RG-AM5528-SF Drahtlos - 1
RG-AM5528-SF Drahtlos - 2
RG-AM5528-SF Drahtlos - 3
RG-AM5528-SF Drahtlos - 4
RG-AM5528-SF Drahtlos - 5
RG-AM5528-SF Drahtlos - 6
RG-AM5528-SF Drahtlos - 7
RG-AM5528-SF Drahtlos - 8
RG-AM5528-SF Drahtlos - 9
RG-AM5528-SF Drahtlos - 10
RG-AM5528-SF Drahtlos - 11
RG-AM5528-SF, Simplified Optical Ethernet (SOE) Master Access Point
  • Connection with APs through hybrid cables, realize long distance and fast transmission
  • Full 2.5G downlink optical ports, fully maximizing the AP performance
  • Multiple AP models allowing flexible service expansion
  • AP remote power-on or power-off, eliminating the need for onsite operation
Hauptspezifikationen
Funktionen
Ruijie All-Optical i-Share+ Solution — Master AP RG-AM5528-SF
All-optical architecture, point-to-point power supply for APs through hybrid cables
High-bandwidth data transmission and long-distance power supply, supporting the long-term evolution of wireless network construction in the next two decades
Solution
All-Optical Network
Hybrid Cable
Wi-Fi 6
i-Share Mode
Power On/Off of a Single AP
24 Optical Ports and 24 PoE Ports, Hybrid Cable, Maximum Transmission Distance of 1000 m
24 optical ports and 24 power supply ports, and direct connection with optical APs through innovative hybrid cables
Only one cable for high-bandwidth data transmission and long-distance PoE power supply concurrently, simplifying the deployment of an all-optical network
Longer Distance
The connection distance between the master and micro APs is up to 1,100 m, realizing central management.
Faster Transmission
The transmission rate of the hybrid cable is up to 400 Gbps to meet the expansion requirements in the next two decades.
Superior Power Supply
The master AP can power 24 micro APs with one cable, eliminating the need for local power supply.
2.5G Optical Ports, Eliminating the Bottleneck of Gigabit Networks and Maximizing AP Performance
Full 2.5G downlink optical ports, allowing high-speed transmission of APs
Breaking the bottleneck of wired networks and providing better wireless experience for growing service needs
Multiple AP Models, Facilitating Flexible Service Expansion
The optical i-Share master AP provides the i-Share mode, supports access of micro APs, and integrates wired and wireless coverage of intensive rooms such as dormitories and hotels.
It can also switch to the common mode, provide Layer 2 switching, realize on-demand access of the ordinary wall plate APs, indoor APs, and outdoor APs, facilitating flexible service expansion.
An O/E converter is required for connecting an conventional AP with copper ports to a master AP.
P2P Power Supply Control and Remote Power-on/Power-off,
Eliminating the Need for Onsite Operation
The 24 power supply ports correspond to the downlink power ports one by one, and support visualization of power supply per circuit on the INC.
When an AP fails, each AP can be powered on or off remotely, without performing any onsite operation.
Spezifikationen
RG-AM5528-SF
(W x D x H)
Main unit: 442 mm x 315 mm x 43.6 mm (17.40 in. x 12.40 in. x 1.72 in.)
Shipping: 538 mm x 438 mm x 173 mm (21.18 in. x 17.24 in. x 6.81 in.)
Main unit: 4.6 kg (10.14 lbs)
Shipping: 6.38 kg (14.06 lbs)
Rack-mount
RG-AM5528-SF
1 GB DDR4
4 GB
RG-AM5528-SF
Uplink: 4 x 10GE SFP+ ports that can only switch between 10GE SFP+ mode and 1GE SFP mode simultaneously. Separate mode switching is not supported.
Downlink: 24 x 1GE/2.5GE SFP ports and 24 x PoE-out ports. Ports 1 to 20 support PoE/PoE+, and each port supports up to a 30 W PoE power supply. Ports 21 to 24 support PoE/PoE+/PoE++, and each port supports up to 90 W PoE power supply.
The maximum PoE output power is 480 W.
