing network security and reliability
RG-AP880-E
Four spatial streams
Channels:
Two spatial streams
Channels:
Eight spatial streams
● Radio 3 – 6 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
● Radio 3 – 6 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
Combined peak data rate: 7.780 Gbps:
● Radio 3 – 6 GHz: 8.6 Mbps to 4.804 Gbps (MCS0 to MCS11)
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.2 dBi.
● 6 GHz: four built-in omnidirectional antennas, with peak antenna gain of 5.4 dBi.
1 x 100/1000/2.5G/5GBase-T port
1 x 10/100/1000Base-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, 6 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● 802.3af (PoE): 12.95 W, 2.4 GHz radio 1x1, 5 GHz radio 1x1, 6 GHz radio 1x1, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3at (PoE+): 23 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, 6 GHz radio 4x4, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2, 6 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● Idle mode: 10.3 W
External power supply
Operating altitude: –500 m to +4,000 m (–1,640.42 ft. to +13,123.36 ft.)
512 MB DRAM, 256 MB flash
● Maximum transmit power: 27 dBm (500 mW)
● Maximum transmit power: 30 dBm (1000 mW)
● Minimum transmit power: 6 dBm (3.98 mW)
6 GHz
● Maximum transmit power: 26 dBm (398 mW)
RG-AP880-E
24 dBm
-96 dBm
24 dBm
-95 dBm
-93 dBm
22 dBm
-89 dBm
24 dBm
-91 dBm
-85 dBm
-80 dBm
21 dBm
-74 dBm
24 dBm
-90 dBm
-70 dBm
24 dBm
-90 dBm
-70 dBm
24 dBm
-90 dBm
-62 dBm
24 dBm
-88 dBm
-60 dBm
-91 dBm
22 dBm
-85 dBm
22 dBm
-80 dBm
21 dBm
-74 dBm
-90 dBm
-68 dBm
-88 dBm
-68 dBm
-90 dBm
-68 dBm
-88 dBm
-63 dBm
-85 dBm
-60 dBm
-90 dBm
-60 dBm
-86 dBm
-56 dBm
-83 dBm
-53 dBm
5 GHz, 802.11ax (HE160)
-81 dBm
-51d Bm
6GHz 802.11ax (HE20)
22 dBm
-90 dBm
-60 dBm
6GHz 802.11ax (HE40)
22 dBm
-86 dBm
-56 dBm
6GHz 802.11ax (HE80)
22 dBm
-83 dBm
-53 dBm
6GHz 802.11ax (HE160)
22 dBm
-81 dBm
-51 dBm
RG-AP880-E
RGOS11.9(6)W3B4 or later
320
Maximum number of WLAN IDs
15
MU and TAG device locating
Application management
PSK, UPSK and web authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP), WPA3-OWE
Dynamic Policy
CoA/DM
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
DNSv6 client
TFTPv6 client
NTP server and NTP client
RG-AP880-E
Big data capabilities
RG-AP880-E
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, ETSI EN 303 687, EN IEC 62311, IEC 62368-1, EN 62368-1, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP880-E] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP880-E] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Información sobre pedidos
RG-AP880-E
Wi-Fi 6E 802.11ax-compliant indoor high-density wireless access point
Tri radios, eight spatial streams, peak data rate of 7.780 Gbps
● Radio 2: 5 GHz: two spatial streams,2x2 MU-MIMO, peak data rate of 2.402 Gbps
● Radio 3: 6 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
Preguntas frecuentes
