RG-AP680-L KMU-Networking - 1
RG-AP680-L KMU-Networking - 2
RG-AP680-L KMU-Networking - 3
RG-AP680-L KMU-Networking - 4
RG-AP680-L KMU-Networking - 5
RG-AP680-L KMU-Networking - 6
RG-AP680-L KMU-Networking - 7
RG-AP680-L KMU-Networking - 8
RG-AP680-L KMU-Networking - 9
RG-AP680-L KMU-Networking - 10
RG-AP680-L, Wi-Fi 6 Dual-Radio 2.976 Gbps Outdoor AP
Outdoor scenarios in general education, energy, business, government, and healthcare sectors
  • Industrial-grade product design, IP68 rating, Operating temperature: –40°C to +65°C
  • High-power omnidirectional antennas with 360° coverage to every corner
Hauptspezifikationen
Funktionen
Designed for Beach
Ruijie Cloud Managed Series Outdoor AP RG-AP680-L
Max. Data Rate 2.976 Gbps
4 Spatial Streams
IP68 Rating
DC/PoE Power Supply
Free Cloud Management
Ensuring Stable Running in Harsh Environments
Corrosion Protection
IP68 Rating
6 kV Lightning Protection
Wide Temperature Range
Comply with salt spray prevention standards, ensuring stable running in saline, warm and humid environment.
IP68 Rating
IP68 rating protection against dust and water, avoiding liquid and sand intrusion.
Built-in high-standard lightning protectors, defending against 6 kV surge and ensuring stable running in bad weather such as thunderstorms.
Operating in the range of –40°C to +65°C, adapting to clod weather in the northern regions.
Omnidirectional Antennas with 360° Coverage to Every Corner
Equipped with 28 dBm omnidirectional antennas with high transmit power
Extending coverage to every corner within 360° and up to 300 m in radius
Good signal coverage for STAs around the AP (including the rear side)
Applicable to outdoor environments where STAs are dispersed
Wi-Fi 6 AX3000
Achieving a combined data rate of up to 2.976 Gbps
2.976
Gbps
High Concurrency
Low Latency
is as low as 20 ms.
High Security
High Speed
802.11ac.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Spezifikationen
RG-AP680-L
Unit dimensions(W x D x H)
415 mm x 242 mm x 337 mm (16.34 in. x 9.53 in. x 13.27 in.)
Main unit: 1.12 kg (2.47 lbs)
6.43 kg (14.18 lbs)
Ceiling/Pole-mount (a mounting bracket is delivered with the main unit)
RG-AP680-L
Dual-radio and four spatial streams:
Operating frequencies
Radio 1: 802.11b/g/n/ax
Radio 2: 802.11a/n/ac/ax
Egypt
Data rates
Radio 1: 2.4 GHz, 574 Mbps
Radio 2: 5 GHz, 2.402 Gbps
● Two spatial stream Multi-User (MU) MIMO for up to 2.402 Gbps wireless data rate to up to two 1SS HE160 802.11ax DL-MU-MIMO capable client devices simultaneously (maximum)
● Two spatial stream Multi-User (MU) MIMO for up to 1.201 Gbps wireless data rate to up to two 1SS HE80 802.11ax DL-MU-MIMO capable client devices simultaneously (typical)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
● 802.11ac: 6.5 to 400 (MCS0 to MCS9, NSS = 1 to 2,VHT20 to VHT40)
5 GHz radio
● 802.11ac: 6.5 to 1733 (MCS0 to MCS9, NSS = 1 to 2,VHT20 to VHT160)
Packet aggregation
802.11n/ac/ax : A-MPDU and A-MSDU
Antenna gain
2.4 GHz radio: 3.5 dBi
5 GHz radio: 5.5 dBi
Maximum transmit power
Thailand
Peru
2.400 GHz to 2.4835 GHz: EIRP ≤ 36dBm
5.150 GHz to 5.250 GHz: EIRP ≤ 23dBm
5.250 GHz to 5.350 GHz: EIRP ≤ 30dBm
5.470 GHz to 5.725 GHz: EIRP ≤ 30dBm
Egypt
Vietnam:
5250-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
RG-AP680-L
2.4 GHz 802.11b
25 dBm
-92 dBm
25 dBm
-82 dBm
25 dBm
-84 dBm
25 dBm
-78 dBm
2.4 GHz 802.11g
25 dBm
-84 dBm
-74 dBm
-72 dBm
-67 dBm
2.4 GHz 802.11n (HT20)
25 dBm
-84 dBm
-66 dBm
2.4 GHz 802.11n (HT40)
25 dBm
-79 dBm
-63 dBm
2.4 GHz 802.11ax (HE20)
25 dBm
-84 dBm
-54 dBm
2.4 GHz 802.11ax (HE40)
25 dBm
-80 dBm
-51 dBm
5 GHz 802.11a
25 dBm
-84 dBm
-74 dBm
-72 dBm
-67 dBm
5 GHz 802.11n (HT20)
25 dBm
-84 dBm
-66 dBm
5 GHz 802.11n (HT40)
25 dBm
-81 dBm
-63 dBm
5 GHz 802.11ac (VHT20)
25 dBm
-84 dBm
19 dBm
-61 dBm
5 GHz 802.11ac (VHT40)
25 dBm
-81 dBm
19 dBm
-56 dBm
5 GHz 802.11ac (VHT80)
25 dBm
-78 dBm
19 dBm
-53 dBm
5 GHz 802.11ax (HE20)
25 dBm
-84 dBm
-54 dBm
5 GHz 802.11ax (HE40)
25 dBm
-81 dBm
-51 dBm
5 GHz 802.11ax (HE80)
25 dBm
-78 dBm
-48 dBm
5 GHz 802.11ax (HE160)
25 dBm
-73 dBm
-43 dBm
Bluetooth Radio
RG-AP680-L
Bluetooth 5.0
iBeacon Bluetooth, applied to Bluetooth locating and Bluetooth applications
Maximum antenna gain
5 dBi
10 dBm
Receive sensitivity
-88 dBm (@BLE)
Ports Specifications
RG-AP680-L
1 x 10/100/1000BASE-T port, in compliance with IEEE 802.3af/802.3at standard
1 x 1GE SFP port
3 x single-color RSSI LEDs
RG-AP680-L
Overall power consumption
● DC powered: 12.95 W
● Idle mode: 6.0 W
RG-AP680-L
IP68
> 250,000 hours
RG-AP680-L
Security standards
EN 62368-1
EN 60950-22
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300328
EN 62311
EN IEC 62311
EN 50665
FCC Part 15
Applicable Software Version
RG-AP680-L
RGOS11.9(6)W3B3 or later
RG-AP680-L
120
1024
 Note
Maximum number of BSSIDs
RG-AP680-L
Dynamic ACL assignment
RG-AP680-L
NAT, FTP ALG, DNS ALG
IPv6 basics
RG-AP680-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
Ressourcen
Auftragsinformationen
RG-AP680-L
Up to four spatial streams
Data rate of up to 2.976 Gbps
IEEE 802.3af/at-compliant (PoE/PoE+) power supply and DC power supply (48 V/0.35 A)
Häufig gestellte Fragen