1 x 10/100/1000BASE-T MGMT port
24 x PoE LEDs
24 x 1000/2.5GBASE-X SFP port LEDs
4 x SFP+ port LEDs
1 x system status LED
1 x power LED
1 x MGMT port LED
RG-AM5528-SF
One 550 W built-in power module (AC input and DC output)
● Input voltage: 176 V AC to 240 V AC
Frequency: 50 Hz to 60 Hz
Rated input current: 4 A
● Output voltage: 12 V DC for the master AP and 54 V DC for the external unit
Without load: < 42 W
With full load: < 530 W
RG-AM5528-SF
Operating temperature: 0ºC to 45ºC (32°F to 113°F)
Operating humidity: 10% RH to 90% RH (non-condensing)
Storage humidity: 5% RH to 95% RH (non-condensing)
AC power connector
● Differential mode: ± 6 kV
● Common mode: ± 6 kV
Hybrid cable connector
● Differential mode: ± 2 kV
69.23 years at the operating temperature of 25°C (77°F)
RG-AM5528-SF
RGOS12.5(4)B0404P1 or later
Egress ACL based on a Layer 2 physical interface or aggregate interface
Ingress ACL based on a Layer 2 physical interface or aggregate interface
Egress ACL based on a Layer 3 interface
Ingress ACL based on a Layer 3 interface
Routing and Switching
MAC address learning and aging
Static and dynamic MAC addresses
Source MAC address filtering
Limitation on the number of MAC addresses learned on an interface
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 1,000
VLAN ID range: 1 to 4,094
Maximum number of ARP entries: 24,000
Static and dynamic IPv4 addresses
DHCP server and DHCP client
DNS client and DNS proxy
NTP server, NTP client, and SNTP client
Static and dynamic IPv6 addresses.
Neighbor Discovery (ND), IPv6 ND proxy, ICMPv6, and IPv6 ping
DNSv6 client
NTPv6 server and NTPv6 client
Maximum number of static IPv4 routes: 1,000
Maximum number of static IPv6 routes: 1,000
Static black hole routing
IGMP snooping
Console, Telnet, SSH, TFTP client, TFTP server, FTP server ,and FTP client
RG-AM5528-SF
Ressourcen
Auftragsinformationen
RG-AM5528-SF
All-optical i-Share+ master AP for Ruijie SOE Solution
24 x downlink 1G/2.5G SFP ports and 24 x PoE/PoE+ power supply ports. Four power supply ports support PoE/PoE/PoE++ power supply.
4 x uplink 10G SFP+ ports, low noise, and power supply included
In i-Share+ mode, each master AP occupies eight wireless controller licenses.
RG-MAP852-SF-S
Universal IEEE 802.11ax-compliant dual-radio wall plate micro AP for Ruijie SOE Solution
1 x SFP port
1 x 10/100/1000Base-T Ethernet port with auto-negotiation
BOB structure
One 1G optical module of the master AP
RG-MAP852-SF-M
1 x 2.5G SFP port
4 x10/100/1000Base-T Ethernet ports with auto-negotiation
Support for Bluetooth
Wall-mounted, ceiling-mounted, and junction box-mounted
RG-MAP920-SF-M
Universal IEEE 802.11be-compliant dual-radio wall plate micro AP for Ruijie SOE Solution
1 x 2.5GE SFP port
4 x 10/100/1000BASE-T ports
A wireless data rate of up to 3.570 Gbps per device
The RG-MAP920-SF-M does not have a built-in optical transceiver by default, and BIDI optical transceivers must be used in pairs. Therefore, a pair of optical transceivers needs to be purchased separately. Recommended 2.5GE models: 2.5G-SFP-LX03-SM1310-BIDI-I and 2.5G-SFP-LX03-SM1550-BIDI-I.
GE-SFP-LX03-SM1550-BIDI
SFP BIDI Transceiver-TX1550/RX1310,3km,LC
GE-SFP-LX03-SM1310-BIDI
SFP BIDI Transceiver-TX1310/RX1550,3km,LC
SFP 2.5G BIDI Transceiver-TX1310/RX1550,3km,LC
10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC)
10GBASE-SR, SFP+ Transceiver (1550nm, 40km, LC)
10GBASE-SR, SFP+ Transceiver (1550nm, 80km, LC)
RG-HybridBox
The hybrid box for Ruijie SOE Solution supports input of 24 hybrid pigtails and output of 24 hybrid cables, which is used to connect the hybrid pigtails to the hybrid cables.
RG-OEHC-SM-1B6A2-2x0.5-I-305
Indoor single-core 2×0.5 mm² photoelectric hybrid cable, single roll, 305 m, with silicon dioxide single-mode fiber, zero-dispersion wavelength of 1300–1324 nm and fiber cladding diameter of 125.0±1.0 μm.
RG-OEHC-SM-2B6A2-2x1.0-I-305
RG-OEHC-SM-2B6A2-2x1.5-O-1000
Note: Currently, only some supported optical transceiver models are displayed. For more information about optical transceiver models, contact Ruijie pre-sales engineers.
Häufig gestellte Fragen
