RG-MAP852-SF-M Drahtlos - 1
RG-MAP852-SF-M Drahtlos - 2
RG-MAP852-SF-M Drahtlos - 3
RG-MAP852-SF-M Drahtlos - 4
RG-MAP852-SF-M Drahtlos - 5
RG-MAP852-SF-M Drahtlos - 6
RG-MAP852-SF-M Drahtlos - 7
RG-MAP852-SF-M Drahtlos - 8
RG-MAP852-SF-M Drahtlos - 9
RG-MAP852-SF-M Drahtlos - 10
RG-MAP852-SF-M, Simplified Optical Ethernet (SOE) Standard Micro AP, Wi-Fi 6 Dual-Radio 2.976 Gbps
  • 2.5G optical ports, delivering high bandwidth and smooth Internet access
  • Data transmission and power supply through a hybrid cable
  • Upgrade to Wi-Fi 6, wireless transmission at a rate of up to 2.976 Gbps
  • Unified cloud management, intelligent optimization, and easy O&M
Hauptspezifikationen
Funktionen
Ruijie All-Optical i-Share+ Solution - Micro AP (RG-MAP852-SF-M)
Solution
RG-MAP852-SF-M works with the optical i-Share master AP to realize high-bandwidth data transmission and long-distance PoE power supply through a hybrid cable, integrating wired and wireless coverage.
Wi-Fi 6
Maximum Data Rate: 2.976 Gbps
Max number of
associated STAs:1024
i-Share Mode
P2P Power Supply Through a Hybrid Cable
Bluetooth 5.1
2.5G Optical Port Delivering High Bandwidth
2.5G high-speed optical ports greatly improve the data transmission rate, coping with bandwidth-intensive services at ease.
2.5G optical port bring a more stable and smooth online experience.
New Wi-Fi 6 Experience with a Speed of 2.976 Gbps
2.976
Gbps
Hight Concurrency
Multi-user transmission technologies such as OFDMA and MU-MIMO are introduced, supporting 64 concurrent users.
Low Latency
OFDMA technology is used to transmit data to multiple terminals simultaneously. The latency is as low as 20 ms.
The next-generation wireless encryption protocol WPA3 greatly improves the security of wireless connections.
High Speed
With 1024QAM modulation, data rate is 25% higher compared with 802.11ac.
Unified Cloud Management
Intelligent Optimization, and Easy O&M
The WIS cloud network configuration and optimization can be completed without onsite operations.You can use Wi-Fi Moho for easier O&M.
With early warning of network failures, wireless networks can be monitored anytime and anywhere
Go to WIS cloud network >
Cloud O&M
24/7 Network Optimization
Real-time Warnings
Fault Location
Vergleich
Protocol
Max. data rate
MIMO
CWDM
Max. power consumption
Dimensions (W x H x D)
Spezifikationen
RG-MAP852-SF-M
Unit dimensions
(W x H x D)
86 mm x 160 mm x 32.5 mm (3.39 in. x 6.30 in. x 1.28 in.)
Shipping dimensions
(W x H x D)
123 mm x 180 mm x 67 mm (4.84 in. x 7.09 in. x 2,64 in.)
Unit weight
Main unit: 0.30 kg (0.66 lbs.)
