RG-AP680-IO Drahtlos - 1
RG-AP680-IO Drahtlos - 2
RG-AP680-IO Drahtlos - 3
RG-AP680-IO Drahtlos - 4
RG-AP680-IO Drahtlos - 5
RG-AP680-IO Drahtlos - 6
RG-AP680-IO Drahtlos - 7
RG-AP680-IO Drahtlos - 8
RG-AP680-IO Drahtlos - 9
RG-AP680-IO Drahtlos - 10
RG-AP680-IO, Wi-Fi 6 Dual-Radio 5.951 Gbps Outdoor Access Point, Omnidirectional Antennas
Outdoor scenarios covering higher education, wireless city, energy, and plaza scenarios
  • 10G optical port and 5G Ethernet port for flexible networking
  • Built-in omnidirectional antennas, wide Wi-Fi coverage
  • 5.951 Gbps high speed with 160 MHz band
  • Industrial-grade product design, IP68 rating, 6 kV lightning protection
Hauptspezifikationen
Funktionen
High-Power Wi-Fi 6 Outdoor AP RG-AP680-IO
Up to eight spatial streams
Max. data rate 5.951 Gbps
IP68 rating
Bluetooth 5.1
Multiple Service Ports, Flexible Networking
10 Gbps SFP+ port: Designed for Ruijie Optical i-Share+ Solution, enabling long-distance and high-bandwidth deployment for outdoor APs.
5 Gbps electrical port: Used for wired connection, meeting networking demands while reducing networking investment.
Omnidirectional Antennas, Wide Wi-Fi Coverage
Built-in 2.4 GHz / 5 GHz dual-band omnidirectional antennas with high transmit power of 30 dBm, enabling wide Wi-Fi coverage.
Beamforming technology, intelligently identifying the directions of mobile clients towards the AP, dynamic adjustment of signal coverage directions and strength, enhancing coverage accuracy and stability.
5.951 Gbps Ultra-Fast Speed with Wi-Fi 6
5.951 Gbps
High Concurrency
High Rate
Low Latency
High Security
Stable Running in Harsh Outdoor Environments
IP68 Protection
6 kV Lightning Protection
Wide Temperature Range
Go to WIS Cloud Network->
Cloud O&M
24 h network optimization
Real-time warning
Fault locating
Spezifikationen
RG-AP680-IO
Eight spatial streams
Channels:
Combined peak data rate: 1.2 Gbps
● Radio 1 – 2.4 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31 )
Four spatial streams
Channels:
Modulation types: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1,024-QAM
Channels:
Combined peak data rate: 5.951 Gbps:
● 2.4 GHz: four built-in omnidirectional antennas, with peak antenna gain of 6 dBi.
● 5 GHz: four built-in omnidirectional antennas, with peak antenna gain of 5 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 3 dBi.
1 x 100/1000/2.5G/5GBASE-T RJ45 Ethernet port with auto-negotiation
1 x 100/1000BASE-T RJ45 Ethernet port with auto-negotiation
1 x 10GE optical port,compatibility with 1GE and 2.5GE
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Whether bridging is enabled
Main unit: 3.3 kg (7.28 lbs)
Shipping: 6.5 kg (14.33 lbs)
● 802.3af (PoE): 12.95 W, the AP starts up normally. Bluetooth and GPS work properly, all radios do not work, and LAN 2 fails to provide power for external devices.
● 802.3at (PoE+): 25 W, 2.4 GHz radio 4x4, 5 GHz radio 4x4, Bluetooth and GPS work properly, LAN 2 fails to provide power for external devices.
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 4x4, 5 GHz radio 4x4, Bluetooth and GPS work properly, LAN 2 for PoE supply, Bluetooth and GPS work properly.
● Idle mode: 10 W
2 GB DRAM, 256 MB flash
● Maximum transmit power: 30 dBm (1,000 mW)
● Maximum transmit power: 29 dBm (795 mW)
GPS positioning
Frequency Performance
RG-AP680-IO
2.4 GHz 802.11b
24 dBm
–94 dBm
24 dBm
–91 dBm
23 dBm
–90 dBm
22 dBm
–88 dBm
2.4 GHz 802.11g
24 dBm
–89.5 dBm
–83 dBm
–79 dBm
21 dBm
–73 dBm
2.4 GHz 802.11n (HT20)
24 dBm
–86 dBm
21 dBm
–68 dBm
2.4 GHz 802.11n (HT40)
24 dBm
–83 dBm
21 dBm
–65 dBm
2.4 GHz 802.11ax (HE20)
24 dBm
–86 dBm
19 dBm
–68 dBm
2.4 GHz 802.11ax (HE40)
24 dBm
–83 dBm
19 dBm
–65 dBm
5 GHz 802.11a
23 dBm
–89.5 dBm
22 dBm
–83 dBm
22 dBm
–79 dBm
–73 dBm
5 GHz 802.11n (HT20)
23 dBm
–86 dBm
–68 dBm
5 GHz 802.11n (HT40)
23 dBm
–83 dBm
–65 dBm
5 GHz 802.11ac (VHT20)
23dBm
–86 dBm
19 dBm
–61 dBm
5 GHz 802.11ac (VHT40)
23 dBm
–83 dBm
19 dBm
–57 dBm
5 GHz 802.11ac (VHT80)
23 dBm
–80 dBm
19 dBm
5 GHz 802.11ax (HE20)
23 dBm
–86 dBm
16 dBm
–58 dBm
5 GHz 802.11ax (HE40)
23 dBm
–83 dBm
16 dBm
–54 dBm
5 GHz 802.11ax (HE80)
23 dBm
–80 dBm
16 dBm
–52 dBm
5 GHz 802.11ax (HE160)
23 dBm
–77 dBm
16 dBm
–49 dBm
Basic Functions
RG-AP680-IO
RGOS11.9(6)W3B6 or higher
250
Maximum number of WLAN IDs
MU and TAG device locating
Application management
Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP, GCMP)
Dynamic Policy
CoA/DM
MAC address table size: 2,048
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
Maximum number of ARP entries: 2,408
NAT, FTP ALG, and DNS ALG
NTP server and NTP client
Telnet, SSH, SNMP and FTP management
RG-AP680-IO
Big data capabilities
RG-AP680-IO
EN 55032, EN 55035, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN 62311, EN IEC 62311, EN 50665, IEC 62368-1, EN 62368-1, IEC 60950-22, EN 18031-1, and EN 18031-2
  • EU simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-IO] is in compliance with Directive 2014/53/EU. The full text of the EU declaration of conformity is available at the following internet address: https://www.ruijie.com/.
  • UK simplified DoC: Hereby, [Ruijie Networks Co., Ltd.] declares that the radio equipment type [RG-AP680-IO] is in compliance with UK Radio Equipment Regulation 2017. The full text of the UK declaration of conformity is available at the following internet address: https://www.ruijie.com/.
Ressourcen
Auftragsinformationen
RG-AP680-IO
Data rate of up to 5.951 Gbps
Fat/Fit/Cloud mode switchover
Häufig gestellte Fragen
