RG-AP880-AR Drahtlos - 1
RG-AP880-AR Drahtlos - 2
RG-AP880-AR Drahtlos - 3
RG-AP880-AR Drahtlos - 4
RG-AP880-AR Drahtlos - 5
RG-AP880-AR Drahtlos - 6
RG-AP880-AR Drahtlos - 7
RG-AP880-AR Drahtlos - 8
RG-AP880-AR Drahtlos - 9
RG-AP880-AR Drahtlos - 10
RG-AP880-AR Drahtlos - 11
RG-AP880-AR, Wi-Fi 6 Quad-Radio 7.780 Gbps High-Density Indoor Access Point, 5Gbps Combo SFP Port
  • Upgraded to Wi-Fi 6, a combined data rate of up to 7.780 Gbps
  • AI radio for intelligent guidance of STA roaming, ensuring service continuity
  • Independent AI Radio for security protection, delivering better experiences and higher security
Hauptspezifikationen
Funktionen
Wi-Fi 6 High-Density Indoor AR Series AP
RG-AP880-AR
Maximum Data Rate
7.780 Gbps
All-Optical i-Share+
Solution
10 Spatial Streams
Bluetooth 5.1
5G Optical Port and 5G Electrical
Port for Flexible Networking
One 5G optical port supports higher bandwidth. With Ruijie All-Optical i-Share+ Solution, this port helps achieve all-optical gigabit access in rooms.
Upgraded to Wi-Fi 6
Achieving a Combined Data Rate of Up to 7.780 Gbps
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
AI Radio for Intelligent Guidance of STA
Roaming, Ensuring Service Continuity
The built-in AI Radio independently scans STA status, and reports the scanning result of neighbor APs to ACs. The ACs then guide STAs to quickly access an AP with better signals.
In this way, STAs can maintain a good signal quality during movement, thereby achieving low latency, no lagging, and service continuity in roaming.
Traditional Settled AP
Average roaming latency: 300ms
Packet loss rate: 2%
RG-AP880-AR
Average roaming latency: < 30ms
Packet loss rate: < 0.5%
Different from traditional, periodic, single-radio scanning with blind spots, AI Radio performs independent, real-time, full-radio, secure scanning.
The secure scanning does not occupy communication radio resources or affect wireless performance, ensuring good network experiences.
AI Radio
Traditional AP
24/7 real-time scanning
5G/2.4G full-radio scanning
Legend:
Secure scanning
Data transmission
Scanning, Safeguarding
secure scanning.
AI Radio
Traditional AP
Unified Cloud Management
Go to WIS ->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
Spezifikationen
RG-AP880-AR
Ten spatial streams
● Radio 1 – 2.4 GHz: 2x2 MIMO, two spatial streams
● Radio 2 – 5 GHz: 2x2 MIMO, two spatial streams
● Radio 3 – 5 GHz: 4x4 MIMO, four spatial streams
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 1 – 2.4 GHz: 20 MHz and 40 MHz
● Radio 2 – 5 GHz: 20 MHz and 40 MHz
● Radio 3 – 5 GHz: 20 MHz and 40 MHz
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: 20 MHz and 40 MHz
Combined peak data rate: 1.200 Gbps
● Radio 1 – 2.4 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15 )
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS15)
● Radio 3 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
● Radio 4 – AI Radio, 2.4 GHz/5 GHz: AI Radio for scanning only
Eight spatial streams
● Radio 2 – 5 GHz: 2x2 MU-MIMO, two spatial streams
● Radio 3 – 5 GHz: 4x4 MU-MIMO, four spatial streams
● Radio 4 – AI Radio, 5 GHz: 2x2 MIMO, two spatial streams
Channels:
● Radio 2 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 3 – 5 GHz: 20 MHz, 40 MHz, 80 MHz, and 160 MHz
● Radio 4 – AI Radio, 5 GHz: 20 MHz, 40 MHz, and 80 MHz
Combined peak data rate: 5.200 Gbps
● Radio 2 – 5 GHz: 6.5 Mbps to 1.733 Gbps (MCS0 to MCS9)
● Radio 3 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
● Radio 4 – AI Radio, 5 GHz: AI Radio for scanning only
● Radio 3 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
Combined peak data rate: 7.780 Gbps:
● Radio 3 – 5 GHz: 7.3 Mbps to 4.804 Gbps (MCS0 to MCS11)
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5.5 dBi.
