Time: July 20th, 2023
What is a Layer 2 Switch?
What is a Layer 3 Switch?
1. A layer 2 switch is designed to perform Layer 2 functions, while a layer 3 switch performs both Layer 2 and Layer 3 functions (routing).
2. Layer 2 switches are less expensive and more efficient than layer 3 switches. They also have a lower learning time, which means they can be configured faster and easier.
3. Layer 2 switches are also more secure because they operate at the data link layer (Layer 2), where MAC addresses are used to identify nodes on the network. This means that each device on your network has its unique address--and therefore cannot impersonate another node's identity or access resources that aren't meant for it. In contrast, layer 3 devices use IP addresses for identification purposes; this makes them less secure because anyone can spoof an IP address if they know how to do so (and many hackers do).
4. A layer 2 switch is used to switch data between ports, while a layer 3 switch routes data between ports.
5. Layer 2 switches are cheaper and easier to configure than layer 3 switches. They're also better for small networks with fewer devices.
Points to Keep in Mind:
Conclusion
Technical Support
Technical Support
Get in Touch
Get in Touch
