RG-WS6512-L KMU-Networking - 1
RG-WS6512-L KMU-Networking - 2
RG-WS6512-L KMU-Networking - 3
RG-WS6512-L KMU-Networking - 4
RG-WS6512-L KMU-Networking - 5
RG-WS6512-L KMU-Networking - 6
RG-WS6512-L, High-Performance Large Campus Wireless Access Controller
Funktionen
Product Overview
The RG-WS6512-L high-performance wireless access controller (AC), developed by Ruijie Networks, is targeted for next-generation high-speed wireless networks. It can be deployed on a Layer 2 or Layer 3 network without any architecture or hardware device changes, delivering seamless and secure control over wireless networks.
The RG-WS6512-L can manage up to 128 wireless access points (APs) by default. With licenses for capacity expansion, it can manage a maximum of 1,152 generic APs or 2,304 wall-mounted APs.
Through powerful centralized and visualized management and control over wireless networks, the RG-WS6512-L can significantly simplify construction and deployment of wireless networks.
The RG-WS6512-L, adopting enhanced security and clustering technologies, offers identity-based networking services. Multiple ACs in a cluster can share a user database, allowing clients to seamlessly roam in different areas of a network. The cluster design guarantees the security and session integrity during roaming and smooth interaction of data and voice over Wi-Fi applications.
Product Highlights
High-speed Forwarding with Full IPv6 Support
●  Centralized/Distributed, integrated, and intelligent local forwarding, eliminating the traffic bottleneck of the wireless access controller
●  Full IPv6 support
Intelligent Management
●  Adaptive Portal authentication page for clients, fair client access, and intelligent load balancing through spectrum navigation
●  Intelligent RF management, flexibly controlling AP configuration and optimizing RF coverage and performance
●  Advanced wireless access controller cluster technology for fast roaming and voice support
Secure and Reliable Network Systems
●  Advanced AC virtualization technology for high reliability and capacity and performance scaling
●  Virtual AP technology, managing APs in groups for secure and convenient authentication and encryption
●  Dynamic network isolation for identity-based access control
●  Authentication and encryption technologies including WPA3, 802.1x, PSK, WEP, and TKIP for enhanced data security
●  Deep Packet Inspection (DPI) based on packet characteristics, identifying over 2500 applications
●  Uniform policy enforcement for WLAN, LAN, and WAN traffic, including content auditing, Flow Pre-Manager (FlowPM), and Ruijie Network Foundation Protection (RNFP)
Spezifikationen
RG-WS6512-L
630 mm x 335 mm x 500 mm (24.8 in. x 13.19 in. x 19.69 in.)
Main unit: 5.9 kg (13.01 lbs)
A power module is delivered with the main unit.
14.50 kg (31.97 lbs)
RG-WS6512-L
8 x GE combo ports , when the combo port is used as an electrical port,
● Port 1 can be used as an out-of-band management port (MGMT).
● It supports 10/100/1000Base-T auto-negotiation.
● It supports Auto MDI/MDIX crossover.
4 x 10GE SFP + ports
2 x USB ports
1 x system status LED
20 x service port LEDs
RG-WS6512-L
70 W
Input voltage
Input current
10 A (steady state)
Output voltage
12 V/5.83 A
RG-WS6512-L
Main unit operating temperature: 0°C to 45°C (32°F to 113°F)
Power module operating temperature: –10°C to +50°C (+14°F to +122°F)
Main unit storage temperature: –40°C to +70°C (–40°F to +158°F)
Note: At an altitude between 3,000 m (9,843 ft.) and 5,000 m (16,404 ft.), every time the altitude increases by 220 m (721.78 ft.), the maximum temperature decreases by 1°C (1.8°F).
0 m to 5,000 m (0 ft. to 16,404 ft.)
Three built-in fans (on the left side)
Right-to-left airflow
< 78 dB
RG-WS6512-L
128
Note: The default number of APs that can be managed by the RG-WS6512-L is subject to the AP model. See the Ordering Information for details.
4,096
2,304
Note: The maximum number of APs that can be managed by the RG-WS6512-L is subject to the AP model. See the Ordering Information for details.
32,768
Note: The maximum number of STAs that can be managed by the RG-WS6512-L is subject to the network environment. Contact technical support team for details.
WLAN service
Maximum number of associated STAs per WLAN: 32,768
Intra-AC roaming handoff time
< 50 ms
802.11 forwarding capacity
Number of MAC address entries
131,072
Number of VLANs
4,096
Number of ARP entries
81,920
DHCP address pools
Number of IPv4 addresses: 81,920
Number of routing entries
IPv4 routing entries: 8,192
IPv6 routing entries: 10,000
Number of multicast entries
Static routing entries: 2,048
7,500
Number of ACL entries
131,072
Applicable Software Version
RG-WS6512-L
RGOS 11.9(6)W1B3 or later
RG-WS6512-L
IEEE 802.11 protocols
Roaming
Forwarding mode
Centralized forwarding
Local forwarding
Wireless QoS
Fair scheduling
AC-based user isolation
AP-based user isolation
WLAN-based user isolation
AC virtualization
AC failover
Multi-AC cluster (N-to-N)
WLAN optimization
RF management
Coverage hole compensation
Band selection
RG-WS6512-L
IPv4 security authentication
802.1X authentication
MAB authentication
SMS authentication
IPv6 security authentication
Multi-SSID mode
WPA and WPA2
WEP (WEP/WEP128)
TKIP
CCMP
Anti-ARP spoofing
AP virtualization
Protocol
RG-WS6512-L
IPv4 protocols
Ping and traceroute
DNS client
NTP
Telnet
TFTP server and TFTP client
FTP server and FTP client
IPv6 protocols
DNSv6 client
TFTPv6 client
FTPv6 server and FTPv6 client
IPv6 CAPWAP
IPv6 ping
Manual tunnels, automatic tunnels, and ISATAP tunnels
IPv6 traceroute
IPv4 routing
Static routing, RIP, and OSPF
IPv6 routing
Static routing, RIPng, and OSPFv3
RG-WS6512-L
RMON
Syslog
Remote probe
Eweb
Wi-Fi heat map
RG-WS6512-L
IEC 62368-1, EN 62368-1
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, and ETSI EN 300 386
Ressourcen
Auftragsinformationen
  • Order an RG-WS6512-L.
Main Unit and Accessories
RG-WS6512-L
RG-PA70I
Optical Modules
Mini-GBIC-SX
1000BASE-SX mini-GBIC module
Mini-GBIC-LX
1000BASE-LX mini-GBIC module
10GE SFP+ SR module
10GE SFP+ LR module
Licenses
RG-LIC-WS-16
RG-LIC-WS-32
RG-LIC-WS-128
RG-LIC-WS-512
RG-LIC-WS-1024
