RG-S6120-20XS4VS2QXS Switches - 1
RG-S6120-20XS4VS2QXS Switches - 2
RG-S6120-20XS4VS2QXS Switches - 3
RG-S6120-20XS4VS2QXS Switches - 4
RG-S6120-20XS4VS2QXS Switches - 5
RG-S6120-20XS4VS2QXS Switches - 6
RG-S6120-20XS4VS2QXS Switches - 7
RG-S6120-20XS4VS2QXS Switches - 8
RG-S6120-20XS4VS2QXS Switches - 9
RG-S6120-20XS4VS2QXS Switches - 10
RG-S6120-20XS4VS2QXS Switches - 11
RG-S6120-20XS4VS2QXS 20-Port 10GE Layer 3 Managed Core and Aggregation Switch
A Red Dot Design Award winner. Recommended core or aggregation switch for small and medium-sized enterprise deployment.
  • Rich port types, 20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, and 2 x 40GE QSFP+ ports for uplink
  • Abundant QoS policies for flexible resource allocation, congestion is a thing of the past
  • Multiple management modes, simple and easy maintenance
Hauptspezifikationen
Funktionen
Layer 3 All-Optical 10G Core & Aggregation Switch
Recommended aggregation switch for large-sized networks, or core switch for small and medium-sized networks. With 20 x 1GE/2.5GE/10GE SFP+ ports and 4 x 10GE/25GE SFP28 ports, the switch provides flexible access capabilities. The 2 x 40GE QSFP+ uplink ports deliver high-speed uplink connectivity, fully satisfying the requirements of high-performance networks.
and Network Connectivity
Optical Port Fault Isolation
With multi-plane flow classification and control capabilities for MAC flow, IP flow and application flow, accurate resource allocation for multi-service traffic makes congestion a thing of the past, delivering high-quality networks.
achieving automatic O&M.
Spezifikationen
2 x 40GE QSFP+ ports (1 x 40GE port can be split into 4 x 10GE ports)
Note: One switch provides a maximum of 32 x 10GE ports
M1SFAN I-F (pre-installed 2)
678 Mpps
System switching capacity*2
912 Gbps
Single-core CPU, with the clock speed of 1.25 GHz
1 GB, 32-bit width, 4-bit ECC
RG-PA150IB-F(AC input):
RG-PD150IB-F (DC input):
RG-PD150IB-F: 150 W
85 W
440 mm x 330 mm x 43.6 mm (17.3 in. x 12.99 in. x 1.72 in.)
545 mm x 500 mm x 235 mm (21.46 in. x 19.69 in. x 9.25 in.)
4.6 kg (10.14 lbs, with two fan modules)
5.70 kg (12.57 lbs)
2 x pluggable fan modules
Fan cooling, front-to-rear airflow
Maximum value: < 78 dB
Automatic speed adjustment
Service port: 6 kV
RG-PA150IB-F: common mode 6 kV, differential mode 6 kV
Software Specifications
200 Gbps
32,768
160,000
100
In: 2,500 Out: 1,000
Functiion
Ethernet Switching
Basic QinQ and selective QinQ
Non blocking
DHCPv6 Client, DHCPv6 relay, and DHCPv6 snooping
IP Routing
IS-IS
BGP4 and MP-BGP
IPv4/IPv6 VRF
IPv4/IPv6 PBR
IGMPv1/v2/v3 and IGMP proxy
PIM-DM, PIM-SM, and PIM-SSM
MLDv1/v2 snooping
Validity check of IGMP packets
ACL80 and IPv6 ACL
ACL redirection
Loose and strict RPF
uRPF ignoring default routes
IPv4 VRRP v2/v3 and IPv6 VRRP
Power modules in 1+1 redundancy mode
NTP, SNTP, and NTP for IPv6
FTP/TFTP v6
SNMP over IPv6
CLI (Telnet/console)
Syslog
IPv6 MIB support for SNMP
Telnet v6
Traceroute v6
 DNS v6
Ressourcen
Auftragsinformationen
20 x 1GE/2.5GE/10GE SFP+ ports,4 x 10GE/25GE SFP28 ports,2 x 40GE QSFP+ ports
2 x power module slots (at least one RG-PA150IB-F power module needs to be configured)
2 x fan module slots (the device is equipped with two fan modules upon delivery)
RG-PD150IB-F
150 W DC power module
  • 20 x 1GE/2.5GE/10GE SFP+ ports support 1GE SFP transceivers, 2.5GE SFP transceivers, 10GE SFP+ transceivers.
  • 4 x 10GE/25GE SFP28 ports support 10GE SFP+ transceivers and 25GE SFP28 transceivers. All 10GE/25GE SFP28 ports must work at the same rate, either 25G or 10G.
25GE
VG-SFP-AOC7M(M)
Häufig gestellte Fragen