● 5 GHz: six built-in omnidirectional smart antennas, with peak antenna gain of 7 dBi.
One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 3 dBi.
1 x 100/1000/2.5G/5GBASE-T port, in compliant with IEEE 802.3af/at/bt standard (PoE/PoE+/PoE++)
1 x 10/100/1000BASE-T port,supplying 48 V/12.95 W power to an IoT unit
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 2 for PoE supply (48 V/12.95 W), and USB port for power supply (5 V/5 W)
● 802.3bt (PoE++): 40 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 4x4, Radio 4 (AI Radio) 2x2, LAN 2 for PoE supply (48 V/12.95 W), and USB port for power supply (5 V/5 W)
● 802.3at (PoE+): 25 W, Radio 1 (2.4 GHz) 2x2, Radio 2 (5 GHz) 2x2, Radio 3 (5 GHz) 2x2, Radio 4 (AI Radio) 2x2, LAN 2 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● 802.3af (PoE): 12.2 W, Radio 1 (2.4 GHz) 1x1, Radio 2 (5 GHz) 1x1, Radio 3 (5 GHz) 1x1, Radio 4 (AI Radio) is disabled, LAN 2 supports data transmission but does not provide PoE output. The USB port is disabled and does not supply power to external devices.
● Idle mode: 12.2 W
External power supply
Note: At an altitude in the range of 3,000–5,000 m (9842.52–16,404.20 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
512 MB DRAM, 256 MB flash
RG-AP880-AR
24 dBm
–96 dBm
24 dBm
–93 dBm
–90 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–67 dBm
24 dBm
–64 dBm
24 dBm
–88 dBm
18.5 dBm
–63 dBm
24 dBm
18.5 dBm
24 dBm
18.5 dBm
–57 dBm
24 dBm
–58 dBm
24 dBm
24 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
24 dBm
–50 dBm
Basic Functions
RG-AP880-AR
RGOS11.9(6)W1B2 or later
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
PSK and web-based authentication
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Interface-based VLAN
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
Identification of IP address conflicts between downlink users
Number of IPv4 addresses set for each Layer 3 interface: 200
NAT, FTP ALG and DNS ALG
Number of IPv6 addresses set for each Layer 3 interface: 400
NTP server and NTP client
SNMPv1/v2C/v3
On-demand diagnosis with packet capture
Remote Packet Capture Protocol (RPCAP) with third-party tools for remote packet review
RG-AP880-AR
Big data capabilities
RG-AP880-AR
  • EU simplified DoC: Hereby, [RuijieNetworks Co., Ltd.] declares that the radio equipment type [RG-AP880-AR] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [RuijieNetworks Co., Ltd.] declares that the radio equipment type [RG-AP880-AR] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • Ruijiewireless products provide only secure and reliable network protocols and communication ports by default. For details, see Ruijie Default Protocols and Ports for Wireless Products. Proper firewall and security policies can be implemented based on this document to ensure the normal operation of wireless services.
Ressourcen
Auftragsinformationen
RG-AP880-AR
Quad-radio, ten spatial streams, peak data rate of 7.780 Gbps
● Radio 1: 2.4 GHz: two spatial streams, 2x2 MIMO, peak data rate of 574 Mbps
● Radio 3: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
● Radio 4 (AI Radio): 2.4 GHz/5 GHz: two spatial streams, 2x2 MIMO, for scanning only
Häufig gestellte Fragen