Shipping weight
0.5 kg (1.10 lbs)
Ceiling/Wall/86 mm junction box-mount
White
Securing latch
RG-MAP852-SF-M
256 MB
128 MB
RG-MAP852-SF-M
Dual-radio
Four spatial streams per device
Operating frequencies
Radio 1, 802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz, channels 1 to 13
Radio 2, 802.11a/n/ac/ax:
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
802.11ax: 8.6 to 2,402 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE160)
Packet aggregation
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 2.22 dBi
● 5 GHz: two built-in omnidirectional antennas, with peak antenna gain of 6.45 dBi
● One built-in omnidirectional antenna, with peak antenna gain of 2 dBi
● Maximum transmit power: 21 dBm (125.89 mW)
● Minimum transmit power: 8 dBm (6.31 mW)
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM, 4096-QAM
Frequency Performance
RG-MAP852-SF-M
2.4GHz 802.11b
17 dBm
–90 dBm
15 dBm
–87 dBm
2.4GHz 802.11g
–78 dBm
15 dBm
–72 dBm
2.4GHz 802.11n (HT20)
15 dBm
–67 dBm
2.4GHz 802.11n (HT40)
15 dBm
–64 dBm
2.4GHz 802.11ax (HE20)
12 dBm
–58 dBm
2.4GHz 802.11ax (HE40)
12 dBm
5GHz 802.11a
–78 dBm
15 dBm
–72 dBm
5GHz 802.11n (HT20)
15 dBm
–67 dBm
5GHz 802.11n (HT40)
15 dBm
–64 dBm
5GHz 802.11ac (VHT20)
15 dBm
5GHz 802.11ac (VHT40)
15 dBm
–57 dBm
5GHz 802.11ac (VHT80)
15 dBm
5GHz 802.11ax (HE20)
12 dBm
–58 dBm
5GHz 802.11ax (HE40)
12 dBm
5GHz 802.11ax (HE80)
12 dBm
–52 dBm
5GHz 802.11ax (HE160)
–75 dBm
9 dBm
–48 dBm
Bluetooth Radio
RG-MAP852-SF-M
Bluetooth 5.1
Built-in omnidirectional anntenna
Maximum antenna gain
2 dBi, with a downtilt angle of roughly 30 degrees
10 dBm (Class 1)
Receive sensitivity
–98 dBm
Port Specifications
RG-MAP852-SF-M
1 x 2.5GE SFP port
4 x 10/100/1000BASE-T ports
1 x micro USB console port
1 x system status LED
RG-MAP852-SF-M
(1) 48 V DC/0.5 A power input
(2) IEEE 802.3af-compliant PoE power input using hybrid cables
Maximum power consumption: 11 W
● DC power: 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● 802.3at (PoE+) : 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● 802.3af (PoE) : 11 W, 2.4 GHz radio 2x2, 5 GHz radio 2x2.
● Idle mode: 7.44 W
RG-MAP852-SF-M
Operating temperature: –10°C to +40°C (14°F to 104°F)
Software
RG-MAP852-SF-M
RGOS11.9(6)W1B9 or later
Maximum number of BSSIDs
16 (up to 8 BSSIDs per radio)
WLAN service
Maximum number of WLAN IDs: 8
Maximum number of users per WLAN: 1,024
Intelligent load balancing based on client count, traffic, or radio frequency
Enabling or disabling the radio as scheduled
Rate set settings
Parameter adjustment for enhanced user experience: client RSSI threshold, client idle timeout, client average rate threshold, transmit power of beacon frames and probe responses
WLAN QoS rate limiting, fair scheduling, and Wi-Fi Multimedia (WMM)
MU and TAG device locating
Application management
PSK and web authentication
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP)
MAC address table size: 2048
Jumbo frame length: 1,518 bytes
IEEE802.1p and IEEE802.1Q
Interface-based VLAN assignment, VLAN group
Maximum number of SVIs: 100
VLAN ID range: 1 to 4,094
Maximum number of ARP entries: 1024
IPv4 ping and IPv4 traceroute
DNS client
DHCP server, DHCP client, and DHCP relay
DHCPv4 snooping
IPv4 source guard
Static and dynamic IPv6 addresses
IPv6 ping and IPv6 traceroute
IPv6 transparent transmission
Static black hole routing
NTP server and NTP client
Telnet and TFTP client
RG-MAP852-SF-M
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN 62311, EN IEC 62311, EN 50665, IEC 62368-1, and EN 62368-1
Ressourcen
Bestellinformationen
RG-AM5528-SF
Optical i-Share+ master AP for Ruijie SOE Solution
24 × downlink 1G/2.5G SFP ports and 24 × PoE/PoE+ power supply ports. Four power supply ports support PoE/PoE/PoE++ power supply.
4 × uplink 10G SFP+ ports, low noise, and power supply included
RG-MAP852-SF-S
Wi-Fi 6 dual-radio wall plate micro AP for Ruijie SOE Solution
1 × SFP port
BOB structure, one 1G optical module of the master AP
RG-MAP852-SF-M
1 × 2.5G SFP port
4 ×10/100/1000Base-T Ethernet ports with auto-negotiation
2.4 GHz and 5 GHz frequency bands,
Support for Bluetooth,
Wall-mounted, ceiling-mounted, and junction box-mounted installation.
RG-HybridBox
The hybrid box for Ruijie SOE Solution supports input of 24 hybrid pigtails and output of 24 hybrid cables, which is used to connect the hybrid pigtails to the hybrid cables.
RG-OEHC-SM-1B6A2-2x0.5-I-305
RG-OEHC-SM-2B6A2-2x0.4-I-305
Indoor dual-core 2 x 0.4 mm² photoelectric hybrid cable, single roll, with a length of 305 m (1000.66 ft)
RG-OEHC-SM-2B6A2-2x1.0-I-305
RG-OEHC-SM-2B6A2-2x1.5-O-1000
