RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 1
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 2
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 3
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 4
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 5
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 6
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 7
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 8
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 9
RG-CS83-24GT4XS-P Redes para pequeñas y medianas empresas - 10
RG-CS83-24GT4XS-P 24-Port 1GE RJ45 Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
RG-CS83-24GT4XS-P
24 x 10/100/1000BASE-T ports and four 1GE/10GE SFP+ ports for flexible networking
Flexible installation
Silence
Carrier-class Reliability
10 kV Surge Protection
Make Your Business Easy
Flexible Management Modes
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Fixed service ports
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
96 Mpps
132 Mpps
78 Mpps
96 Mpps
132 Mpps
128 Gbps
176 Gbps
104 Gbps
128 Gbps
176 Gbps
1.5 MB
6,000
750
Ingress: 1,750
Egress: 800
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
4.10 kg
(9.04 lbs)
4.10 kg
(9.04 lbs)
4.18 kg
(9.22 lbs)
4.25 kg
(9.37 lbs)
4.90 kg
(10.80 lbs)
Power supply and Consumption
RG-CS83-24GT4XS
RG-CS83-48GT4XS
Built-in power supply: 25 W
Built-in power supply: 40 W
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Built-in power supply: 409 W
Built-in power supply: 460 W
35 W (non-PoE)
405 W (PoE full load)
35 W (non-PoE)
52 W (non-PoE)
460 W (PoE full load)
The maximum power is 405 W
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
No fan
Fanless, quiet, < 20 dB
27℃ (80.6°F): 32 dB
27℃ (80.6°F): 35 dB
27℃ (80.6°F): 32 dB
27℃ (80.6°F): 35 dB
Communication port: 10 kV
RG-CS83 Series
Communication standard
RG-CS83 Series
Non blocking
IGMP v1/v2 snooping
Dual-Boot Redundancy
SPAN, RSPAN
Warm start
Interface priority
Información sobre pedidos
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Preguntas frecuentes
